Choices for 3 or 5 channel amp under $1k? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-08-2012, 07:16 PM - Thread Starter
AC2011's Avatar
Quoted: 108 Post(s)
Liked: 52
Hi - looking to buy a 3 (most likely) or 5-channel power amp, at least 150WPC and keep it under $1k.
Based on my searching, looks like Emotiva is about the only one that fits the bill if buying new.
What other choices might there be?
Boston Acoustics Classic series L/C/R + front presence; Fluance XLBP Bipole surrounds; 2 x PSA XS15se
Yamaha RX-A3040; 3 x Emotiva XPA-100; Emotiva BAS-X A500
Oppo BDP-103D
AC2011 is offline
post #2 of 7 Old 02-08-2012, 07:35 PM
jjackkrash's Avatar
Quoted: 932 Post(s)
Liked: 803
Three outlaw mono blocks would be pretty close to your budget and get you 200w per channel.
http://www.outlawaudio.com/products/2200.html
jjackkrash is offline
post #3 of 7 Old 02-08-2012, 07:57 PM
cmryan821's Avatar
Quoted: 194 Post(s)
Liked: 59
What speakers are you using and how loud do you listen? Is your receiver not cutting it or do you just want some new gear(not that there's anything wrong with that)? If your receiver really isn't supplying enough power then it's not likely that 150wpc will provide a great improvement.
cmryan821 is offline
post #4 of 7 Old 02-08-2012, 09:00 PM
johnson636's Avatar
Quoted: 212 Post(s)
Liked: 50
If you don't mind the look of pro amps, they offer lots of power at very reasonable prices. QSC, Peavey, Crown, and Crest are mentioned across different threads as be very respectable and trusted Brands. Or, you could just go with Emo's.
johnson636 is offline
post #5 of 7 Old 02-09-2012, 05:31 AM - Thread Starter
AC2011's Avatar
Quoted: 108 Post(s)
Liked: 52
My front soundstage is Boston Acoustics CS226 mains and CS225C center. Mains rated for up to 250W, center for 175W.
Don't listen at reference levels, but fair sized room (about 3,100 cubic feet). Everything sounds okay, but running 7.1 off a Yamaha RX-A800 (rated 95WPC), so thinking taking some of the load off the Yammie might make it all sound better, plus extend the life of the AVR.
Plus, I do love new gear
Oppo BDP-103D
AC2011 is offline
post #6 of 7 Old 02-09-2012, 07:26 PM - Thread Starter
AC2011's Avatar
Quoted: 108 Post(s)
Liked: 52
bump
Oppo BDP-103D
AC2011 is offline
post #7 of 7 Old 02-13-2012, 01:25 PM
cmryan821's Avatar
Quoted: 194 Post(s)
Liked: 59
To be honest, I think you should save up to get better speakers if you want a real improvement in sound quality. Additional amplification only results in better sound if your current listening levels are clipping your current amp. And since you don't listen at reference levels then I think it would be best to just save your money for now. I realize you may just want to upgrade something but it's not wise to put much more money into your electronics than your speakers.
All that said, if you still want an additional amp then look at the outlaw 2200 or emotiva xpa3. If you don't mind giving pro amps a try, give the crown xls1000 or qsc gx3 a look. If you don't mind used gear, then check out audiogon or videogon. Plenty of decent stuff there. Best of luck.
