R972 Trinnov User Notes - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 653 Old 03-10-2012, 06:14 PM - Thread Starter
3D Audio Consultant
Curt_Trinnov's Avatar
Quoted: 72 Post(s)
Liked: 119
Hi Noah
You've correctly answered all your own questions!
I'm also headed out with the lady, time to shift gears..
Cheers,
___________
Curt Hoyt
3D Audio Consultant
Trinnov Audio
USA
Curt_Trinnov is offline
post #92 of 653 Old 03-11-2012, 10:35 AM
jwells777's Avatar
Quick questions regarding the 3d mapping functionality:
If I have the FR/C/L near the floor but approximately correctly spaced (by angle) in the front and the SL/SBL/SBR/SR approximately correctly spaced (by angle) in the ceiling, will the Trinnov 3d mapping be able to adjust the virtual vertical height on all (or any) of the speakers?
jwells777 is offline
post #93 of 653 Old 03-11-2012, 10:49 AM - Thread Starter
3D Audio Consultant
Quoted: 72 Post(s)
Liked: 119
Check it out and get back to us: V2.5 Trinnov User Notes, Section 6, page 6 implies you'll have a tilted sound stage. You may also have trouble cal the ceiling speakers if they are way off axis with attenuated hi's to the cal mic.
___________
Curt Hoyt
3D Audio Consultant
Trinnov Audio
USA
post #94 of 653 Old 03-11-2012, 11:13 AM - Thread Starter
3D Audio Consultant
Quoted: 72 Post(s)
Liked: 119
Correct reporting for Sub is distance and level only. Anyone getting the Trinnov Cal Data, first page, to report Sub at 90 deg horizontal?
___________
Curt Hoyt
3D Audio Consultant
Trinnov Audio
USA
post #95 of 653 Old 03-11-2012, 11:21 AM
cpoole17's Avatar
Curt -
None of the calibrations that I currently have stored report sub at 90 deg, but I am almost certain that I have seen it in the past...
Chris
cpoole17 is offline
post #96 of 653 Old 03-11-2012, 12:24 PM
jwells777's Avatar
Thanks for the quick reply. I had glanced through your notes but somehow missed the section that exactly answered my question.
Unfortunately, this makes it a much more difficult call for me to decide whether to buy or not....4311CI...SC-55...TX-NR809...or r-972...decisions....
post #97 of 653 Old 03-11-2012, 12:35 PM - Thread Starter
3D Audio Consultant
Quoted: 72 Post(s)
Liked: 119
Your layout is not that unusual. Maybe someone with a similar setup could report the results they are having. I suspect an improvement in 2D
___________
Curt Hoyt
3D Audio Consultant
Trinnov Audio
USA
post #98 of 653 Old 03-11-2012, 12:49 PM
jwells777's Avatar
If anyone could, it would be greatly appreciated.
My primary motivation of upgrading the receiver is to take advantage of the latest and greatest bells and whistles (currently using an old HK AVR525). It seems that the R-972 vs. one of the later Denon/Onkyo AVRs there is room correction advantage to the R-972 and a feature advantage (particularly networking) to the others. I am trying to gauge whether the Trinnov processing advantage is sufficiently better for my setup than the Audyssey such that I should give up the other bells and whistles....
post #99 of 653 Old 03-11-2012, 03:41 PM
Stereojeff's Avatar
Quoted: 133 Post(s)
Liked: 63
Aside from the R-972, the cost to have Trinnov in your system is north of $10k. Boxes that offer the Internet streaming features are available in the low hundreds. You do the math.
Jeff
Stereojeff is offline
post #100 of 653 Old 03-11-2012, 04:11 PM
Roger Dressler's Avatar
Quoted: 1763 Post(s)
Liked: 900
No. The surrounds are opposite the mains. The points you wish to "virtualize" (raised L/C/R) are outside the available range of operation for remapping. Now maybe if you had Lh and Rh speakers remapping might help, but the 972 does not know what those are.
Deadwood II Theater
Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is online now
post #101 of 653 Old 03-11-2012, 04:12 PM
adude's Avatar
Quoted: 49 Post(s)
JWells777,
I have my front L/C/R speakers on the floor, tilted up so the tweeter is aimed at the listening position. The 4 surrounds are wall, at approx 8 ft height. I think this layout is very similar to yours. The left and right surround speakers are approx .5 ft towards front from listening position.
