Onkyo TX-NR809: DSP2 Writing 98%. Serial flash option? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-22-2012, 11:12 AM - Thread Starter
hevnsnt's Avatar
Receiver Info: Onkyo TX-NR809
Firmware Version: 1091-0977-??10-9105
Main Firmware: 1.09 11x18AM
Yes, the firmware showed two "??" in the version number. I have to assume that this is probably the issue. I have tried hard-resetting the box and try to do a firmware update over the network, and via USB and the same problem occurs. When the receiver starts to write the firmware, it stalls at 98% (Writing, not downloading) the screen shows "DSP2 Writing 98%". I have let it sit in that state for over 12 hours, to make sure it didn't just take a while.
Does anyone have any ideas how to fix this issue? Is there any serial, JTAG or otherwise force the firmware update onto the eeprom? Thanks for any help provided.
hevnsnt is offline
post #2 of 3 Old 07-09-2012, 08:42 AM - Thread Starter
hevnsnt's Avatar
Still looking for help here.. anyone have any ideas?
hevnsnt is offline
post #3 of 3 Old 03-28-2014, 03:10 PM
idiamant's Avatar
Hello.
I'm having the exact same problem. Any news about it?
Thank You.
Igor.
idiamant is offline
Onkyo Tx Nr809
