Setting up zone 2 on yamaha rx-a800 help needed!! - AVS | Home Theater Discussions And Reviews
Old 02-26-2012, 01:51 PM - Thread Starter
tc51's Avatar
So i just purchased some B&W M1s to use for a 2.0 system for my music. I wanted to connect them to the zone 2 on my receiver and play my cds through my sony Blu ray player. I hooked everything up, selected the 7.1 + zone on my receiver settings and popped in a cd and nothing. When i turn the zone on it says input dock, which is confusing since i don't have a dock. Then i read that you need audio cables going from the source into the receiver, but there is no input for the zone only outputs. Just wondering if what I'm trying to do can't be done or I'm missing something, any help would be appreciated!
Tom
tc51 is offline
Old 02-26-2012, 02:18 PM
JChin's Avatar
Quoted: 177 Post(s)
Liked: 151
Hi tc51, Zone 2 can only player analog audio so connect a set of RCA cables (red & white) from BD player to either AUDIO-1 or AUDIO-2.
JChin is offline
Old 02-26-2012, 03:27 PM - Thread Starter
tc51's Avatar
Do i need to change any settings on the receiver?
tc51 is offline
Old 02-26-2012, 04:18 PM
UndersAVS's Avatar
Quoted: 18 Post(s)
Liked: 35
Set the receiver input selection on your remote control to the corresponding RCA input that you have the Blu-ray player connected. That's it. Easy peasy.
UndersAVS is offline
Old 02-26-2012, 04:42 PM - Thread Starter
tc51's Avatar
Is there anyway to keep the onscreen display of the blu ray player? When i change the output it just goes to the receivers default picture
tc51 is offline
Old 02-26-2012, 05:54 PM - Thread Starter
tc51's Avatar
Got it!!! took a little playing around with the settings but i finally figured it out thanks for the help guys!
tc51 is offline
Yamaha Rx A800 7 1 Channel Audio Video Receiver Black
