Receiver that will send CEC signals TO the display? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-15-2012, 02:57 PM - Thread Starter
EGOvoruhk's Avatar
I've got an old plasma monitor that was used as sort of a digital signage, but now I'm repurposing it as an HDTV. The problem is, there's no IR port for remote control, and the only way to turn it on/off is by literally plugging it in. The panel used to go to sleep and wake up via the proprietary box (which had a remote) that would push content to it, and all that had was an HDMI cable, so I assume it sent a CEC signal to the display letting it know to wake up (or sleep)
My current receiver (TX-NR708) doesn't seem to support turning the TV on/off via CEC from the receiver, just turning the receiver on/off via CEC from the TV. Are there any brands of receivers out there that support both directions?
EGOvoruhk is offline
post #2 of 5 Old 03-15-2012, 03:06 PM
YeuEmMaiMai's Avatar
I believe that the Yamaha may do it (ie TV or Receiver turns the other on)
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #3 of 5 Old 03-21-2012, 01:09 PM - Thread Starter
EGOvoruhk's Avatar
Bump for more eyes/solid information
Thanks in advance
post #4 of 5 Old 03-21-2012, 01:13 PM
ccotenj's Avatar
Liked: 101
i wouldn't "assume" anything... it's entirely possible that it "wakes on input"...
what's the make/model of the monitor?
cec, by definition, is bi-directional..
- chris
ccotenj is offline
post #5 of 5 Old 03-21-2012, 01:22 PM - Thread Starter
EGOvoruhk's Avatar
Sadly it doesn't go to sleep when there's no HDMI signal, or the cable is unplugged
It's completely brandless. I'll have to open the back panel when I get a chance to see if there's any panel information
But my current receiver doesn't seem to support both directions. When I have it hooked up to a normal Sony KDL-40EX720, the receiver turns on when I use the HDTV remote to turn on the TV, but if I use the receiver remote to turn on the receiver, the HDTV stays doesn't turn on
