High Freq boost - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-23-2012, 08:53 PM - Thread Starter
larrylwill's Avatar
Quoted: 29 Post(s)
I have a Pioneer VSX-521 as part of my Home Theater system.
Like most people over 60 I have high frequency loss in my hearing. The wife hears things I don't like ringing phones, bells, etc that I do not. If I turn the volume up I can hear them but its too loud for her. In the old days I could insert a equalizer between the pre and power amp as most amps had pre amp out and amp in connectors. Now they don't and the freq adjust is just not enough.
I have decent speakers and a 67" 3D Tv. Is there anything I can do to boost the highs without having to buy a new separate pre amp and power amp? Do they make anything I can put between the amp and speakers that wont break the bank? or does sombody have any ideas? I can't be the only one with this problem.
larrylwill is offline
post #2 of 8 Old 03-24-2012, 08:22 AM
Kal Rubinson's Avatar
Quoted: 771 Post(s)
Liked: 542
Have you tried using the treble adjustment on your remote control?
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 8 Old 03-24-2012, 08:54 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
Whatever happened to super tweeters?
"But this one goes up to 11"
MichaelJHuman is offline
post #4 of 8 Old 03-24-2012, 09:06 AM - Thread Starter
larrylwill's Avatar
Quoted: 29 Post(s)
As I said "Now they don't and the freq adjust is just not enough." Besides my remote control doesn't have a treble control. ;<)
The treble adj on my AMP is not enough and earphones are a pain since I wear glasses. Yes maybe a super tweeter would work but what did happen to them. Everything is getting like gloves, one size fits all.
post #5 of 8 Old 03-24-2012, 09:38 AM
Quoted: 771 Post(s)
Liked: 542
According to the manual on Pioneer's website, it does. Also, I was not clear on what you had meant by "the freq adjust."
I doubt it would be a help to you as supertweeters extend the FR higher but do not increase the output in the normal range.
There are AVRs with built-in graphic EQs that might help you but I wonder if bumping up the treble might be as annoying to your wife as bumping up the loudness.
Kal Rubinson
post #6 of 8 Old 03-24-2012, 09:41 AM
Quoted: 266 Post(s)
Liked: 151
Sorry, I was kind of joking about the super tweeters. Yeah, I wonder if you tried to boost the treble if other listeners might find that annoying.
I take it you still have some ability to hear higher freqs? If not, I don't think boosting HF will help.
post #7 of 8 Old 03-24-2012, 09:44 AM - Thread Starter
larrylwill's Avatar
Quoted: 29 Post(s)
I was just looking at some, their pretty cheap and people report that some I looked at boosted the highs 6-8db. My system uses a harmon kardon 5.1 surround sound speaker set. The surround left right and center speaker are pretty small about 10" x 4 x 4. The amplified sub woofer is about 18x12 x 12. I supposed its worth a try. As for the wife their pretty directional so I could aim them at my end of the couch. Might be worth a try.
post #8 of 8 Old 03-24-2012, 09:46 AM - Thread Starter
larrylwill's Avatar
Quoted: 29 Post(s)
Well if turn up the volume I can hear what she hears. If I use earphones I can also hear it I have tried wireless ones but loose the surround and the phones hurrt my head due to the glasses.
Not really a joke all the old speaker systems had them just to balance out the highs with the mid and low range.
