Help me avoid buying a piece of junk - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 02-25-2012, 10:05 AM - Thread Starter
SPL2Alan's Avatar
I need a 100w/channel @ 8ohm power amp. Other than that, I don't really care. I just want something that is going to last a while. Sound quality is not terribly important to me at this point. If I get something that doesn't sound so great, I can always upgrade later. On the same token, I don't want some static-y 300 mile away radio station quality of sound either.
I know from my days in car audio that a PYLE or a PYRAMID amplifier pretty much spells garbage.
Can you help me steer clear of those kinds of components in home audio?
SPL2Alan is offline
post #2 of 14 Old 02-25-2012, 10:14 AM
RaggedEdge's Avatar
Quoted: 14 Post(s)
Budget?
Alex
RaggedEdge is offline
post #3 of 14 Old 02-25-2012, 10:19 AM - Thread Starter
SPL2Alan's Avatar
Originally Posted by RaggedEdge View Post
Budget?
Just for the sake of argument lets say 200-300.
I can afford a lot more than that, but realistically if this is just for background music in the kitchen, I don't think I need a 3000 dollar amp.
SPL2Alan is offline
post #4 of 14 Old 02-25-2012, 10:37 AM
RaggedEdge's Avatar
Quoted: 14 Post(s)
Pioneer VSX-821-K will do everything you need.
Alex
post #5 of 14 Old 02-25-2012, 10:42 AM - Thread Starter
SPL2Alan's Avatar
Not that i'm getting picky, because for that price range I know that I can't be, but I thought it would be cheaper getting a power amplifier as opposed to an a/v receiver.
SPL2Alan is offline
post #6 of 14 Old 02-25-2012, 10:50 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4781
Pretty good value in avrs at your price point, in integrated amps not so much. Depends on the quality you want. Why do you want 100w/ch? What speakers are you driving?
lovinthehd is offline
post #7 of 14 Old 02-25-2012, 10:56 AM - Thread Starter
SPL2Alan's Avatar
http://www.amazon.com/Polk-Audio--Ce...196078&sr=1-20
Those are what I was looking at. Not that i'm going to need to drive a full 100W to them anyway, but I had figured better to have full power and not use it all.
Again, the sound quality is not hugely important, so if you have suggestions i'm all ears. (eyes)
SPL2Alan is offline
post #8 of 14 Old 02-25-2012, 11:05 AM
BullishDad's Avatar
The Pioneer VSX-821K can be had for $180 at Newegg this weekend in case you hadn't seen that.
Cablevision - Explorer 8300HD- SARA
Western Digital 250 gb (WD2500KS)
BullishDad is offline
post #9 of 14 Old 02-25-2012, 03:41 PM
mannoiaj's Avatar
Take a look at this amp, it should drive those speakers well.
Dayton Audio APA150 150W Power Amplifier
mannoiaj is offline
post #10 of 14 Old 02-25-2012, 05:42 PM
walbert's Avatar
Nope. Economies of scale and all that - stand-alone power amplifiers are a low-volume item; they can get absurdly expensive for something incredibly basic. The cheapest multi-channel power amplifier I'm aware of is around a grand; there's plenty of AV receivers less than that. Sure, you can pay more for less and tell yourself you're "not wasting money on features you don't need!" but the reality is; you're paying more to get less.
The Dayton isn't a bad choice, neither are a lot of cheap stereo receivers from Sherwood, Sony, and so on - the Pioneer (or some other AVR) will have substantially more features and widgets for (roughly) the same money. Just for grins, you could even run the room-correction after the fact; would probably help to be quite honest.
walbert is offline
post #11 of 14 Old 02-25-2012, 05:50 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
Behringer A500 is about the cheapest respected stereo amp I know of. It's more than 100x2 into 8 ohms, but it's not bad to have a bit more than needed.
"But this one goes up to 11"
MichaelJHuman is offline
post #12 of 14 Old 02-25-2012, 06:06 PM
Nethawk's Avatar
Liked: 119
Two good deals in this price range at Audiogon:
NAD 2400PE
B&K ST140
I would personally choose a receiver and expand your options for future. I have an Onkyo TX-8050 2 channel receiver with built in network streaming services that we just love. Currently running about $260.
Nethawk is offline
post #13 of 14 Old 02-25-2012, 08:14 PM - Thread Starter
SPL2Alan's Avatar
Kind of odd they don't even show a rating for 2x (watts) @ 8 ohms,
but if it's stable at 4 ohms in 2 channel, it must be stable at 8 ohms.
Found it for 199 on Amazon.
SPL2Alan is offline
post #14 of 14 Old 02-26-2012, 06:46 AM
ccotenj's Avatar
Liked: 101
just as a suggestion...
someone has a pio a35r in the classified for 125 clams...
clicky
no, it's not mine... but i do have one, and have used it for many different things... nice little unit, and 4 ohm stable...
- chris
ccotenj is offline
