AV rack - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-04-2012, 10:59 PM - Thread Starter
amb7247's Avatar
Is there a good rack you guys recommend that is maybe 300-600 range that gives at least 5-6 shelves of space. Bottom shelf WILL have the amp on it other will have the receiver, power surge, DVD player and network switch. Top will have 360 and PS3 on it. Thanks.
Doesn't have to be professional just something I'm putting in the corner.
Xbox Live: ShadyFusion23
PSN: Nukleard1sa5t0r
amb7247 is offline
post #2 of 2 Old 03-05-2012, 06:50 PM
jrj127's Avatar
I recently bought wire shelving from The Container Store (you can probably find another store, too). The consumer brand is InterMetro and the commercial is Metro if your equipment is very heavy. With InterMetro you can choose black, white, or silver. It is modular and adjustable. I had the poles cut to 50". The wire shelves are all 24" wide, perfect for home theater gear.
Let me tell you, having the rack on wheels is amazing! Setting up and making changes is so easy. If you go wheels, the 3" casters are limited to 100 pounds each (so a 4-wheel, 4-pole rack can hold 400 pounds). I got 2 plain wheels and 2 with brakes.
I chose black which looks pretty good with black gear. I have 5 shelves total at varying positions (each amp and preamp have their own shelves). My bottom shelf is at the very bottom of the poles, holding a 75 pound amplifier. The top shelf is at the very top of the poles because it would look silly to have bits of the poles sticking out. All the feet on my gear contacted at least two wires of the shelf for weight distribution. You could add coasters to spread out the weight if you'd like.
jrj127 is offline
