Burr Brown 32 bit DAC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 79 Old 02-20-2012, 10:12 PM - Thread Starter
sx460's Avatar
Quoted: 18 Post(s)
Send a message via Skype™ to sx460
Hi There,
Looking at Integra Receivers I noticed that the 80.3 sports 32 bit Burr Brown DACs. This is the first I've heard of these. I'm familiar with their 24 bit DACs. What is everyone's take on their 32 bit offering. Is it superior/offering noticeably better sound quality? Does anyone know of other receivers sporting these DACs?
Matt
sx460 is offline
post #2 of 79 Old 02-21-2012, 12:19 AM
gurkey's Avatar
Quoted: 252 Post(s)
Liked: 148
Onkyo TX-NR 5009, PR-SC 5509.
A 32-Bit DAC might be technically better, but if it really improves anything audibly against a 24-Bit DAC is not clear.
gurkey is offline
post #3 of 79 Old 02-21-2012, 07:51 AM - Thread Starter
sx460's Avatar
Quoted: 18 Post(s)
Thanks for the info. What's your take on Burr Brown DACs versus other brands? What are some other good choices?
sx460 is offline
post #4 of 79 Old 02-21-2012, 09:48 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
Burr Brown was purchased by TI some time back, so Burr Brown is TI brand name now.
There are a number of companies who make DACs. Cirrus comes to mind. Wolfson another brand. Analog Devices as memory serves.
I am sure they all make perfectly good DACs. There's different models from each manufacrturer, one of the differences being the SNR. You would need to know exact model numbers to know which exact DAC is in any given unit.
It's rather difficult to compare DAC chips directly...I have never seen any test I would call valid.
Personally, I don't worry about it.
"But this one goes up to 11"
MichaelJHuman is offline
post #5 of 79 Old 02-22-2012, 12:21 AM
Kilian.ca's Avatar
Liked: 37
The Integra and Onkyo 5009 have PCM1795 32/192 DAC from 2009 (not that new). A quick look at the following shows the SNR isn't the highest in 32-bit DACs and some 24-bit DACs have higher SNRs. My understanding of SNR is anything above 100dB or 110dB isn't really distinguishable so SNR isn't really that important, or the most important consideration. The 32-bit only means it accepts 32-bit input, not any implication of SNR at all. Being 32-bit is certainly not in my list of priority when picking AVR but that doesn't stop Oppo fans getting excited by the 32-bit Sabre. Other things could matter more - have a look at the data sheet.
SNR:
PCM1791 24-bit 192kHz 113dB
PCM1792A 24-bit 192kHz 132dB
PCM1793 24-bit 192kHz 113dB
PCM1794A 24-bit 192kHz 132dB
PCM1795 32-bit 192kHz 123dB
PCM1796 24-bit 192kHz 123dB
PCM1798 24-bit 192kHz 123dB
PCM5100 32-bit 384kHz 100dB
PCM5101 32-bit 384kHz 106dB
PCM5102 32-bit 384kHz 112dB
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #6 of 79 Old 02-22-2012, 04:37 AM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
Is it true than that denon is using lowend DACs in the 4311 ?
AK5358B dac S/N: 102dB
Does this mean more hiss when the volume is turned up ?
joehonest is offline
post #7 of 79 Old 02-22-2012, 07:40 AM - Thread Starter
sx460's Avatar
Quoted: 18 Post(s)
This is a good discussion and is helping me understand. One question: my understanding is that the DACs are responsible for taking the a digital stream and converting to an analog stream to feed the amplifier. SNR is one thing, I would understand this as the DACs' efficiency. Maybe this isn't the right way to look at it however isn't there any way to measure accuracy? And also wouldn't some DACs create different sounds (warm vs harsh) etc? It just seems to me that it would be a very important component in dictating sound quality. Am I putting too much emphasis on the DACs?
sx460 is offline
post #8 of 79 Old 02-22-2012, 07:52 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
Bump. I am wondering the same thing? What causes the difference in SQ between dacs that have similar or the same specs, such as 24/196 or 24/96? If two dacs use the same chip that is rated at 24/96, shouldnt they both sound the same? What I am wondering is, what makes a really expensive or good dac, sound different from a cheaper dac that has similar specs?
Martycool007 is offline
post #9 of 79 Old 02-22-2012, 08:15 AM
Quoted: 266 Post(s)
Liked: 151
Accuracy on DACs would likely be measured as THD (total harmonic distortion.) The THD figures on DACs are well below THD levels considered to be audible.
