Yamaha RXV 1800 multichannel inputs issue - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 36 Old 03-08-2012, 05:07 PM
YeuEmMaiMai's Avatar
*wonders where the deception is?*
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #32 of 36 Old 03-08-2012, 05:11 PM
M Code's Avatar
Quoted: 791 Post(s)
Liked: 481
Originally Posted by Remonster View Post
Why would it matter? Once anything is recorded digitally, it's nothing more than a series of ones and zeroes representing an audible signal. All a DAC has to do is convert those ones and zeroes into an analog waveform. That is the beginning, middle and end of a DAC's job.
Just because you spent money on a new DAC (five times) and think you heard an improvement each time, doesn't make it necessarily so. The unfortunate reality is the human brain is easily deceived by preconceived notions, but there is no arguing with the science.
I want to be clear about one thing: I am not saying every single DAC sounds the same as every single other one, many of them seem to have been built with equalization (for example a bass boost) that makes them more pleasing to audiophiles who think it's a good idea to buy an entire chain of components which each colors the sound, but the majority of mainsteam DACs (especially when it comes to the ones found in AVRs) are just designed to do their job without artificially coloring the sound and among those, you will never, ever hear a difference.
There are major differences in DACs for their electrical performance specifications..
See the below link..
http://www.cirrus.com/en/products/d-a_converters.html
Next check the 1st DAC, CS4334 now compare its specs to the CS 4398, the differences are quite significant.. As you may know Crystal/Cirrus Logic is one of the larger supplier of DACs to the audio, automotive and CE product segments.
For your info..
The cost difference in 100K qtys the cost of the 4398 is 8x the cost of the 4334..
Another good demo comparison for DACs is to take an iPod and AVR that can play its iPod audio digitally through USB..
Denon, Pioneer and Onkyo have models that can do this. Next connect a simple 3.5 m/m cable > RCAs from the iPod Line Out to a stereo input on the AVR, also connect the OE iPod cable through USB. Select a good quality audio track and compare the analog audio to the digital audio, there is a very big audible difference.
Keep in mind, the audibles differences are not just the DAC but related to the overall circuit design, however this part is a major contributor to the sonic differences..
Just my $0.02...
M Code is online now
post #33 of 36 Old 03-09-2012, 07:13 AM - Thread Starter
glmoneo's Avatar
This just in from the Yamaha rep that answered that the analog inputs had to go through the DAC and DSP:
"Actually after further investigation it does not touch any Digital chips and would be true analog."
All righty then.
glmoneo is offline
post #34 of 36 Old 03-09-2012, 07:29 AM
DonH50's Avatar
Quoted: 2105 Post(s)
Liked: 1666
For your info..
Just my $0.02...
I suspect the differences, wide as they look on paper, are not audible, at least as far as the DAC chips themselves are concerned. As you say, the rest of the circuitry probably drives the sound differences. I doubt an iPod has the same buffering and isolation as your AVR or an outboard DAC.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #35 of 36 Old 03-09-2012, 07:38 AM
Super Moderator
markrubin's Avatar
Quoted: 1223 Post(s)
Liked: 2701
thread title edited for clarity/ no need for the drama
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
Test Reports HDMI Cables that support 18GBPS&HDMI 2.0b
markrubin is offline
post #36 of 36 Old 03-09-2012, 09:02 AM
Super Moderator
markrubin's Avatar
Liked: 2701
thread cleanup
limit posts to technical issues
