Denon replacement for Denon 987 (2807) - AVS Forum | Home Theater Discussions And Reviews
Old 04-01-2012, 07:07 AM - Thread Starter
49Merc's Avatar
Quoted: 336 Post(s)
Liked: 73
I may need to replace my Denon AVR 987 (2807). I prefer to stay with Denon. Please recommend a equivalent or better featured model. I will most likely buy it from Best Buy.
LG OLED 55EG9100 HDTV, DirecTV HD DVR Genie HR44, DirecTV AM21 OTA Receiver, Sony BDPS6500 Blu-Ray, Bose Soundtouch 130 HTC (Sound Bar), Panamax MR5100 Power Manager, Harmony Ultimate One Remote, Monoprice AV Cables
LG OLED 55EG9100 Calibrated by Best Buy Geek Squad
49Merc is offline
Old 04-01-2012, 07:19 AM
jdsmoothie's Avatar
Quoted: 12082 Post(s)
Liked: 5502
Depends on what features/inputs/outputs you need as well as your budget of course. Although the 3312CI is the successor to the 2807CI, you could be just as well served with a 2112CI if you don't need the additional features offered by the 3312CI (ie. preouts, dual HDMI outputs, Zone 3, etc.). Review post #2 in the Denon XX12 Owner's thread linked in my sig for a comparison of the various models. Note however, that the new XX13 models are due to be announced in the next few weeks and released in May/June so you may want to wait to see what they offer.
jdsmoothie is online now
Old 04-01-2012, 09:06 PM
Slare's Avatar
If you're going to buy it from Best Buy for one reason or another you are probably going to be best off waiting until the xx12 models hit clearance any day now. Displays will be even less.
Only way to get a Denon at a decent (sometimes excellent) price at BB.
1712 would be the minimum to replace a 2807. Weaker amp, but Audyssey XT which is an upgrade.
Slare is offline
Old 04-01-2012, 09:28 PM - Thread Starter
49Merc's Avatar
Quoted: 336 Post(s)
Liked: 73
Thanks. Audessey doesn't work for our very, very irregular snapped room. I'd not prefer a weaker amp. Hopefully, there is nothing wrong with our 987. Time and tests shall tell.
49Merc is offline
Old 04-02-2012, 05:32 AM
jdsmoothie's Avatar
Liked: 5502
It's unlikely you would notice the difference in power between a 90W AVR (1712) and 110W AVR (987). Also note that Audyssey is not likely working well as it was not setup correctly. Follow the instructions provided in the Setup Guide linked in my sig.
Old 04-02-2012, 06:50 AM - Thread Starter
49Merc's Avatar
Quoted: 336 Post(s)
Liked: 73
Thank you.
49Merc is offline
Old 12-28-2014, 07:59 PM
Withapict's Avatar
Quoted: 54 Post(s)
Liked: 32
Re setting up my avr 987 and curious if anyone really gets to most out of this unit. Any tips or simple changes you might suggest? I like keeping all outputs around 0.0 db as far as levels and have some new 5.1 speakers coming so all will identically match(95 bd). Will also use a pair of subs.
Any tips would be appreciated.
Withapict is offline
Old 12-29-2014, 07:25 AM
jdsmoothie's Avatar
Liked: 5502
Better to post in the Owner's thread. Also review the Audysey 101/FAQ guide.
The "Official" Denon AVR-2807 Thread