If the distortion is inaudible, and their measured frequency response is ruler flat (as would be expected) then it's not clear why they would sound anything other than non neutral (not saying they could not have some chracteristic sound, but I would not expect that.)
I would hope by now the problems inherent in creating a properly behaving DAC were solved long ago.
post #10 of 79 Old 02-22-2012, 08:35 AM - Thread Starter
sx460's Avatar
Quoted: 18 Post(s)
OK, now I've got to ask the obvious: if all DACs act/sound the same then why are there so many different models? Even Burr Brown/TI offer many different models of DACs (and at different price points) and beyond them there are other companies that make DACs.
sx460 is offline
post #11 of 79 Old 02-22-2012, 08:41 AM
Theresa's Avatar
Liked: 51
The difference between DACs is vanishingly small. In a properly functioning system noise and distortion is inaudible except when one's ear is pressed to a tweeter. MiniDSPs for instance have a signal to noise ratio of just under 100db but unless there is a gain matching problem that noise is inaudible. A device with a SNR over 100db is indistinguishable from one with a 120db SNR. As someone here has said "just because it can be measured doesn't make it audible."
Theresa is offline
post #12 of 79 Old 02-22-2012, 09:02 AM
Nethawk's Avatar
Liked: 119
Slightly off topic, but now that I've connected my PC to a 2 channel receiver I've been curiously puzzled why I see so many references to external (and often expensive) DACs. My onboard sound card has DACs, my receiver has DACs. Am I looking at this wrong?
Nethawk is offline
post #13 of 79 Old 02-22-2012, 09:33 AM - Thread Starter
sx460's Avatar
Quoted: 18 Post(s)
Nethawk this is a great point. I've seen this before as well and am trying to tease this out. Since it can be quite expensive to have an external DAC and if all DACs are created equal what is the value of an external DAC?
sx460 is offline
post #14 of 79 Old 02-22-2012, 09:33 AM
Quoted: 266 Post(s)
Liked: 151
Only discussion I ever had on this with any references to measurements which made sense to me was that SNR could make a difference.
How 100 vs 110 or 120 could make a difference, I forget, because typical dynamic ranges when listening are narrower than 100 dB.
post #15 of 79 Old 02-22-2012, 09:59 AM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
DACs maybe just for golden ears or poets,(these are the same people that write about wine and cigars) But every new issue of stereophile mag has something to say about all these new high priced black boxed dac add-ons, for the rich and soon tobe poor if they keep buying this BS.
post #16 of 79 Old 02-22-2012, 10:06 AM
Theresa's Avatar
Liked: 51
Yes, my Essence STX sound card has interchangeable DACs and I've never been moved to try different ones. The noise floor with the stock one is below my hearing threshold.
Theresa is offline
post #17 of 79 Old 02-22-2012, 11:21 AM
DonH50's Avatar
Quoted: 2120 Post(s)
Liked: 1689
Audible differences among DACs, unless the noise floor is very high, are more likely due to the distortion spectrum, which is related to their (differential and integral) linearity curves. You might see something in the ENOB, THD, IMD, or DNL/INL plots if you know what to look for, but by and large the average consumer does not have the background to read and understand all the techie details.
In terms of a DAC in a box, what most audiophiles mean by "DAC", the output buffers, power supply, and board design probably have more influence than the actual DAC chip itself.
All IMO, of course. - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #18 of 79 Old 02-22-2012, 11:30 AM
Theresa's Avatar
Liked: 51
I can interpret THD and IMD but the rest are foreign to me. The only things I see in most discussions of the various audio qualities of DACs has been totally subjective and soaked in snake oil.
Theresa is offline
post #19 of 79 Old 02-22-2012, 11:57 AM
Quoted: 266 Post(s)
Liked: 151
Can you explain simply how ENOD adds to knowledge gleaned from THD and noise specs? Does it tell us something more or is it just another way to view the information on signal distortion?
I understand that converting a quantized signal to analog is non trivial - the method must not only smooth out the steps in the signal, but also not introduce any audible artifacts. But I thought I have seen scope images of post DAC output which looked rather smooth so I presumed that they do a very good job.
