Technics SH-AC500D Issue - AVS Forum | Home Theater Discussions And Reviews
Old 02-24-2012, 03:26 PM - Thread Starter
aerial_22's Avatar
I am having an issue with my my Technics SA-AX6/SH-AC500D setup. When I initially turn on my TV and then my receiver and digital sound processor I get a lot of popping coming from my speakers. I have to keep adjusting the overall output level on the digital processor until the problem finally goes away. This issue only occurs at start-up. Once the system has been on the problem never occurs again. If I turn everything off and come back later in the day it will repeat the same issue. It seems to primarily happen on digital input 1 that is connected to my Tivo box via an optical cable. It only happens when I am connected to a digital souce. This never happen when I use the tuner to listen to the radio. Any thoughts on what could be causing the issue?
aerial_22 is offline
Old 02-27-2012, 12:22 PM - Thread Starter
aerial_22's Avatar
Bump for reply. Any suggestions would be great!
Old 02-27-2012, 01:25 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
It sounds as if you have a bad chip or maybe a bad solder joint somewhere in the digital processor circuitry. That may be a tough one for a technician to find.
If you are lucky, maybe it will get more persistent, which should make troubleshooting easier.
commsysman is offline
Old 02-27-2012, 02:49 PM - Thread Starter
aerial_22's Avatar
Thanks commsysman! I was kind of thinking something along those lines. I found an article on line with a similar issue that ended up being a bad capacitor. I have a technician I work with that restores old A/V equipment on the side. I may take it to him and have him take a look at it for me.
