Simple question about AMPS vs receivers for multiple zones. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-17-2012, 01:50 PM - Thread Starter
sullender's Avatar
I have a Sony receiver that will do an A and B zone from the same source. I want to add two more sets of speakers on to this system - all to play the same source. What is the cheapest way to do this? The two sets of speakers already have volume controls built in to the wall.
Any simple recommendation?
sullender is offline
post #2 of 9 Old 02-17-2012, 02:01 PM
jdsmoothie's Avatar
Quoted: 15331 Post(s)
Liked: 7484
Is it set up as Front A/B (any source will play to both A/B) or main zone/Zone 2 (only analog to Zone 2)? To add additional zones playing the same source you can add a multi zone impedance matching speaker selector which are available from 2-8 additional zones.
jdsmoothie is online now
post #3 of 9 Old 02-20-2012, 07:35 AM - Thread Starter
sullender's Avatar
How would I know the answer? I know if I play something in 5.1, to get it to go to the other zone, you have to change it to 2 speaker analog output. Which do I have?
post #4 of 9 Old 02-20-2012, 07:42 AM
jdsmoothie's Avatar
Liked: 7484
Sounds like the Sony has Zone 2 preouts which must be connected to an external 2CH amp? What model do you have?
post #5 of 9 Old 02-22-2012, 05:15 PM - Thread Starter
sullender's Avatar
It is the STR DE895. What do you recommend?
post #6 of 9 Old 02-22-2012, 07:03 PM
jdsmoothie's Avatar
Liked: 7484
So then the receiver has Front A and Front B speaker posts, both sets sharing the same amp so when you run A+B you're effectively cutting the speaker impedance of the 4 speakers in half, requiring a lot more power then for the same volume level of just 2 speakers. And it doesn't look like there are Zone 2 preouts so your best bet is to get another receiver to power the speakers in those other rooms.
post #7 of 9 Old 02-23-2012, 06:32 AM - Thread Starter
sullender's Avatar
Do you mean replace the Sony? Or just by another amp to power the other zones?
post #8 of 9 Old 02-23-2012, 06:42 AM
jdsmoothie's Avatar
Liked: 7484
The Sony is not designed to run multiple zones so I'm suggesting either getting another AVR for those other zones, connecting a separate music source to it, and using the Sony in it's current configuration, or getting a Zone 2 AVR with Zone 2 preouts and use it as your main AVR and connect the preouts to the Sony to power the additional 2 zones.
post #9 of 9 Old 02-23-2012, 07:09 AM - Thread Starter
sullender's Avatar
Thanks. Appreciate the input