Now, when I run the 3d remap, there is quite a bit of sound coming from the left right surrounds. At first I liked it for movies because it seemed that there is wider ambience/soundstage. I am not sure if Trinnov was using it more like wide speakers or trying to raise the entire front soundstage up using those two surrounds in the mix. For movies. But as I listened more and more, it was kind of distracting. After I heard it for music, it was a big no-no. Most of the sound was coming from LR surrounds than the fronts. I have now set the spatial mode to DLY+LVL and that working out very fine for me. Trinnov EQ is very powerful and does a very good job without any 2d/3d remap/autoroute.
That's my experience. Yours may be similar or different. We can only know once you try.
adude is offline
post #102 of 653 Old 03-12-2012, 09:08 AM
RTPBob's Avatar
OK, this thread has rekindled my interest. My concern has always been about my speakers and their compatibility with Trinnov and the R972 Receiver. I have a 5.1 Magnepan MMGW and MMGC setup with a Outlaw LFM-1+. Nominally 5 Ohms on the Maggies. Down the road, I've considered getting another pair of Maggies for a Front-wide set-up.
I know the MMGW's don't go real high but that doesn't bother me as neither does my hearing anymore.
Does anyone have any thoughts about the compatibility?
Thanks in advance,
Bob
RTPBob is offline
post #103 of 653 Old 03-12-2012, 09:44 AM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
Curt,
Do the +3/+6 low freq curves that can be obtained from Sherwood have the same effect as raising the gain on the sub amp by +3 or +6db?
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #104 of 653 Old 03-12-2012, 09:53 AM - Thread Starter
3D Audio Consultant
Quoted: 72 Post(s)
Liked: 119
Originally Posted by cschang View Post
Curt,
EXACTLY. Adjusting for 3-6 dB manually can be problematic, unless you have a way to measure.
___________
Curt Hoyt
3D Audio Consultant
Trinnov Audio
USA
post #105 of 653 Old 03-12-2012, 10:19 AM
FilmMixer's Avatar
Quoted: 1946 Post(s)
Liked: 2410
Curt,
Curtis... I don't believe so... when I had my 972, I had access to the files (I still have them if you need them, BTW).. IIRC, Jeff H. relayed to me that it was actually the eq target and not just a sub gain change..
FilmMixer is offline
post #106 of 653 Old 03-12-2012, 10:26 AM - Thread Starter
3D Audio Consultant
Quoted: 72 Post(s)
Liked: 119
Believe what you will... I personally specified the curves and forwarded them to Jeff. It changes the EQ target for SUB ONLY.
___________
Curt Hoyt
3D Audio Consultant
Trinnov Audio
USA
post #107 of 653 Old 03-12-2012, 11:08 AM
FilmMixer's Avatar
Liked: 2410
Curt.. As I said, I was recalling an old conversation.. however..
I said to Curtis:
"it was actually the eq target and not just a sub gain change.."
How is that different than your reply "it changes the EQ target?"
Are you saying it was just a linear addition of 3 or 6 db to the original curve..
post #108 of 653 Old 03-12-2012, 11:38 AM - Thread Starter
3D Audio Consultant
Quoted: 72 Post(s)
Liked: 119
I said to Curtis:
Yes, we did this in 2008!
It's both: Computation calculates the level adjustment and EQ target. They go hand in hand- work together- to give you the sat-sub integration. It is "just a linear addition of 3 or 6 db to the original curve."
To remove confusion about this going forward, I'll add details to the EQ- Target curves section of the Trinnov User Notes.. now at V2.6.
___________
Curt Hoyt
3D Audio Consultant
Trinnov Audio
USA
post #109 of 653 Old 03-12-2012, 12:33 PM
cpoole17's Avatar
Curt,
Regarding my 4.1 setup, I have a few follow up questions.
1. As I related in my earlier post, I was able to get the system working with Trinnov using your suggestion of calibrating with the "center" speaker at center rear and then removing that speaker. As I described, I did not notice any significant problems with this configuration. However, as I thought about it, I began to wonder about scenarios where problems might arise such as: if a signal is present in both rear channels of a 5.1 soundtrack with approximately equal loudness, would it be mapped to the missing speaker and be lost? Similarly, if a source has a discrete 6.1 or 7.1 soundtrack, would those additional channels (or a portion of them) be lost?
2. If the answers above are yes, could the issue be mitigated by vertically displacing the speaker at center rear (say by placing it on the floor); then re-calibrating, disconecting that speaker, and setting spatial to 3d? In other words, would the 3d remapping attempt to "pull up" that missing speaker by sending (some portion of) the signal to the remaining rear speakers?
3. Do the results of the tests I performed earlier indicate that Trinnov, or at least this implementation of it, is not compatible with a 4.1 setup? Or is there something peculiar about my system that is keeping Trinnov from mapping the channels properly?
