Yamaha RX-V3900 help please ! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-18-2012, 09:16 PM - Thread Starter
kttealow1's Avatar
I am running HDMI from set top box into RX-V3900 - pass through works great. Up-scaling works great when unit is powered on.
Here is the question. Is it possible and if so what are the correct settings for:
Viewing (On the Display) set top box signal with the RX-V3900 power on and also listening to USB / Net all in the same "Zone"?
Example : Watch the basketball game while listening The Eagle Classic Rock
Hope someone has a answer - prior to running the set top box through the Yamaha - I could do this, obviously, no problem - but now can't do it. If I am watching the television and than select the USB / Net button yes I do hear the music but loose the television picture.
Thank you for any help you can over!
kttealow1 is offline
post #2 of 2 Old 02-18-2012, 09:52 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
You can't listen to an audio only source while switched to a video source. I realize past receivers allowed this, but the feature seems absent with newer models.
I know there's a reason of sorts, but I would have to think about why the change was made (you could accomplish it maybe by using zones, with another set of speakers.)
"But this one goes up to 11"
MichaelJHuman is offline
Yamaha Rx V3900bl Receiver
