Need Amp advise AAD2001 with Decco2 - AVS Forum | Home Theater Discussions And Reviews
Old 03-28-2012, 07:23 PM - Thread Starter
nybroker's Avatar
OK I just picked up a pair of AAD2001 monitors rated at only 86db and I have a Decco2 so I know it will not have enough power to drive these properly.
Room size is not very large 12*10*8
I will continue to use the decco2 as a pre-amp
I am considering getting the following
2 Emotiva EPA-1 Monoblocks at 200W each NEW aprox $700
or
PS Trio A-100 150W per channel USED aprox $500
What are your thoughts is it ok to buy used amps?
Any others to consider dont want to spend more than $700 or so
nybroker is offline
Old 04-05-2012, 06:55 PM - Thread Starter
nybroker's Avatar
Anybody cant believe no responses to this question
I am listening them with the 40W Decco and they are producing awesome sound whats an amplifier going to do for them, I mean the windows are not ratteling but the sound is silky smooth bassy and just wonderful
nybroker is offline
