Sony receiver not working, after it says PROTECT MODE. shuts itself off. - AVS Forum | Home Theater Discussions And Reviews
Old 01-18-2012, 09:38 PM - Thread Starter
LADYCLAIRE's Avatar
my Sony receiver stopped working when I unplugged my Droid phone from it while listening to pandora station. It was plugged in front of receiver in auxiallary audio port. Does anyone know why it "blew up". can i fix it? BTW< it did say "Protect mode" right when it happened, then it went off. unplugged it and tried to turn receiver on and it stays on for a little while (no sound) then it says PROTECT MODE again and turns itself off> Plese help!
LADYCLAIRE is offline
Old 01-18-2012, 10:01 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3099
Normally, protect mode means the receiver is overheating. Also, you shouldn't disconnect devices when content is being played. In any case, what model is the receiver? A microprocessor reset might be advised.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
Old 01-18-2012, 10:29 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Strange that it happened when you unplugged a Droid phone. In my experience going into protection mode (if not indicating a permanent problem,) is from a fault such as a bad speaker, bad wiring, or something like overheating.
Seeing how you unplugged it, and it's still faulting, it may need service. One thing you can do is to disconnect everything from it. Then unplug it, and let it sit for a bit (even overnight,) then plug it back in. If it faults again, it's probably a problem that requires servicing the receiver (or buying a new one if it's out of warranty, as most Sony models would likely cost more to service than they are worth.)
"But this one goes up to 11"
MichaelJHuman is offline
