Help - Echo in speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 02-19-2012, 02:42 PM - Thread Starter
blaine84's Avatar
Hi, thanks for reading my post.
I am experiencing an echo on lower frequency sounds. For example, if music is playing on a movie, I'll hear the bass normally, then about two beats later, I'll hear it echo at a lower volume.
I have the cable box and xbox connected to a Pioneer VSX-821 via HDMI cables, and a single HDMI cable running out of the receiver to the TV. Suggestions are appreciated.
blaine84 is offline
post #2 of 17 Old 02-19-2012, 03:04 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Never heard of that. What kind of speakers do you have?
what sound mode are you using on your receiver?
Afro GT
afrogt is offline
post #3 of 17 Old 02-19-2012, 03:27 PM
turbobuick86's Avatar
Are the TV speakers playing along with your stereo/surround?
turbobuick86 is offline
post #4 of 17 Old 02-19-2012, 03:34 PM
hughh's Avatar
Quoted: 34 Post(s)
Liked: 39
Exactly what I thought when I saw his post.
hughh is offline
post #5 of 17 Old 02-19-2012, 07:50 PM - Thread Starter
blaine84's Avatar
TV speakers are disabled. I have 2 floor speakers, a center speaker, and 2 rear shelf speakers. I hear the echo no matter what mode the receiver is in.
blaine84 is offline
post #6 of 17 Old 02-19-2012, 08:10 PM
hughh's Avatar
Quoted: 34 Post(s)
Liked: 39
Try adjusting the sound in the cable box menu and see if that takes care of it.
hughh is offline
post #7 of 17 Old 02-19-2012, 08:15 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Doesn't sound like a speaker related problem...
"But this one goes up to 11"
MichaelJHuman is offline
post #8 of 17 Old 02-19-2012, 08:20 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Maybe the L/R surround delay setting is too high...
Just my $0.02...
M Code is online now
post #9 of 17 Old 02-19-2012, 08:39 PM
Quoted: 266 Post(s)
Liked: 148
Just my $0.02...
That seems like a good guess. On my receiver, there's a speaker distance setting for each channel. What that really is, is an audio delay. If that's not set properly you could definitely experience an echo.
post #10 of 17 Old 02-19-2012, 09:29 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Lifted from the Dolby standards....
"The Dolby specification is 15ms and the product should allow delay adjustment of 0-15 ms for the surround channels, in steps of 1 ms or less. Steps of 1 ms are recommended. As indicated previously, the adjustment may be provided using speaker distance information..."
Another thought...
If set by the Room EQ S/W there could have been an error during the setup routine..
Just my $0.02..
post #11 of 17 Old 02-19-2012, 09:38 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
1 more thought..
Many users are unaware that also when in Dolby True Audio the L/R fronts have a Time Delay applied as well..
"Front Time Delay
If adjustable surround delay time is included, the product should provide delay adjustment of –2 to +7 ms for the front channels, in steps of 1 ms or less. Negative delay adjustments are used for front channel outputs that are farther away from the listener than the L and R speakers (allowing them to respond ahead of other front channels to compensate for their physical positions).... "
Just my $0.02...
post #12 of 17 Old 02-21-2012, 06:21 PM - Thread Starter
blaine84's Avatar
Thanks for the suggestions. My delay was originally set to 0ms. When I changed it to 1ms, the echo disappeared. I don't understand why, but it worked!
blaine84 is offline
post #13 of 17 Old 02-21-2012, 06:44 PM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 460
I don't understand either. 1ms is too short an interval to be discerned as an echo.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #14 of 17 Old 02-21-2012, 06:47 PM - Thread Starter
blaine84's Avatar
You're right, the echo I heard was more than 1ms. It was more like half a second. If a song ended abruptly, I would generally hear the last two beats of the song echo. If a deep voice stopped talking, I would hear the last couple of words again, only muffled a bit.
blaine84 is offline
post #15 of 17 Old 04-22-2012, 04:44 PM
bozobuttz's Avatar
Hi blaine84, I'm having the same problem with my new Pioneer Elite VSX-40 receiver. You mentioned you have 5 speakers (no subwoofer). I also do not have a subwoofer and in the setup I have Subwoofer set to NO and my mains (L+R) set to LARGE. I found if I set Subwoofer to YES, the echo goes away! However, this is not a feasible solution since the LFE channel is not redirected to the LARGE L+R speakers. Could you tell me which setting you adjusted to get rid of the echo?
bozobuttz is offline
post #16 of 17 Old 04-22-2012, 07:07 PM - Thread Starter
blaine84's Avatar
I changed S.Delay from 0.0 to 0.1.
blaine84 is offline
post #17 of 17 Old 04-22-2012, 07:57 PM
bozobuttz's Avatar
Thanks, that seems to have done the trick! I also had to set it individually for each input.
