Amp/Reciever for JBL ScreenArray HT (denon, crown) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-24-2012, 01:23 PM - Thread Starter
xevious99's Avatar
I'm trying to design a basement home system based on JBL pro gear.
I'm planning on using JBL-3678 for the LCR and 4x 8320's for the surround. If If can find a used 4645c or 4642a I'll use that for the sub.
I'd like to use a Denon 3112 reciever, and run the 3678's biamped.
I'm trying to figure out: how far do I need to go in the amplifier department? I could theoretically get just one for the sub and run everything else off the reciever, or I could go as far as Crown DSI-1000's x 2 for the surrounds and x4 for the LCR and sub. Perhaps an intermediate would be an Emotiva 5-channel out and one DSI 2000 for the sub.
Do I need a separate crossover? Don't the DSI's have that built in?
Is there a way to use DSI-1000's for the HF and 2000's for the LF? That would be a more efficient use of the amps, but I'm imaging I would definitely need a crossover then.
Thanks for any advice! Xev
xevious99 is offline
post #2 of 3 Old 02-24-2012, 02:15 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
How big are those LCRs? Just curious.
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 3 Old 02-24-2012, 02:19 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 421
JBL-3678
Dimensions:
Height: 40.125" (w/horn)
Width: 25.625"
Depth: 11.5"
15" Woofer & horn tweeter.
Just my $0.02..
M Code is offline
