denon receivers and harmony - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-07-2012, 11:44 AM - Thread Starter
john_a_g's Avatar
OK, just finished the basement. Using Denon 3808 for 7.1 in main "family room" downstairs. Also have a gym and patio wired for speakers. My intent is to use my older 3803 as an amp. I have zone-2 pre-outs from 3808 into front speakers of 33803. That will power the gym speakers And zone 3 pre4-outs going to surrounds on the 3803 which will power the patio.
I am using a Harmony 900 remote for the setup.
Here's the issue I've run into: Since both receivers are Denon the codes are pretty much the same so both receivers respond to the same command.
Originally, I thought I might get around this by covering the I/R of the 3803 and using the Trigger Out on the 3808 to power on the 3803. I could then do everything on the 3808 zone commands. BUT, doesn't appear the 3803 has any type of "trigger in"
A little research dug up the "remote ID" function on the 3808 (something the 3803 doesn't have). That seems like a decent option but I can't find out how to make the Harmony send remote id 2 signals.
I'd hate to have to buy amps for the gym/patio when I already have the 3803 which has the amps I need.
Any thoughts?
john_a_g is offline
post #2 of 3 Old 03-08-2012, 11:03 AM
allsop4now's Avatar
The Harmony 900 can learn commands from another remote, and I've used that to add "Quick Select" commands from my Denon 2312 remote.
You could add the 3808 as a new "unknown" receiver and let the Harmony learn all the various commands as "remote id 2".
allsop4now is offline
post #3 of 3 Old 03-08-2012, 12:28 PM - Thread Starter
john_a_g's Avatar
Thanks. I guess that is worst case scenario. If I go that route that means I change the 3808 to remote 2 itself. So, can't use the secondary remote for it and I also have to program every key into the harmony.
At least it's an option, but one I hope to avoid if I can.
john_a_g is offline