Thanks again for all of your support!
Chris
cpoole17 is offline
post #110 of 653 Old 03-12-2012, 02:59 PM
Liked: 900
Originally Posted by cpoole17 View Post
Curt,
If your AVR thinks it is driving a 6.1 speaker system, then it will sometimes try to use it as such. 6.1 discrete or EX or PLIIx or Neo:6 modes will all direct signal to the missing speaker. Somehow you have to override the speaker configuration and tell it the speaker is not present. If that irritates the Trinnov remapping, then at least if you limit all decoding to 5.1 mode you will not lose anything essential.
It's not an inherent Trinnov problem, nor a peculiar setup. It just appears to be a setup that no one tested thoroughly at Sherwood. I found similar oversight in my Classe SSP-800. In phantom center mode there were various odd, and glaringly obvious, problems that required a firmware fix. One of those bugs is still present to this day, 3 years into production. The next code release finally nails it!
I guess engineers seem to assume if they test the maxed out case, the subsets will automatically be fine.
Deadwood II Theater
post #111 of 653 Old 03-13-2012, 02:29 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
Out of curiosity, how many filters can Trinnov apply to a channel for EQing?
-curtis
cschang is offline
post #112 of 653 Old 03-14-2012, 02:09 AM
Liked: 900
One. Same as Audyssey or Dirac.
Deadwood II Theater
post #113 of 653 Old 03-14-2012, 06:08 AM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
Thanks Roger...but maybe my syntax isn't correct.
Should I say filter "resolution"?
-curtis
cschang is offline
post #114 of 653 Old 03-14-2012, 06:27 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 400 Post(s)
Liked: 289
You should say "filter taps".
RUR is offline
post #115 of 653 Old 03-14-2012, 07:00 AM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
Thanks...OK...let's go with that.
How many filter taps does Trinnov use per channel?
-curtis
cschang is offline
post #116 of 653 Old 03-14-2012, 07:11 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 400 Post(s)
Liked: 289
Sorry Curtis, not aiming for incremental disclosure... I know what it is for my unit, but not for the 972. Curt's your huckleberry.
RUR is offline
post #117 of 653 Old 03-14-2012, 07:30 AM
Stereojeff's Avatar
Quoted: 133 Post(s)
Liked: 63
1024 tap FIR filters plus 7 independent IIR filters per channel.
Jeff
post #118 of 653 Old 03-14-2012, 07:48 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 400 Post(s)
Liked: 289
Jeff
Thanks, Jeff. What's the cutoff frequency for IIR vs. FIR - 250Hz?
RUR is offline
post #119 of 653 Old 03-14-2012, 10:43 PM
noah katz's Avatar
Quoted: 1033 Post(s)
Liked: 366
Curt, I'd appreciate feedback on the following plan for speaker placement.
The surrounds are now as shown in the pic; left side speakers mirror the right.
I put the side surrounds where they are because it's close to what the ITU/972 manual recommends, and so Trinnov wouldn't have to work so hard to re-map them.
But now, after your additional explanations and ensuing discussion, I wonder if a more useful way to think about it is that Trinnov will try to create phantom images where they belong over 360 deg azimuth (not sure about the very back though).
Therefore it would be better to have more even angular spacing of the surrounds, which I could do by moving the sides from the back edge of the fireplace to the front.
Is that about right?
Another possibility, which would give me back two of the speakers I removed after the Denon 4311:
- Use a phantom center to free up one channel (assuming I don't have the same issue as Chris).
- Connect the two surround back speakers to one amp channel, freeing up another one
- Use the two newly available channels for a pair of front speakers, located at the former Audyssey DSX wides' locations at 60 deg azimuth from the center speaker and about a foot above ear height, or at the former Audyssey DSX heights locations' at45 deg azimuth from the center speaker and 45 deg elevation from the listening position (see pic), or somewhere in between.
Speaking of height channels, the user notes say
"Trinnov 9.1 with height
Some of you want more channels, up to 9.1- typically to fill in long rectangular rooms. The best way to accommodate
more channels such as 9.1 is to share the side outputs with two speakers each, thereby leaving the rear outputs for use
as height channels in the front."
To be clear, this is intended only to correct soundstage height errors, as with a below-screen center speaker, not to expand the soundstage height as with DPL IIz or Audyssey DSX - right?
Noah
noah katz is online now
post #120 of 653 Old 03-15-2012, 02:42 PM
noah katz's Avatar
Liked: 366
When setting up for a phantom center, does the importance of getting within 1 deg horizontal transfer to now getting the L/R within 1 deg of the same horizontal angle?
Noah
Sherwood Newcastle R 972
