Pioneer VSX-918V No center or surround sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-31-2012, 08:28 PM - Thread Starter
Rubixcube22's Avatar
i just recently bought my Pioneer VSX-918V receiver and I just can't seem to get the center or surround sound to work. I went in troubleshooting in the manual and did everything it suggests but i still can't seem to get it to work. If i go into the channel levels where you can test the levels of each speaker i can hear the test sound coming from both the center and the surround speakers, but when i try playing music, watching tv, a movie ect. i get nothing out of them. Any suggestions?
Rubixcube22 is offline
post #2 of 12 Old 02-01-2012, 02:19 PM - Thread Starter
bump
post #3 of 12 Old 02-01-2012, 02:48 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi Rubixcube22, more info about your setup and settings would help.
JChin is offline
post #4 of 12 Old 02-01-2012, 03:32 PM - Thread Starter
uhhh, I have two Acoustic Audio 300w surround sound speakers, an 150w Acoustic Audio center speaker, a 90w samsung subwoofer, two MA Audio front speakers, and a dual speaker MA Audio Synergy connected. I have my Phillips flatscreen hooked up through DVR/VCR in, my xbox 360 hooked up in CDR/TAPE, and i have my turntable hooked up in AUX. I didn't lower or raise any of the channel levels. I have the subwoofer set at yes, and all the other speakers set at large.
post #5 of 12 Old 02-01-2012, 03:49 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Appears you're using RCA (white & red) audio cables. If so that is the reason you're getting 2Ch.
JChin is offline
post #6 of 12 Old 02-01-2012, 06:56 PM - Thread Starter
what should i do to fix this?
post #7 of 12 Old 02-01-2012, 09:53 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
For the Xbox 360, connect an optical cable Xbox 360 to receiver OPT-1.
Do you have a cable box or OTA (tv antenna)?
JChin is offline
post #8 of 12 Old 02-01-2012, 10:58 PM - Thread Starter
cable box
post #9 of 12 Old 02-01-2012, 11:34 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
first thing, set all your speakers to small and let your subwoofer handle the low frequencies.
second choose a sound mode like Dolby Pro Logic II or DTS:Neo6. Then you'll get sound from all your speakers.
Use optical connections from your cable box if it is HD and optical from Xbox 360 to receiver.
Afro GT
afrogt is offline
post #10 of 12 Old 02-02-2012, 01:01 PM - Thread Starter
how do I do that?
post #11 of 12 Old 02-08-2012, 12:50 PM - Thread Starter
i did exactly what you said. I figured out how to switch it to dolby pro logic and used an optical connection, but i still don't have sound in all my speakers...
post #12 of 12 Old 07-29-2013, 09:00 PM
lazyydesi's Avatar
Rubix... how did u get this to work? i have a new SC-67 and i can't seem to get the sound on surround or center speakers during the test tone or a movie.
regards,
Hassan
lazyydesi is offline
