Do I need to disable anything when using a receiver as a pre-amp? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-15-2012, 10:46 AM - Thread Starter
JoeMG's Avatar
Using my Onkyo TX-SR875 as a pre-amp, do I need to turn anything off in the receiver to disable the built-in amp section? Or just plug the pre-outs to the amp and proceed as usual?
JoeMG is offline
post #2 of 7 Old 03-15-2012, 11:59 AM
ccotenj's Avatar
Liked: 101
nope... just connect to the pre-outs, and away you go...
the amplifiers will still be "on" and "idling"... however, they will never do more than "idle" since you will not have a load connected to them...
- chris
ccotenj is offline
post #3 of 7 Old 03-15-2012, 12:25 PM - Thread Starter
JoeMG's Avatar
Great! Thanks!
JoeMG is offline
post #4 of 7 Old 03-15-2012, 04:37 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 150
I've only heard of a few receivers where the amp circuits could be turned off. They may drain some power, and run a little warm, but I feel the main heat source and power drain is probably from all the integrated circuits in these things...CPU, HDMI, video chips, etc.
I suspect, but have no direct evidence, that they may be a bit more efficient in recent years than they were 3 to 4 years ago, via a reduction in chip count.
"But this one goes up to 11"
MichaelJHuman is offline
post #5 of 7 Old 03-15-2012, 06:59 PM
keyboardcat's Avatar
I saw a post a few months ago on here where the guy said that he had trouble with using the onkyo receiver as a pre amp. The repair shop told him that he will keep having the problems with it if he keeps using it as a pre amp. He had to work on the guys receiver several times. He said that older receivers are fine using it as a pre amp, but newer receivers are having problems with it.
keyboardcat is offline
post #6 of 7 Old 03-15-2012, 07:02 PM
ccotenj's Avatar
Liked: 101
that would fall under the category of "bs"...
- chris
ccotenj is offline
post #7 of 7 Old 03-15-2012, 07:17 PM
Quoted: 266 Post(s)
Liked: 150
I feel like an assertion like that is in need of proof.
a) That would constitute a design flaw
b) How can a line level output connected to a bigh impedance input result in issues with a receiver? That's the only connection between the amp and the receiver?
