Xpa-5 w/pio1016 or upgrade receiver to Marantz 7005 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-24-2012, 06:21 AM - Thread Starter
Bigfishe's Avatar
Guys going to be getting an Epsom 8350 soon and was going to look into updating things on the audio side as well. Wanted to hear thoughts on if I would see more benefits from pairing a xpa-5 with my existing pioneer 1016 or would upgrading to something like a Marantz sr7005 would be a better route. Hdmi1.4 a non issue as the 8350 does not do 3d. Speakers are 4- x-mtm's encores with an x-cs encore center with a single mfw-15. In a 20x13' room.
Was curios if anyone thought feeding the x series more power from the emotiva amp would be a noticible difference.
Bigfishe is offline
post #2 of 4 Old 03-26-2012, 01:41 PM - Thread Starter
Bigfishe's Avatar
Bueller.......Bueller.....lol...guess I'm on my own for this one.
Bigfishe is offline
post #3 of 4 Old 03-26-2012, 03:00 PM
ccotenj's Avatar
Liked: 101
i'm starting to sound like a broken record here, but...
if you aren't clipping/putting the avr into protection (which you would have noticed/complained about already), the emo buys you nothing...
a more modern avr, otoh, buys you modern dsp (which actually does do something)...
imo, i would pass on the sr7005 if you go that direction, and either push my budget a bit higher and go for the denon 4311 or push it a little lower for a lower level denon model... see the first 3 posts in the denon xx12 thread for descriptions/features...
- chris
ccotenj is offline
post #4 of 4 Old 03-26-2012, 07:21 PM
jproy13's Avatar
Liked: 26
agreed. If you buy an amp, you will have a VSX-1016 with more power that you probably won't notice because I doubt that you ever ran out of juice in a room that size with your current receiver.
If you get a new receiver, like some of what ccotenj recommended, I'm certain that you will be very please by what a good room correction software will do for you. I have a Denon 2311 in a room slightly bigger and there is no way I'm running it to it's limit at reference level. I'm not sure on your speakers sensitivity but I doubt they are lower then 87db.
cheers
jproy13 is offline
Emotiva Xpa 5 5 Channel Power Amplifier
