Audio Return Channel (ARC) Only passes 2 Channel LPCM Stereo from TV to AVR? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 43 Old 07-26-2012, 12:16 PM
DonoMan's Avatar
Originally Posted by jdsmoothie View Post
I actually asked a Panasonic rep a few weeks ago whether a smart app DD 5.1 audio signal would pass as DD 5.1 over HDMI (ARC) or wether it would downmixed to 2.0 and was told 2.0 over HDMI and 5.1 over the optical audio output. Now today, another rep tells me it will indeed pass over the HDMI(ARC) as DD 5.1 or DD+ ... so 1 for, 1 against. Your best bet is to get an owner's confirmation in the ST50 or VT50's Owner's thread.
DD, maybe, but definitely not DD+. S/PDIF only supports 2-ch PCM, normal AC3, and normal DTS. It is common that S/PDIF interfaces on TVs only do the 2ch PCM thing because of simplicity reasons - HD audio signals would have to be modified to reencode as plain AC3 or DTS, or to strip the AC3 "core" out of the Enhanced AC3 standards, for example. It seems a bit half-ass to me, but it's also not a big deal in my personal opinion...
I agree with you guys that ARC isn't really that necessary. It can eliminate 1 S/PDIF cable plus potentially slightly simplify the switching of the system a little bit if you don't have an advanced remote such as a Logitech Harmony.
"Vintage" is good for wine, not for A/V equipment.
-Dan D.
DonoMan is offline
post #32 of 43 Old 07-26-2012, 05:03 PM
jdsmoothie's Avatar
Quoted: 15325 Post(s)
Liked: 7479
Oops, .. no DD+ .. I was thinking of Netflix capability rather than what the HDMI(ARC) could do. The Panasonic rep actually called back to say that upon futher confirmation with his peers, the Panasonic TVs cannot pass the DD 5.1 via HDMI(ARC), rather via the optical audio output only.
@sdiver2489 - better plan on adding the optical cable from the TV to the AVR.
jdsmoothie is online now
post #33 of 43 Old 08-10-2012, 02:20 PM
sitnik's Avatar
The 5.1 does not pass from HDMI input X to HDMI (ARC) because of HDMI specification:
When an external device and the TV are connected directly, they negotiate their capabilities during initial handshake (resolution, copy protection, etc.). At that time, the TV tells the source that it is a 2CH device, because it is stereo. In response, the source (Xbox360, PS3, Cable box, etc.) downgrades its own audio output to 2CH. Then, this 2CH audio pass through the ARC and Optical.
In short, the TV does not down convert the audio. It just passes it. The HDMI source device down convert, because it was notified by the TV that only 2CH are available (the TV's own speakers).
sitnik is offline
post #34 of 43 Old 08-10-2012, 06:55 PM
jdsmoothie's Avatar
Liked: 7479
This really depends on the capability of the TV as some are able to pass both DD 5.1 and DTS 5.1 as well from a connected external source.
post #35 of 43 Old 11-25-2013, 12:04 PM
Scott Oakley's Avatar
Quoted: 80 Post(s)
Liked: 95
Nope that isn't the point at all, rather the primary reason is to pass any TV generated smart app audio (eg. Pandora, Netflix, Rhapsody, etc.) or OTA audio back to the AVR/sound system. Your best bet is to contact each TV mfr to determine which models will pass DD 5.1 via ARC. As already noted, Panasonic TVs can only do it via the optical audio out connection.
Hello, I realize this thread is a couple of years old but I would like to ask:
What is the source of the Panasonic comment (not passing 5.1 via ARC)?
Thank you,
Scott
Panasonic 2013 55VT60
Marantz SR-5012 AVR
B&W 805 Speakers
Velodyne 10" Sub
TiVO Premiere
Scott Oakley is offline
post #36 of 43 Old 03-03-2014, 09:13 AM
BHeld's Avatar
I have a 2012 Viera ST50 and will report for the benefit of others that Dolby Digital does NOT pass via HDMI (ARC) when using the Viera Smart Apps.
I do however get Dolby Digital via HDMI (ARC) for OTA programming.
Smart Apps tested were: CinemaNow, Vudu and Amazon Prime.
