TV has no optical digital output - help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 03-10-2012, 02:07 AM - Thread Starter
AgentK8's Avatar
I'm possibly buying a TV from a friend but it apparently does not have a "digital optical" output.
Currently I have PS3 to TV via HDMI, and a digital optical cable from my current TV to my surround sound.
If it get the tv without the digital optical, what will be effected and can I fix this with a different type of cable at all? I'm new to all this stuff. PLEASE HELP.
Cheers.
AgentK8 is offline
post #2 of 17 Old 03-10-2012, 05:22 AM
jdsmoothie's Avatar
Quoted: 12176 Post(s)
Liked: 5548
Why are you connecting the PS3 (HDMI) to the TV and not to the receiver? Receiver not HDMI capable? Not HDMI 1.4 for 3D? At the very least you'll want to connect the PS3(HDMI) to the TV with PS3 (optical) to the receiver.
jdsmoothie is offline
post #3 of 17 Old 03-10-2012, 06:05 AM - Thread Starter
AgentK8's Avatar
Thanks for your help, I really have no idea about this stuff at all... So I should connect PS3 to the TV with HDMI and connect the PS3 to the receiver with optical?
What will this change the quality of?
AgentK8 is offline
post #4 of 17 Old 03-10-2012, 06:15 AM
jdsmoothie's Avatar
Liked: 5548
First answer my question ....
post #5 of 17 Old 03-10-2012, 06:26 AM - Thread Starter
AgentK8's Avatar
Answer to why is - I don't know, someone else originally hooked it up. The receiver does have a HDMI output yes.
AgentK8 is offline
post #6 of 17 Old 03-10-2012, 06:37 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi AgentK8, you might get more helpful suggestions and answers if you post back with the brand and model of the receiver or surround sound system.
JChin is offline
post #7 of 17 Old 03-10-2012, 07:57 AM
jdsmoothie's Avatar
Liked: 5548
What model TV do you have? What model receiver do you have? If you're not watching 3D movies through the PS3, then you'll want to connect the PS3 (HDMI) directly to the receiver (bypassing the TV all together). The person who set it up likely didn't have a receiver originally.
post #8 of 17 Old 03-10-2012, 08:25 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Most TVs limit their digital audio outputs to stereo when the source equipment is attached using HDMI. So, if you attach your PS3 to the TV and use the TV's digital output to send audio to the sound system, you'll get stereo while, if you run audio direct to the sound system, you'll get true surround sound. There's no way to know the best way to wire up your system without model numbers of all the gear.
BIslander is offline
post #9 of 17 Old 03-10-2012, 02:09 PM - Thread Starter
AgentK8's Avatar
The receiver is a Panasonic SA-BTT755.
It was originally set up as is with the same receiver.
The proposed tv (friend selling and bigger than what I currently have) is a "Uniden".
AgentK8 is offline
post #10 of 17 Old 03-10-2012, 02:12 PM
jdsmoothie's Avatar
Liked: 5548
Then your best connection would be HDMI from the PS3 directly to the receiver so it can play the DD/DTS multi channel surround audio rather than only stereo 2.0 from the TV.
post #11 of 17 Old 03-10-2012, 02:47 PM - Thread Starter
AgentK8's Avatar
Even if the sound for the TV currently isn't used when using the PS3? It still comes via the receiver - which is connected to the (current/old) tv at the moment with optical... which is why I was concerned about a TV with no optical output socket.
And if it connect the PS3 to the receiver with HDMI, does the PS3 still need to be connected to the TV with a seperate HDMI?
AgentK8 is offline
post #12 of 17 Old 03-10-2012, 03:00 PM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 758
What you guys failed to realize is that his Panasonic SA-BTT755 has no HDMI inputs. Just a single HDMI out which is due to the built in blu ray player.
It has one optical input so he can connect the PS3 directly to the TV with a HDMI cable and use an optical cable for audio from the PS3 to the receiver. He'll probably need to change the audio settings on the PS3.
Afro GT
afrogt is offline
post #13 of 17 Old 03-10-2012, 03:17 PM - Thread Starter
AgentK8's Avatar
Thanks Afro.
What would I need to change ps3 audio settings to?
And what difference/improvement would this change make to the current setup?
AgentK8
(she
AgentK8 is offline
post #14 of 17 Old 03-10-2012, 06:08 PM
jdsmoothie's Avatar
Liked: 5548
Setting the PS3 to output video via HDMI to the TV and audio via optical to the PS3 will get you the better quality DD/DTS 5.1 audio rather than only PCM 2.0 from the TV.
post #15 of 17 Old 03-10-2012, 06:53 PM
afrogt's Avatar
Liked: 758
Thanks Afro.
AgentK8
(she
Don't know, I don't own a PS3. You can find it in the manual though or one of the thousands of PS3 threads online.
You'll get Dolby Digital 5.1 and DTS from your movies or games instead of what you were getting before.
Afro GT
afrogt is offline
post #16 of 17 Old 03-10-2012, 07:41 PM
YeuEmMaiMai's Avatar
There are some limitations to optical out on the PS3
Nothing more than 5.1 comes out so the PS3 will automatically downmix anything above that when it uses optical out. I believe that you have to tell the PS3 to enable optical when you use HDMI...
lip sync issues may arise if your TV does ANY type of processing to the video input you may or may not be able to correct for this in your receiver
afrogt is right HDMI to TV, Optical to the receiver
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #17 of 17 Old 03-10-2012, 08:16 PM - Thread Starter
AgentK8's Avatar
Thanks so much guys - you rock!
AgentK8 is offline
