Recommended Receivers?? - AVS Forum | Home Theater Discussions And Reviews
Old 02-19-2012, 09:22 PM - Thread Starter
roddymac's Avatar
I've got a dedicated theatre room in a new home construction and I am looking for some input on receivers. So far, I have Sonance LCRs and subwoofers making up 9.2 surround. My projector is the JVC DLA-RS65. I haven't decided on a screen, but have room for between 100-108". I also haven't decided on a receiver to power this beastly set up either.
Any recommendations are welcome! Cheers!
R
roddymac is offline
Old 02-20-2012, 08:54 AM
wxthomson's Avatar
You may want to look at the Onkyo 5009. Lot of features for the money.
wxthomson is offline
Old 02-20-2012, 11:54 AM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
For about 1/2 the price get the Denon 4311.
kikkenit2 is offline
Old 02-20-2012, 01:07 PM
Davecraze's Avatar
Quoted: 158 Post(s)
Liked: 55
Either the Onkyo 3009 (has 99% of the functionality of the 5009 at 60-70% of the cost) or the Denon 4311 (as mentioned).
If you really want to spend Onkyo 5009 type of money, I would still do the 3009 and then power the front three LCR with an Emotiva XPA-3.
This later choice assumes that you are running the Sonance LCR Cinema Ultra 1 or 2 across the front three. If it is the non-Ultra Sonance LCR Cinemas, or any other Sonance inwall model, any decently powered higher end AVR will push them to very loud levels without a separate amp.
Davecraze is offline