This really is a pretty lame implementation of a "Smart TV" for it to not pass the signal when using the built in streaming apps.
Bob H
Minneapolis, MN
BHeld is offline
post #37 of 43 Old 03-03-2014, 03:30 PM
jontyrees's Avatar
Liked: 38
Bob H
Minneapolis, MN
I'm pretty sure it does - try the ST thread in the TVs section - I'm sure there's some setting you need to change. Either that or the content you're streaming isn't in dolby digital
jontyrees is offline
post #38 of 43 Old 03-03-2014, 03:49 PM
BHeld's Avatar
Thanks jontyrees but 'pretty sure' is not the same as having actually tested it. I was just confirming what another user had posted with information they got from Panasonic since there continues to be people questioning whether it does or not.
Bob H
Minneapolis, MN
BHeld is offline
post #39 of 43 Old 04-17-2014, 11:54 AM
dazboz's Avatar
E5 series here, I can confirm after some testing it CAN pass DD 5.1 from Netflix over ARC.
No joy with other HDMI inputs or anything through the USB ports.:(
dazboz is offline
post #40 of 43 Old 05-29-2014, 07:18 AM
Naveen Yadav's Avatar
I'm facing the same problem with my Sony KLV46R452A. I'm only getting 2.1 audio through ARC and my TV doesn't even have slot for optical cable. What do I do?
Naveen Yadav is offline
post #41 of 43 Old 05-05-2015, 04:12 AM
See The Light's Avatar
Quoted: 51 Post(s)
Liked: 71
I have a Sony STR-DH550 Recevier and a Vizio E291-A1 LED TV. (Both are HDMI 1.4 ready).
The cable TV input is plugged from the wall directly to the Vizio with the coaxial able using the 75 ohm connection.
I gave up on trying to get the Sony receiver to play the TV sound using the ARC HDMI connection with the Vizio TV (HDMI 1 is the ARC slot).
What I did do insted was attach an optical cable from the Vizio, to the Sony receiver using the receiver's "TV" "OPT 2" port.
I set the Sony receiver Sound Field to "A.F.D Auto", which presents the sound as it was encoded *without* adding any surround effects.
As I change channels on the Vizio TV, the Sony receiver displays various sound fields it detects:
When the Vizio TV channel info reads "Dolby D 5.1 CH" = the Sony receiver readout is "Dolby Digital [3.2/1]"
"Dolby D Mono" = "Dolby Digital [1/0]"
"Stereo" = Linear PCM [C2/0]"
I have the Vizio Digital Audio Out Setting set to "Dobly Digital" (Instead of "PCM" or "OFF").
Cable Channel Choice is the only choice I want to make !!
See The Light is offline
post #42 of 43 Old 05-05-2015, 07:20 PM
Quoted: 51 Post(s)
Liked: 71
Tonight, I was able to get the ARC funtion working in the Sony amp.
To do that, I had to go to the Vizio TV Settings and under "CEC," turn on both the "CEC Funtion" and the "System Audio Control".
The same Digital Audio was passed through the HDMI ARC as was passed through the Digital Optical from the TV cable stations.
With some Tv stations transmitting only 2 channel, and others 3.2/1.
post #43 of 43 Old 06-23-2015, 01:32 PM
GatorRican's Avatar
Quoted: 37 Post(s)
Liked: 26
I just ordered a Vizio soundbar (SB4051) capable of HDMI ARC. From reading others above...Looks like I will not be able to pass 5.1 audio through my Panny ST 50 HDMI ARC to my new Vizio HDMI ARC sound bar. Although one poster did say that TV HDMI ARC will pass 5.1 if its an OTA sourced channel, which mine are!
HOWEVER, I guess I'll have to connect my BR Player and PS4 directly to the bar... having learned all of this ARC is not as useful as I once thought...
Though in fairness, I could blame Panasonic too for not passing 5.1 through their plasmas
TV: Panasonic TC-P55ST50
BluRay: Panasonic DMP-BDT 220
Audio: Sony HT-CT100 (Currently testing Vizio SB4051)
Gaming: PS4
PSN: Rican21
GatorRican is offline
