2112ci w/polk RTi A5 (right speakers for me?) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-23-2012, 07:46 PM - Thread Starter
silam's Avatar
Hi -
I'm building out my sound system and wanted to gather some advice. Right now I'm leaning towards a denon 2112ci AVR paired with polk rti-a5s and a csi a4. I'm going to fill out the rears shortly but I didn't see a good enough deal and to bite right now. I'm in the process of sub research.
The theatre will be used for 70% movie 30% music.The room size is a little tough. Roughly 14x18 but TV might be angled so wouldn't have the full length and width for sound. I listened to them in store and they sounded great, but this is my first venture into nicer sound, so I don't have a lot to compare (I think I'd need more time than in store).
Are there any suggestions you'd make for the setup, or specifically for the speaker package? Thanks in advance.
silam is offline
post #2 of 4 Old 02-23-2012, 08:15 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
I like Polk speakers. I personally think speakers are hard to recommend because (a) it's hard to audition them and pick out flaws and (b) as no speakers are perfect (that I know of) they involve compromises, so perhaps it's mostly a personal preference.
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 4 Old 02-24-2012, 09:21 AM - Thread Starter
silam's Avatar
Will there be any issues with clipping etc due to power difference? The avr is <100w per channel and the speakers are 20 - 200. I'm not sure if more power is needed to prevent clipping.
Any other thoughts would be helpful as well!
silam is offline
post #4 of 4 Old 02-24-2012, 09:48 AM
tvuong's Avatar
Quoted: 1769 Post(s)
Liked: 1061
You will be fine with the 2112/polk combo unless you drive the 2112 with 4ohm load speakers.
tvuong is online now
