Using a Receiver Amp Section to Power Pre/Pro - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-21-2012, 09:39 PM - Thread Starter
AVGeek99's Avatar
Quoted: 44 Post(s)
Liked: 37
I know this scenario isn't ideal but if you are in the position where you need to use the amp section of a receiver to power a Pre/Pro here are some instructions. I was forced into an early upgrade so am doing this now. I was given some ideas but I couldn't find any explicit instructions anywhere so maybe these will help someone in the future.
1. Do a factory reset on the receiver
2. Connect DVD/BRD player to receiver
3. Use a setup disc that has test tones, I used my old Digital Video Essentials DVD
4. Play the test tones from the set up disc and measure output with an SPL meter
5. Turn the volume up on the receiver until the output = 75db
6. Make note of the volume setting of the receiver; always set the volume of the receiver to that setting and never change it
7. Use the multi-channel input on the receiver and any direct or pure audio mode so there is no additional processing done in the receiver
AVGeek99 is online now
post #2 of 2 Old 03-21-2012, 10:59 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Those are pretty much the steps I would follow as well
"But this one goes up to 11"
MichaelJHuman is offline
