The Official Pioneer VSX-921-K Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 73 Old 06-05-2013, 01:13 AM
stephanludik's Avatar
Snafu55,
It is not possible, to my knowledge to stream a digital source to Zone 2. The options I know of is to watch a digital source on the main zone, and then listen to any analog input on the Zone 2 Speakers.
stephanludik is offline
post #62 of 73 Old 06-06-2013, 10:24 PM
Hi All,
I am new to the forum so please bare with me. I have a Pioneer VSX-921-K (Eu Version). I want to know if it is at all possible to run the 921 with both bi-amp and Zone 2 enabled.
I have read the manual end to end and have found that the surr back outputs is used in both cases. Is it not possible to use the Front Height/Wide outputs for Zone 2. As I understand the Speaker B setup plays the same audio on both "zones" which is not what I want to do. I want to achieve a 5.1 bi amp system in my main zone, with independent audio in zone 2.
Any help or alternatives to achieve this will be greatly appreciated.
post #63 of 73 Old 08-30-2013, 03:50 PM
dagreek82's Avatar
Hi never done this before, but you guys are my only hope ( don't wanna be defeated )
I've got the pioneer vsx-921 k, I like to think I'm good at these things as I've been into it for a while, BUT ! This one is bugging me I only use this to play my ipad or iPhone great but when I connected it to my tv I'm getting no sound I've connected it through hdmi and nothing I've gone through the settings on the receiver (so I know the hdmi cable is ok) set it up for hdmi. And nothing !!! I've go through the manual about 20x been on the net for about 2weeks please HELP
dagreek82 is offline
post #64 of 73 Old 10-01-2013, 11:54 AM
pleibowitz's Avatar
This happened to me when I connected Apple TV to the receiver. Here is what Pioneer Customer support came back with to get it to work.
On Remote press Receiver, then Signal Select repeatedly until you get H for HDMI.
pleibowitz is offline
post #65 of 73 Old 12-18-2013, 04:22 PM
bjaurelio's Avatar
Liked: 32
I've had a VSX 921-K for a couple years now, and everything has been great so far. I recently purchased a new subwoofer. In running bass tests, I noticed that even with the crossover set to 80hz and my mains set to small I can hear my Def Tec SM350s playing notes all the way down to 35hz and feel the bass radiator moving at even lower frequencies. Even if I change the crossover to 200hz I can still hear my mains play lower notes. I've tried switching them back and forth between large and small. There is no difference. Is there any way to fix this? Is there some sort of setting I'm missing that allows them to bypass the crossover while set to small?
bjaurelio is offline
post #66 of 73 Old 12-22-2013, 01:19 AM
lewye's Avatar
MCACC settings How do I install from pc to avr with how cable
did not work with ethernet cable
lewye is offline
post #67 of 73 Old 12-22-2013, 03:11 PM
lewye's Avatar
please help
lewye is offline
post #68 of 73 Old 12-23-2013, 11:26 PM
lewye's Avatar
please help
lewye is offline
post #69 of 73 Old 03-19-2014, 10:23 PM
Snafu55's Avatar
Please explain exactly what you are trying to do. Are you trying to connect to the internet? or trying to connect Audio?
Snafu55 is offline
post #70 of 73 Old 08-13-2014, 01:55 PM
Liked: 0
Hi people,
I'm pretty new to av receivers and recently bought a second hand vsx-921k and connected it to my energy take classic 5.1 speakers. The analog inputs work great. It's a completely new experience to listen to music with them. But i have a problem connecting my pc to the receiver. I've plugged the hdmi cable to video 1 input and selected it as the source. Now i can hear the sounds, browse through MCACC menu, do the speaker configuration etc., but i have no other display on the screen. I can browse the video parameters menu on the screen of receiver but it won't show up on my lcd tv\monitor. when i change the resolution it'll show windows desktop for a brief moment and then will go black.
before you ask i tried the receiver at its old owners home. and it had no such problems there. how am i supposed to fix this? it's frustrating.
symptom is offline
post #71 of 73 Old 05-27-2015, 11:40 AM
Liked: 0
Newb needs help with set up please
Hi
Thanks for reading
Just bought a new lg 4 k 55 inch TV
Took the old system apart and then put wires back in what I thought was the same configuration.
Don't think I did because;
TV sound is out of sync with lips when playing Sky ,either live or recorded.
Next when I select Ariel on TV input I get picture but no sound
I have tried factory reset on amp and setting Hemingway as control.
I have as set up;
Sky dh box
Vex-921 amp
Lg 4k TV
Samsung blue ray player
Apple tv
All have Hdmi and optical
Could someone please guide me from scratch and talk me through where to connect each wire and what to do with amp settings
Thanks in anticipation
Steve
Cannondalerugby5 is offline
post #72 of 73 Old 01-14-2016, 07:11 AM
vickenp's Avatar
how to re assign HDMI inputs
Hi guys,
I'm got the receiver all working fine I have my hdmi output to a projector and 3 hdmi inputs
one for a bluray, one tv receiver box and one xbox
I can't figure out how to switch the inputs so that when I press the tv button for example on the remote, it knows to go to the hdmi input which is the tv receiver (hdmi2)
I can't figure it out in the manual any help please?
thx
vickenp is offline
post #73 of 73 Old 01-23-2017, 03:23 AM
Liked: 0
Pioneer VSX-921 EU version - 3rd times broken
Hello,
I have european version of VSX-921.
I bought it in 2012.
Unfortunately it was during all the time I have it 2 times in repair.
First was replaced: AMP-7 ASSY in 2014.
Next time was FRONT ASSY
Every time the fault was properly diagnosed by receiver (I mean on the display the proper MCACC light was flashing and the unit cannot be switched on).
But now I can't find the fault (but I know that my amp has broken for the third time). I have the service repair manual and operating manual. But in those two documents there isn't exactly the combination which I have now.
When I switch on the receiver, watch the (for example 2 hour) movie and switch it off - the receiver doesn't normally behave. It switch off but Advanced MCACC and HDMI lights are non-stop lit on the front panel, and I can't turn it on again. I must disconnect (take out) the cable from the electric socket and wait for a while to reset the amplifier. Then when I plug in it again the front panel all lights are off and I can turn it on (also the settings are gone - i must again do the MCACC calibration)
If I only knew what means that combination of ADVANCED MCACC and HDMI lights.
I'm hesitate to take the amp to repair because I know that probably will broke again in the near future. (so the 2 times of repair and now the third time wont' be enough probably; and when I count all the money which I spend on him - price of bought and 2 repairs and now the 3rd repair I will end with the sum of new model - but I rather wont buy next new Pioneer. They have made perfect amps until 2008- 9 From then I think they are making only garbage which will failure and need repairs like mine.
Please help me what should I do? What this error lights combination means?
Thanks for help
tonsilfan is offline
Pioneer Vsx921k 7 1 Channel 3d Ready Av Receiver Black
