R972 Trinnov User Notes - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 653 Old 04-07-2014, 05:00 PM
Stereojeff's Avatar
Quoted: 134 Post(s)
Liked: 63
Originally Posted by pwiss View Post
Curt,
Does the +6db bass file add more gain to the receiver thereby needing less gain in the sub? I have a sub that has an auto on feature and was wondering if adding the +6db file would help the signal received by the sub to activate the auto on feature quicker.
While I'm not Curt, I can answer your question.. Tbe bass files change the subwoofer level, only. The +6 dB file is the same as if you turned your sub up by 6dB relative to the file labelled "flat". So it does increase the feed to the subwoofer. This could result in your being able to turn the subwoofer down or could simply make it more accurate depending, of course, on the level before.
Jeff
Stereojeff is offline
post #632 of 653 Old 04-11-2014, 08:39 AM
Raul GS's Avatar
Quoted: 20 Post(s)
Hi Curt,
If you are still around, I have a couple of questions regarding 9.1 Earlier you mentioned that in this configuration you would recommend 2 speakers be attached to each side and the rears be run in front-side (high?). Regarding the two speakers placed on each side, would it be better if one is on the side and the other is high on rear each side or is it preferable that one be on the side and the other placed on the rear for each side. I.e is it better if the second set of speakers is placed high on the rear or should it be around the same height as the side speaker.
Also, the rears that are being reoriented to the front, is it best to place them higher than the mains and to the side of them?
Thanks for any insights.
Dunning–Kruger effect - a cognitive bias where individuals exhibiting poor ability suffer from an illusion of superiority, due to their mistaken assessment of their cognitive ability. That is, a high level of incompetence prevents such individuals from cognitively recognizing their own ineptitude. - Yes I know, I can remember many of my past posts.
Raul GS is offline
post #633 of 653 Old 04-11-2014, 05:14 PM - Thread Starter
3D Audio Consultant
Curt_Trinnov's Avatar
Quoted: 72 Post(s)
Liked: 120
Originally Posted by Raul GS View Post
Hi Curt,
Hi Raul GS
All of this depends on what you are listening to- movies or music- and your room configuration: room shape, where are listeners, how many, etc.  The possible choices depend on many factors I believe should be taken into account. Speaker placement using Trinnov Remapping would be great seminar topic.  If you or any others would like recommendations regarding a particular configuration, I suggest you PM me.
___________
Curt Hoyt
3D Audio Consultant
Trinnov Audio
USA
Curt_Trinnov is offline
post #634 of 653 Old 04-25-2014, 02:25 PM
rlseverance's Avatar
I continue to get 0 hz for my -6 db point. I know the speakers should be somewhere around 100 hz, definitely not 0.
I tried the user notes and couldn't find anything and read all 22 pages of this thread.
rlseverance is offline
post #635 of 653 Old 04-25-2014, 02:27 PM
Another thing, I have read many of the comments about "Audiophile 1", but I haven't seen a description of what is happening. With manufacturing variance and room placement interaction, the left speaker and right speaker will not be equal, so what does Trinnov choose as the target curve?
post #636 of 653 Old 04-25-2014, 02:31 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
I'm not sure that is the -6dB point, but the crossover point is chosen in conjunction with the upper end rolloff for the sub.
Do you have a subwoofer? What is displayed for the subwoofer?
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #637 of 653 Old 04-28-2014, 09:09 AM
No sub.
Full range left and right, satellite center, left and right surrounds.
post #638 of 653 Old 04-28-2014, 09:14 AM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
No sub.
Then the 0 hz is correct as there is no crossover.
-curtis
cschang is offline
post #639 of 653 Old 04-28-2014, 09:28 AM
So I did not understand the analysis that the Trinnov software was doing.
Along with picking a crossover point, I thought the software was determining a -6 db point for bass management, in my case, to send any bass content from the center or surrounds to the front left and right speakers.
So do I just lose any bass mixed into the center channel, surrounds, and/or the LFE channel?
To me that wouldn't make sense to design it that way, but I don't know.
post #640 of 653 Old 04-28-2014, 10:10 AM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
To be honest, I am not sure how the R972 handles this situation. Perhaps you can find a test disc of some sort and experiment.
Perhaps someone who does know will chime in.
-curtis
cschang is offline
post #641 of 653 Old 04-28-2014, 10:34 AM
sdrucker's Avatar
Quoted: 862 Post(s)
Liked: 587
Beats me whether the R-972 version of Trinnov redirects bass to speakers with a lower (better) detected -6db level from those with a higher (worse) -6db point, or uses Large speaker settings from before a Trinnov cal in a meaningful way.
If you downloaded REW (Room EQ Wizard) and had a USB/HDMI mic you could run frequency-limited sweeps to try to see whether you were getting "bass holes", and at what Hz.