I also seem to recall, there's the possible clocking issues.
post #20 of 79 Old 02-22-2012, 01:48 PM
DonH50's Avatar
Liked: 1689
The effective number of bits (ENOB) includes all error sources (per the IEEE ADC Standard) so encompasses noise and all nonlinearity. It is derived from SINAD, the signal-to-noise-and-distortion ratio. Humans are generally more sensitive to IMD than THD or noise. DNL/INL are d.c. measurements that effectively determine the best the DAC will ever do. If your INL has a pattern (curve) and is more than an lsb, you'll lose a bit. Then you add noise and dynamic errors (distortion, jitter, etc.) and lose more bits...
The curves on a scope probably look smooth due to resolution and filtering. By eye, a mid-frequency 6-bit sine wave looks smooth. For that matter, most high-speed scopes only reach about 6 ENOB from their 8-bit converters (ADCs). By eye, about 1% is good enough to look perfect, and that's about the 7-bit level.
There are a myriad of issues, clocking among them...
post #21 of 79 Old 02-22-2012, 04:17 PM
Quoted: 266 Post(s)
Liked: 151
Thanks, I will try to fully assimilate your answer
post #22 of 79 Old 02-22-2012, 08:46 PM
DonH50's Avatar
Liked: 1689
Oh, now we're bringing the Borg into this discussion?
post #23 of 79 Old 02-22-2012, 09:53 PM
Quoted: 266 Post(s)
Liked: 151
heh
post #24 of 79 Old 02-23-2012, 06:30 PM
Bob7145's Avatar
Liked: 36
Funny, this article was repeated on NPR today.
http://www.npr.org/blogs/13.7/2012/0...e-what-we-like
"Maybe the evolutionary psychologists are right and our preferences are really complicated strategies to display wealth and win sexual partners."
Bob7145 is offline
post #25 of 79 Old 02-23-2012, 06:43 PM
jjackkrash's Avatar
Quoted: 952 Post(s)
Liked: 820
Take out the "maybe" and I'd agree with this statement.
jjackkrash is online now
post #26 of 79 Old 02-23-2012, 07:45 PM
Quoted: 266 Post(s)
Liked: 151
Obviously that plays a role in how we operate. But I think humans go beyond the basics of food and reproduction. We create works of art and science that I feel exceed those things.
post #27 of 79 Old 02-24-2012, 01:39 AM
Kilian.ca's Avatar
Liked: 37
This thread isn't about external DAC nor evolutionary biology so that is off-topic. As usual every DAC thread on AVS can't stay on track and civil and eventually turns sideways and into condescending remarks at the mild end or insults and personal attacks at the nastiest. They just can't help it somehow. If some people really think owning an external DAC is about wealth and sex they have a problem. MJH is a DAC sceptic but at least to his credit he is usually capable of engaging in a civilised conversation without an attitude towards others here.
post #28 of 79 Old 02-24-2012, 01:56 AM
Theresa's Avatar
Liked: 51
I would just say that while there are differences between DACs, the difference is subtle. People are led to think that there are great differences. I don't think all external DACs are a waste of money as that subtle difference is of great importance to some. The Burr Brown (TI) 32 bit DACs are about as good as any IMHO.
Theresa is offline
post #29 of 79 Old 02-24-2012, 05:51 AM
DonH50's Avatar
Liked: 1689
In case the above tirade was directed at my posts, I must clarify that all DACs, whether in an AVR or an external box, do require power supplies, output buffers, and other supporting components, and are placed upon a circuit board, all of which can affect the sound. Or not -- you must decide.
Also, 6 bits looks smooth to the eye but the eye is not the ear. A perfect 6-bit DAC would have SNR around 38 dB and spur floor around 54 dB. At full scale even those numbers might not be audible, but as the signal level drops the relative SNR degrades.
Perhaps the biggest factor is the type of filtering applied, both in the digital domain and at the analog output. The relatively low sampling rate and steep high-order analog filters smeared the pulse response of early DACs (and ADCs). Oversampling has mostly fixed that problem, though a look at most any review with a pulse response will show the ringing added by digital filters before the DAC.
Finally, the shape (frequency spectrum) of the noise floor may also impact the sound. I cannot say if it really does or not (you must listen for yourself), but different DAC architectures do have different noise spectra, and some may be more objectionable (or us more sensitive to them, take your pick).
FWIWFM - Don
post #30 of 79 Old 02-24-2012, 06:03 AM
Theresa's Avatar
Liked: 51
I apologize if what I posted came across as a tirade. The spirit behind the words was conciliatory. I just wanted to say that I didn't believe there were no differences between DACs.
Peace.
Theresa is offline
