Need help selecting Receiver! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-26-2012, 05:31 PM - Thread Starter
Forced_Fool's Avatar
Quoted: 55 Post(s)
Hello, this is my first time on avs forums and just need your opinions on selecting an av receiver.
HELP!!!
For the receiver, i was looking into the denon line (specifically the 1712)
I cant seem to figure out if i should get the 1712, 1912, or 2112.
From what i read the 1712 and 2112 are better than the 1912 in terms of sound quality due to the MultiEq XT against the regular MultiEq.
I don't have an idevice so those features from 1912 and 2112 are useless to me.
Is it worth having internet connectivity for firmware updates? I have a ps3 that has everything i use for now anyway (netflix...) lol
Is there anything better than those Receivers?
Im pretty much trying to stay around $350 for the receiver.
Need Any opinions please not trying to replace this for a couple years and I want to be happy with my purchase.
Forced_Fool is offline
post #2 of 10 Old 03-26-2012, 06:28 PM
Knucklehead90's Avatar
Quoted: 504 Post(s)
Liked: 435
The 2112 has MultEq XT and the other two have 'plain' MultEq. The XT version is better by a tic or two. I'd pick the 2112 for the XT version. Its better and thats a good thing. I doubt you'll find it for $350. Cheapest price I've seen in on accessories4less.com and $100 more that your desired budget. And thats for a refurbished unit. Which is what I'd buy. Get an extended warranty since you are interested in keeping it for a while.
Yamaha CX-A5000 - VTA ST-120 (6550 output tubes) - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - Acurus A100 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #3 of 10 Old 03-26-2012, 06:35 PM - Thread Starter
Quoted: 55 Post(s)
Thanks for the response!
So what is the difference between 2112 and 1712?
I dont really need the internet connectivity unless the firmware updates are really necessary (idk lol).
Is there really any reason i would get the 2112 over 1712 if i didnt have an idevice and didnt need the connectivity?
I appreciate your help i know you probably get this alot.
post #4 of 10 Old 03-26-2012, 08:07 PM - Thread Starter
Quoted: 55 Post(s)
any recommendations?
post #5 of 10 Old 03-26-2012, 08:38 PM
jjackkrash's Avatar
Quoted: 1192 Post(s)
Liked: 1029
If you don't need networking, the 1712 is a fine unit and has the exact same amp section as the 2112. The only thing I am not sure about is its GUI, or if that's important to you, and no usb. The 2112 has airplay, which is a pretty nice feature.
Give Electornics Expo of J&R Electronics or the AVS sales department and see what they can do for you on price. I have had good luck with EE in the past.
Read the first few posts of this thread and then ask questions about Denons in the same thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1334369
jjackkrash is offline
post #6 of 10 Old 03-26-2012, 08:44 PM
Hushed's Avatar
Accurate pricing information can be found in the deals sections http://www.avsforum.com/avs-vb/showthread.php?t=1388096 on the Denons. I just ordered a 2112ci. It seems to be the first model which isn't missing features.
Hit up the Denon thread for an excellent comparison of the different models.
Hushed is offline
post #7 of 10 Old 03-26-2012, 09:30 PM - Thread Starter
Quoted: 55 Post(s)
Thanks guys. So I guess denon is one of the better picks of other receivers? And btw I think 1712 has xt too if im not mistaken.
post #8 of 10 Old 03-26-2012, 11:19 PM
jjackkrash's Avatar
Liked: 1029
^^^^ Correct, the 1712 has XT.
post #9 of 10 Old 03-27-2012, 09:38 AM - Thread Starter
Quoted: 55 Post(s)
Any other competing receivers you would consider besides the 1712?
post #10 of 10 Old 03-27-2012, 07:51 PM
gene c353's Avatar
Quoted: 156 Post(s)
Liked: 114
Consider a factory refurb from ac4l.com to save a little money. Even though the Denon 1712 is the better receiver also consider something like the Pioneer 821 With your total budget you may want to spend a little less on the receiver and a little more on the speakers/subwoofer. Then maybe you can get those Jamo's and the F12/s10.3?
gene c353 is offline
