Pioneer vsx52 avr and spendor a5 speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-24-2012, 07:51 PM - Thread Starter
motobonsai's Avatar
I have a pioneer elite vsx52 receiver. I was thinking of getting some spendor A5's with a matching center.
Will the pioneer be good enough to drive the spendors?
If not, would getting an outboard amp like the emotiva xpa line help? Or would i need a more expensive amp?
Or is it just a waste to drive good speakers like that with an avr+amp?
motobonsai is offline
post #2 of 2 Old 01-25-2012, 09:24 AM
blackangst's Avatar
Quoted: 116 Post(s)
Liked: 102
Well, "good enough" is subjective. Do you have a powered sub? If so that will help. It's really going to depend on your listening levels, room size, etc. Reading around a bit they arent super efficient and appear to be a bit power hungry so an external amp may be the way to go.
Best suggestion? Try 'em and see The nice thing about Emo amps is you have a 30 day period you can return if you want.
My system: Yamaha RX-A3060, Emotiva XPA-2, Salk Song3, Salk Songcenter RT, Polk FXiA6, Rythmik FV15HP, Intel i7 HTPC running JRiver Media Center
blackangst is offline
