New Receiver? with new 3D TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-16-2012, 03:29 PM - Thread Starter
trusaleen1's Avatar
Im looking for some guidance, im about to pull the trigger on an LG 55LW5600 3d on Amazon. When I remember that my receiver is several years old. I have an HK 247 receiver. I dont believe that its 3D compatible. Can anyone recommend a good budget 3d receiver. Sony????
Thanks for your help
trusaleen1 is offline
post #2 of 12 Old 02-16-2012, 03:30 PM
Tweaked05's Avatar
Quoted: 41 Post(s)
Liked: 26
Instead of getting a cheap receiver just for 3D, perhaps you could consider getting a BD player with dual HDMI ports. You could run one HDMI to your TV directly for 3D, and the other to your HK 247 for audio.
Tweaked05 is offline
post #3 of 12 Old 02-16-2012, 03:34 PM - Thread Starter
trusaleen1's Avatar
With that set up how would I run it for my cable tv? Cable video to TV and then audio to receiver?
post #4 of 12 Old 02-16-2012, 03:35 PM
Luisfc1972's Avatar
Quoted: 162 Post(s)
i would do what tweaked said but if you insist on budget receiver people like the Pioneer VSX-521-K 5.1
http://www.amazon.com/Pioneer-VSX-52...9431665&sr=8-1
Luisfc1972 is offline
post #5 of 12 Old 02-16-2012, 03:37 PM - Thread Starter
trusaleen1's Avatar
Ok guys thanks for the help, im just trying to see how I would connect everything for example, my cable box, my PS3, and a dual HDMI player. How would all those connections work on my current receiver so they could all play 3d?
post #6 of 12 Old 02-16-2012, 03:41 PM
Luisfc1972's Avatar
Quoted: 162 Post(s)
actually your ps3 slim can do 3d
post #7 of 12 Old 02-16-2012, 03:47 PM - Thread Starter
trusaleen1's Avatar
I do have the PS3 slim. But im still not sure how the set up would work. My cable box goes through my HK too.
post #8 of 12 Old 02-16-2012, 03:47 PM
Luisfc1972's Avatar
Quoted: 162 Post(s)
check out this thread
http://www.avsforum.com/avs-vb/showthread.php?t=1348030
post #9 of 12 Old 02-16-2012, 04:54 PM - Thread Starter
trusaleen1's Avatar
ok so it looks like I can run it through my ps3 for picture but not get true loss less sound because I have to connect via optical.
post #10 of 12 Old 02-16-2012, 05:10 PM
Tulpa's Avatar
Liked: 61
How many HDMI inputs does your TV have? If it's 3D, I assume it has at least two.
You can run one HDMI from a dual HDMI player to the TV for video, run the second to the receiver. Anything else can just run through the receiver like normal, and out to the TV. Two HDMI cables run into the TV, one from the player, one from the receiver.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #11 of 12 Old 02-16-2012, 05:17 PM
jdsmoothie's Avatar
Quoted: 12169 Post(s)
Liked: 5546
The PS3 cannot pass Dolby TrueHD with 3D video. You can connect the PS3 (HDMI) to the TV with optical to the AVR. It's doubtful you can tell the difference between lossless audio and the higher bitrate DD/DTS on BDs over optical.
jdsmoothie is offline
post #12 of 12 Old 03-04-2012, 01:02 AM
gogo_vs's Avatar
I would keep the old receiver and use HDMI for video (BD,PS3,...->TV) and optical/coaxial for audio (BD,PS3,...->Receiver) or am I missing something?
Is there a diferrence in audio quality/delay if you use optical/coaxial over HDMI?
gogo_vs is offline
