Amplifier capacitors help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-03-2012, 07:19 PM - Thread Starter
Razvanel's Avatar
The power supply capacitors in my Gemstone Blue Diamond amplifier have started leaking. I would like to buy new capacitors to replace the bad ones but I couldn't find any of the same size on the Internet. I don't know who the manufacturer is, maybe someone here has an idea? I've included pics below:
Razvanel is offline
post #2 of 5 Old 04-03-2012, 07:44 PM
M Code's Avatar
Quoted: 798 Post(s)
Liked: 487
Try here..
http://www.mouser.com/ProductDetail/...%2fjn72fM0M%3d
Hold on to your hat they are expensive..
Just my $0.02..
M Code is online now
post #3 of 5 Old 04-03-2012, 07:44 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
They don't have to be the exact size I think. But they need to be spec'd properly, such as the voltage spec. Is gemstone not still in existance to get the specs on?
"But this one goes up to 11"
MichaelJHuman is offline
post #4 of 5 Old 04-03-2012, 08:22 PM
M Code's Avatar
Quoted: 798 Post(s)
Liked: 487
The capacity in uF has a tolerance of -10% & +75%, voltage should be equal or higher...
Just my $0.02..
post #5 of 5 Old 04-03-2012, 08:28 PM - Thread Starter
Razvanel's Avatar
Ideally they should be the same size - especially the diameter and the distance between the screws on the bottom so that they fit into the original board - and specs. Hard to find them... I'm not sure that the Cornell Dubilier in the link above would work but thanks M Code.
Gemstone hasn't replied yet, probably never will. I did contact Sim Audio, they made the amp for Gemstone, but they were not willing to help at all...
Still looking, wonder if anyone knows what the 'A' on the capacitor stands for i.e what company that might be?
R
Razvanel is offline
