Need advice on AMP to connect computer to speakers -$200ish budget - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-03-2012, 08:27 AM - Thread Starter
Nostalgic's Avatar
Hey all.
I was using some vintage tuners to connect my computer to my Polk desktop speakers. I really need something much smaller so I can set it within reach on my desk and won't take up tons of space. I also don't want to go vintage anymore.
All I need it to be able to do is let me connect my computer to it using a 3.5mm jack to rca's. Would be nice if I could also connect my CD player/ipod/etc to it in the same way (doesn't have to be at the same time).
It also needs to have a headphone jack (headfi baby!)
So, what are your suggestions for doing this in the $200 range?
Thanks!!
Nostalgic is offline
post #2 of 10 Old 03-04-2012, 07:28 AM - Thread Starter
Nostalgic's Avatar
Bump in the hopes someone will see this
post #3 of 10 Old 03-04-2012, 10:58 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
If you don't need a lot of volume (SPL), there's some pretty cheap amps called t-amps. Search on amazon.com
There's car amps, but then you would need a 12 volt power supply.
There's this (http://www.amazon.com/AudioSource-AM...0887382&sr=8-3)
This [I think this brand seems like cheap junk, but never owned one] (http://www.amazon.com/Pyle-PCA1-30-W...0887382&sr=8-4)
FYI, I did a search on Amazon.com for 'compact power amplifiers' to find some of these.
"But this one goes up to 11"
MichaelJHuman is offline
post #4 of 10 Old 03-04-2012, 12:27 PM
defear's Avatar
You could search ebay for a brand called technical pro.
defear is offline
post #5 of 10 Old 03-04-2012, 02:08 PM
rdperry's Avatar
http://www.parts-express.com/pe/show...number=300-383 I think this wold fit the bill for you.
rdperry is offline
post #6 of 10 Old 03-05-2012, 01:32 AM
jdcrox's Avatar
Quoted: 80 Post(s)
Liked: 107
Great little amp! I have been using one for over a year on my computer, driving the Parts Express B652 speakers. Sounds really good.
jdcrox is offline
post #7 of 10 Old 03-05-2012, 01:47 AM
Ryan1's Avatar
Quoted: 75 Post(s)
Liked: 85
And on the page Michael points to, there is a link to this dirt cheap Lepai Tripath Class-T amp.
It has Tripath's TA2020 chip, which is rather good. If that thing is halfway decently made, it's seems like a very good buy at less than $25
Ryan1 is online now
post #8 of 10 Old 03-09-2012, 10:30 AM - Thread Starter
Nostalgic's Avatar
Thanks for all the help so far. I've got some research to do...
Now I'm wondering about a usb DAC then connect an amp. Will a usb DAC work with my computer if I don't have a soundcard (integrated sound only) ?
post #9 of 10 Old 03-09-2012, 10:40 AM
jdcrox's Avatar
Quoted: 80 Post(s)
Liked: 107
Yep, it will work fine. I use an HRT Music Streamer II, feeding a Dayton DTA 100a amp, to the Dayton B652 speakers. Sounds great to my ears. Nothing like my main rig with Green Mountain Audio speakers and Cambridge Audio integrated, but doesnt send me screaming in pain either!
jdcrox is offline
post #10 of 10 Old 03-09-2012, 10:50 AM
Nethawk's Avatar
Liked: 119
Slightly over budget, but you seem to have surpassed that already. Have you considered a small receiver instead? It would allow you to expand. If so, check out the Sherwood R-904N.
Nethawk is offline