Audio Gear: Trinnov Altitude 32 (24 channel), NAD M27 amps (3)
Video: JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro 4444 (coming soon)
Misc.: Oppo 103, Oppo 203 UHD player, JRiver
Speakers: PSB Imagine T3 LCR, Imagine T Wides and Side Surround 1, T2 Side Surrounds, Imagine XB rears, PSB CS1000 ceilings (6), HSU ULS-15 Mk 2 subs (4) - 11.4.6
sdrucker is online now
post #642 of 653 Old 04-28-2014, 11:48 AM
Stereojeff's Avatar
Quoted: 134 Post(s)
Liked: 63
Measurement data from Trinnov is used for TI's standard bass management library.
Jeff
post #643 of 653 Old 04-28-2014, 01:18 PM
I don't know how TI's standard bass management library functions.
Richard
post #644 of 653 Old 04-28-2014, 06:48 PM
Stereojeff's Avatar
Quoted: 134 Post(s)
Liked: 63
4th order low pass and 2nd order high pass filters at the crossover point specified by Trinnov suite.
Jeff
post #645 of 653 Old 04-29-2014, 06:09 AM
Thanks Jeff.
As I stated in an earlier post, I have full range left and right speakers, a small center, left surround and right surround.
No sub.
Trinnov is not picking up a -6 db point for any of the small speakers.
There being no sub, it is not picking a crossover point.
So I am wondering, am I just losing any bass content mixed to center, surround, or LFE channel?
Richard
post #646 of 653 Old 04-29-2014, 11:20 AM
Stereojeff's Avatar
Quoted: 134 Post(s)
Liked: 63
The industry standard (and Dolby and DTS requirement) is to re-route bass information from channels where it cannot be reproduced to channels that are low frequency capable. To my knowledge, the R-972 was submitted to and passed both Dolby and DTS certification but I cannot personally verify either. When I was at Sherwood certification submission was handled directly by the factory. Nevertheless, my assumption is that the unit was submitted and accepted.
Jeff
post #647 of 653 Old 04-29-2014, 12:36 PM
Thanks Jeff,
I will do more testing and try and figure out what is going on.
I did read all 22 pages of this thread before posting, and didn't find anyone else that couldn't get a -6 db point. So maybe my unit simply isn't working, but that would seem strange, as I get good distance, level and angle readings.
Richard
post #648 of 653 Old 04-29-2014, 02:01 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
Thanks Jeff,
Richard
It doesn't exactly answer your question, but here is Curt's explanation of how the crossover is calculated:
http://www.avsforum.com/t/1397757/r972-trinnov-user-notes/480#post_22746399
-curtis
cschang is offline
post #649 of 653 Old 04-29-2014, 02:26 PM
I had read that response, but 1. It is for a situation where the -6 db point was determined, and 2, there is a sub, which is not my situation.
post #650 of 653 Old 09-18-2014, 01:24 PM
Update on bass management
So after a bunch of testing, here is what I confirmed.
(remember the set up was large left and right speakers, small center and left/right surrounds, no subwoofer)
A low frequency signal sent to LFE is reproduced at the left and right speakers, but at a quite low level.
Low frequency signals sent to the center or surrounds, stay at the center, or surround speaker, they are just in my case barely audible because the speakers really can't handle the signal, if I turn up the volume a bunch, I can get a bunch of distortion.
So, in conclusion, if you have a set up like mine, the Trinnov/R-972 bass management is not working as most other systems would, and you would in fact lose bass content sent to the LFE, or the center and surrounds.
post #651 of 653 Old 12-01-2014, 09:51 AM
RippyD's Avatar
Quoted: 64 Post(s)
Liked: 49
Replying to this very late as I was researching Trinnov.
Are you sure Trinnov isn't working, or are your speakers just not able to reproduce those frequencies? What speakers are they, or what is the specified -3dB (or -2dB) low range for the speaker? For most speakers the low end falls off a cliff. If you're trying to have the EQ system account for frequencies below the -3dB frequency of your speaker it's not going do to much.
Rip
RippyD is offline
post #652 of 653 Old 12-12-2014, 02:14 PM
Trinnov Bass Management
Perhaps I was not clear enough.
First, Trinnov is working, all the spatial processing works as described.
My comments only apply to the Trinnov bass management, when, one of the calibrated positions is selected. In that scenario, with no subwoofer, and, full range left and right speakers, small center, small surrounds, the Trinnov processor will not assign a frequency at which to high pass the small speakers and direct bass to the left and right full range speakers.
So, if you send a low frequency tone to the center or surrounds, you basically hear nothing, unless you turn it way up, and then you can generate a bunch of distortion.
If you choose poition none, from the Trinnov menu, then you can manually set crossovers and the bass management works like most systems I have ever read about, for example, low tones to the center or surround are reproduced by the full range left and right speakers.
This is one example where some manual override of the auto set-up would have been nice, so I could have proper bass management, and yet retain the nice spatial processing that Trinnov produces.
post #653 of 653 Old 12-12-2014, 03:18 PM
tr4a's Avatar
Quoted: 57 Post(s)
Liked: 326
Have you tried the Subwoofer Mode in System setup?
The Normal position is not working for you but the SW Plus might
solve your bass issues.
Steve
tr4a is online now
Sherwood Newcastle R 972
