Mixing Emotiva XPA-3, Adcom GFA-5500, and Onkyo NR-708 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-03-2012, 12:29 AM - Thread Starter
Teseract's Avatar
So I'm planning on an Emo XPA-3 whenever the Spring sale rolls around. I currently have an Adcom GFA-5500 with an Onkyo NR-708 receiver. Front speakers are Polk RTI-12's with a CSI5 center, a couple Sony towers for surrounds that I've modified with inexpensive crossovers (stock just had caps inline with the wires) and better tweeters/mids, with some stock Sony bookshelf speakers for rear surrounds.
I eventually want to get some RTI A7's for surrounds and some A3's for the rears, but what I have makes me happy for now.
The Adcom is in the shop currently but normally runs the RTI-12's. The NR708 runs the rest.
I'm trying to decide on the best setup once I get the XPA-3. Should I bi-amp the RTI-12's? The things LOVE power so I'm tempted.
If I do, should I use the Adcom on the woofer section and use the XPA-3 to run the mids/tweets? Or should I use the Adcom or the XPA-3 to run the surrounds and use the receiver to power the mids/tweets and the XPA-3 or Adcom to run the woofers? I'm favoring the Adcom to power the woofers if I do bi-amp because it has a higher damping factor (700, yes, 700) than the XPA-3 (Approx 200) and (arguably) more headroom.
On the other hand, I'm not sure how worthwhile it is to send 200 wpc of power to the mids and tweets on the RTI-12's; most of the power gets sucked by the woofers. I'd think the 110WPC the Onkyo puts out would be sufficient, especially if it's only responsibility besides that was to power the rear surrounds.
Plus I'm not sure if there would be an issue with balancing the sound levels between the upper and lower sections?
The Sony towers really aren't power hungry at all, and I don't know if the crossover can handle 200+ watts. Once I get my hands on the RTI A7s I'd of course I'd end up using one of the amps to drive them too.
Either way I'm probably going to have to run a extension cord to another room, I don't know if the wiring in this room can handle two big amps plus the receiver and the TV.
Opinions or past experiences anyone?
M.B.
Teseract is offline
post #2 of 13 Old 03-03-2012, 05:33 AM
chatanika's Avatar
I tried bi-amping and could not hear any improvement. most of the power goes to the bass so sending more power to the tweeter is a waste. If you feel that you need more power then just get a bigger amp for your mains , although that adcom should do the job. If your looking for a big performance gain I would throw as much money as you can afford on a subwoofer .
chatanika is offline
post #3 of 13 Old 03-03-2012, 05:39 AM
Theresa's Avatar
Liked: 51
Passive bi-amping does nothing but waste an expensive amp. I would use the XPA-3 for the L/C/R. It is a fine amp, I use it in my system too but am using active crossovers so the L/C/R midwoofers are powered by it.
Theresa is offline
post #4 of 13 Old 03-03-2012, 04:24 PM - Thread Starter
Teseract's Avatar
So because the RTI12s have passive crossovers sending more power to them won't do much of anything?
Teseract is offline
post #5 of 13 Old 03-03-2012, 06:03 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
The low frequency side will always draw more power than the high side. Some say passive biamping can be useful still, though.
One thing to note, when passively bimamping from a amp with a shared power suoply, the supply itself may be the limiter.
If you are in a position to try it, I suggest trying it thus bypassing the endless threads discussing it's merits.
"But this one goes up to 11"
MichaelJHuman is offline
post #6 of 13 Old 03-03-2012, 06:20 PM
Audiodork's Avatar
Liked: 37
I would leave the Adcom driving your Mains. The GFA-5500 uses a 1.5 kVA Toroidal Transformer as opposed to the 850VA used in the XPA-3. So in other words, the 5500 has almost twice as large of a transformer while driving one less channel. I would look for a matching GFA-5503 as opposed to adding an XPA-3. Also, the 5503 uses a 2.0 kVA Toroidal Transformer which is almost three times the size of the Emotiva.
Radio Shack SPL Meter Owner
Audiodork is offline
post #7 of 13 Old 03-03-2012, 10:48 PM - Thread Starter
Teseract's Avatar
I was considering this until I was sitting with the Adcom on reading a web page with nothing playing at all when the left channel of the GFA-5500 released it's magic smoke with a deafening WHUMP from an RTI12 and made my house reek for a couple hours... now I'm concerned about reliability and a 5 year warranty sounds nice to me. I'm still waiting for my Dad to finish fixing the Adcom.
I agree on keeping the Adcom on the RTI12's though, it does have more headroom. I really miss it. I tried to re-watch "The Tree Of Life" with no amp after watching it with the Adcom the first time... there's no comparison. The Onkyo just doesn't have the juice to handle 7 channels and the wattage sucking RTI12's and the CSI5.
Teseract is offline
post #8 of 13 Old 03-03-2012, 11:02 PM
Quoted: 266 Post(s)
Liked: 151
Wow...Adcom's website shows new products? I thought they were practically dead.
post #9 of 13 Old 03-03-2012, 11:07 PM - Thread Starter
Teseract's Avatar
There's nothing there I'd spend that much money on for sure.
Teseract is offline
post #10 of 13 Old 03-04-2012, 06:01 AM
Audiodork's Avatar
Liked: 37
Now if only Indy Audio Labs started to release Aragon and Acurus Amplifiers... Hopefully they will soon.
post #11 of 13 Old 03-04-2012, 06:03 AM
Audiodork's Avatar
Liked: 37
Now if only Indy Audio Labs started to release Aragon and Acurus Amplifiers... Hopefully they will soon. Hold that, they are now selling new Amplifiers! Look kinda expensive so far, but they really do look nice.
Actually, they do have an Acurus 2002 that would be nice and far less expensive than the Palladium based Monoblock on the Aragon side. At least what is showing on the Website.
post #12 of 13 Old 04-18-2012, 10:39 PM - Thread Starter
Teseract's Avatar
Well, Emotiva is running 10% off on a few items, so I finally pulled the trigger on an XPA-3, ~$630 shipped Fedex ground.
I'm looking forward to having some oomph in the front soundstage again, the Onkyo just can't handle 7 channels with the speakers I have properly. If I flip to stereo only it's not bad, but I was watching scenes from "The Tree Of Life" and it definitely didn't have the impact I had even with the Adcom just running the front left/right channels.
My Adcom GFA-5500 is still out of commission... my Dad is busy and isn't much working on it. I have a sneaking suspicion he's "burning it in" after repairing it and doesn't want to give it back yet...
Teseract is offline
post #13 of 13 Old 04-19-2012, 12:23 AM
ValerSterling's Avatar
ValerSterling is offline
Onkyo Tx Nr708
