ONKYO HT-R390...no sound from anywhere - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-29-2012, 07:52 PM - Thread Starter
lowonthe456's Avatar
I bought my mom this little set up. Problem is, it worked for a while even into tonight...now...nothing.
I won't play any audio, either from fm or tv (optical) or HDMI
I'm pulling my hair out. I bought the thing through amazon and do not want to have to send this thing back to them.
1st: how can i completely reset the thing back to factory. Its currently unplugged.
2nd: the way i have it set...
TV: tv gets its signal via coax. Shound is passed via optical to the r390.
DVD: pic and sound in through HDMI. I get picture, no sound now. I did earlier tonight. Though sometimes I had to reboot the amp.
Please help
lowonthe456 is offline
post #2 of 6 Old 02-29-2012, 09:29 PM
JChin's Avatar
Quoted: 354 Post(s)
Liked: 205
Hi lowonthe456, what does the receiver display show? Have you try turning the volume to a high setting?
To reset the receiver (reset everything back to factory default, auto setup will need to be rerun):
- turn receiver on
- while holding down the [VCR/DVR] button
- press the [ON/STANDBY] button
- “Clear” will appear on the display and the receiver will enter Standby mode
JChin is offline
post #3 of 6 Old 03-01-2012, 08:05 PM - Thread Starter
it just shows whatever setting its on. Just now man called to say she accidentally turned the unit off....she turned it back on and guess what..no sound
I'm calling Onkyo tomorrow. This is crap.
post #4 of 6 Old 03-01-2012, 09:27 PM
JChin's Avatar
Quoted: 354 Post(s)
Liked: 205
Is the speaker indicator showing "A"? Is the receiver muted by accident (since on the remote the "Mute" button is close the "Receiver" button)?
JChin is offline
post #5 of 6 Old 03-02-2012, 08:06 AM - Thread Starter
nope. not muted. Speaker A enabled. Its on the correct setting for TV.
I switched to dvd and its the same thing. Passes the video but no audio.
I unplugged it last night and plugged it in this morning and it works again...
post #6 of 6 Old 10-05-2012, 05:56 PM
javi404's Avatar
Did this ever happen again? Ever figure out what the cause was?
javi404 is offline
