Opinions on replacing Denon 4306 being asked for. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-27-2012, 07:31 PM - Thread Starter
nameneeded's Avatar
So here's the scoop...
My Denon 4306 that I've had for 5+yrs from new has recently died. Well sort of.
It seems it needs a new digital board of some sort and will cost $700cnd to fix. So should I get it fixed or replace it. The sad part is at this time I can't spend more than the repair or at least be very close.
Important feature my Denon had that is a must have is 7.1 analog in as I am using a couple of tube processors for fuller sounds.
nameneeded is offline
post #2 of 5 Old 02-27-2012, 08:38 PM
Briant73's Avatar
Quoted: 28 Post(s)
Possibly the Denon 4311ci, I believe it has 7.1 ext in, though you may want to check the Denon thread to make sure about that.
Briant73 is offline
post #3 of 5 Old 02-27-2012, 10:01 PM - Thread Starter
nameneeded's Avatar
Thanks but like I mentioned currently need to keep things around $700. I don't think I will ind a 4311 for that little unless it to is broken.
post #4 of 5 Old 02-28-2012, 07:36 AM
Briant73's Avatar
Quoted: 28 Post(s)
Whoops missed that, yeah lowest you can find the 4311ci is about 600 more than your budget amount.
Briant73 is offline
post #5 of 5 Old 02-28-2012, 04:25 PM - Thread Starter
nameneeded's Avatar
So thinking either MArantz SR6006 or Onkyo NR809. Thoughts?
