Harman Kardon AVR 265 bad speaker port? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-07-2012, 10:06 AM - Thread Starter
sharangad's Avatar
Hi Guys
I have an Harmon Kardon AVR 265.
I've noticed some ringing/harshness on the front right speaker when playing back certain high frequencies.
This has been noticed with the ez Speaker setup (auto-calibration using the supplied microphone) and with the signal fires sequence in the extended LOTR Return of the King DTS-HD MA blu-ray disc (Disc 1 1h01min approximately).
Swapped the two front speakers, the problem remained with the front right. Swapped the cables for the front two speakers and the problem emanated from the front left (i.e. front left is now connected to the front right port on the AVR).
Before I take it back to the dealer is there anything I should check for?
sharangad is offline
post #2 of 4 Old 03-07-2012, 12:28 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 421
Strange, sounds like an amplifier issue..
Note that the 265 is a Euro model..
Just my $0.02...
M Code is offline
post #3 of 4 Old 03-10-2012, 09:33 AM - Thread Starter
sharangad's Avatar
Nm. Rerunning the calibration resolved the issue.
post #4 of 4 Old 02-11-2015, 11:21 PM
Darlene Joseph's Avatar
Liked: 0
Hi guys, I am having a problem with my AVR 265. I recently found out there was an update for it and updated it. After following the prompts and hardware resetting it, none of the commands are working. Would appreciate some help.
Darlene Joseph is offline
