trouble shootin help Integra 80.3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-22-2012, 07:10 PM - Thread Starter
devildogdad's Avatar
I just replaced my dead 9.9 with a dhc 80.3. now I get hundreds of horizontal dashes that go across the screen. I plugged the hdmi from the projector directly into the blu ray and the lines were gone. So that ellimates them. I do not have an extra HDMI cable to try between the blu ray and the Integra. I will get one tomorrow.
Any other troubleshooting thoughts? it's a two hour drive to the dealer and I would hate to take it if I didnt need too. Thanks
devildogdad is offline
post #2 of 4 Old 01-22-2012, 08:20 PM
bobpaule's Avatar
Quoted: 22 Post(s)
Liked: 36
Now it is a good time to get it replaced.
IMHO you have a stillborn video processor in your
DHC, if true handshake issues were present you'd
have a blue screen.
I have a DHC-9.9 rock solid, how did yours die?
bobpaule is offline
post #3 of 4 Old 01-23-2012, 06:14 AM - Thread Starter
the audio on the 9.9 stopped. went in for service and the part alone was $850 . so since it was 4 generations back I decided to replace.
after reading more of the manual they say to try putting hdmi on pass thru, i will try that tonight. also will call the dealer and see what he thinks.
post #4 of 4 Old 04-10-2012, 06:14 AM
alanl715's Avatar
ur dealer shoulda told u that he has the ability to do a 6 month advanced exchange !
alanl715 is offline
