Worth upgrading my receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 03-31-2012, 12:39 PM - Thread Starter
bodean's Avatar
Quoted: 170 Post(s)
Liked: 43
Currently running a 5.1 system in my house.
I have an old Sony STR-DG720 (http://store.sony.com/webapp/wcs/sto...umber=STRDG720)
with Polk Monitor 50 speakers setup in 5.1 format.
I've been looking at a new receiver that will allow me to play my ipod through it. I've had my eyes on the new Yamaha series. Would it be a benefical upgrade to go with a new receiver like this, vs the model I have (which is kind of old)?
As far as sound, will i be noticing enough difference / handling of the sound to make the price in upgrading beneficial?
Sony KDL65W850A 65" LED HDTV  || Bose Soundtouch 130 soundbar || Synology DS716+ NAS || XBOX One ||
Xbox Live : BoDEAN
bodean is offline
post #2 of 18 Old 03-31-2012, 12:41 PM
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
Why not get a ipod dock ?
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is online now
post #3 of 18 Old 03-31-2012, 12:51 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
A newer receiver could give you TrueHD and DTS-MA decoding from Blu Ray, room calibration software, USB port for iPod and other smartphones, better speaker terminals (your Sony has cheap spring clips), more clean power, better bass management. networking, Pandora and internet radio streaming, possible wireless A/V control from iPod, iPad or Android phone.
I could see lots of reasons to upgrade. Just depends how much you're willing to spend.
If you want to go the inexpensive route, then just get an iPod dock.
Afro GT
afrogt is offline
post #4 of 18 Old 03-31-2012, 12:59 PM - Thread Starter
bodean's Avatar
Quoted: 170 Post(s)
Liked: 43
Thanks. Was looking at around $500-800 dollars. Had my eye on the Yamaha RX-V671 which has a lot of nice features (no wifi though).
Xbox Live : BoDEAN
bodean is offline
post #5 of 18 Old 03-31-2012, 01:09 PM
afrogt's Avatar
Liked: 755
For $800 you can do way better than the RX-V671.
Look up the RX-V871, Yamaha RX-A810, Onkyo NR809, Denon AVR-3312, Marantz SR5006 and SR6006, Pioneer VSX-1121, Elite VSX-53 etc.
Afro GT
afrogt is offline
post #6 of 18 Old 03-31-2012, 01:14 PM - Thread Starter
bodean's Avatar
Quoted: 170 Post(s)
Liked: 43
Thanks. Amazon has the Pioneer for 488.88. Not bad at all
Xbox Live : BoDEAN
bodean is offline
post #7 of 18 Old 03-31-2012, 02:38 PM
walbert's Avatar
If you want Yamaha, the RX-V867 is a good choice too; should cost around the same as the 1121. There's lots of options within that $800 range.
I doubt you notice any "sonic differences" apart from what room EQ nets you (assuming there's not a gain mismatch, which there probably is). This could/should be beneficial by itself though.
If you're satisfied with your Sony, just get a dock or output cable and hook up the iPod that way - no reason to spend $600 just to plug in your iPod...
walbert is offline
post #8 of 18 Old 03-31-2012, 03:39 PM - Thread Starter
bodean's Avatar
Quoted: 170 Post(s)
Liked: 43
$800 is a max price range...
Xbox Live : BoDEAN
bodean is offline
post #9 of 18 Old 03-31-2012, 04:10 PM
walbert's Avatar
Oh yeah, none of the models I suggested should approach it either.
walbert is offline
post #10 of 18 Old 03-31-2012, 04:11 PM
afrogt's Avatar
Liked: 755
All the receivers I've recommended can be had at $800 and below if you call or visit the right websites online.
Afro GT
afrogt is offline
post #11 of 18 Old 03-31-2012, 04:16 PM - Thread Starter
bodean's Avatar
Quoted: 170 Post(s)
Liked: 43
Are the models you recommend new models (2012?) Or are they older models?
I found the YAMAHA RX-V867 for 470 (refurbished). Not sure how I feel about refurbished receivers. Any input on this?
Xbox Live : BoDEAN
bodean is offline
post #12 of 18 Old 03-31-2012, 04:18 PM
walbert's Avatar
The models I suggested are "old" but it's not like it matters.
walbert is offline
post #13 of 18 Old 03-31-2012, 04:39 PM
afrogt's Avatar
Liked: 755
The 867 is last years model but still a good one. At one point Newegg sold it for $299 new, but you'll never see that price again since they're no longer in production.
Afro GT
afrogt is offline
post #14 of 18 Old 03-31-2012, 10:34 PM
BullishDad's Avatar
The Yamaha RX-V671 might be available in store at Fry's for $350 if you have a Fry's near you. This is an excellent price and it has networking.
Cablevision - Explorer 8300HD- SARA
Western Digital 250 gb (WD2500KS)
BullishDad is offline
post #15 of 18 Old 03-31-2012, 10:42 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
It's best to buy last year's models on closeout. You can save 100's.
"But this one goes up to 11"
MichaelJHuman is offline
post #16 of 18 Old 09-24-2012, 10:21 AM - Thread Starter
bodean's Avatar
Quoted: 170 Post(s)
Liked: 43
Thanks for all the suggestions. Just moved into my condo, and looking to buy in the next 3 days or so.
I guess 2 important features I need are Airplay (to stream my music from itunes to my receiver, and a good EQ. Most models I see have Audyssey 2EQ which after doing research, isn't very good. Not sure why people say it's not really good, but to avoid that EQ and go with the step up.
Xbox Live : BoDEAN
bodean is offline
post #17 of 18 Old 09-24-2012, 10:29 AM
jdsmoothie's Avatar
Quoted: 12107 Post(s)
Liked: 5509
Primarily because it is the only version of Audyssey unable to EQ the sub which generally needs the most EQ of the setup, not to mention that it is the lowest version of Audyssey, with the next higher version MultEQ having 2x the number of speaker resolution control points as 2EQ and the next higher version above that, MultEQ XT having 16x more speaker control points.
jdsmoothie is offline
post #18 of 18 Old 09-24-2012, 11:00 AM - Thread Starter
bodean's Avatar
Quoted: 170 Post(s)
Liked: 43
Thanks. I think I'm going to go with the Denon DENON AVR-2112CI refurb. 359.99 (649.99 MSRP).
Seems like an awesome value, and has the airplay, and the MultEQ XT
Xbox Live : BoDEAN
bodean is offline
