Which receiver do you think I should buy? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 04-06-2012, 11:04 PM - Thread Starter
Brian G's Avatar
Thanks for your help with this, despite this question coming up 51 times per day.
My Denon AVR-1909 went completely dead after less than 3 years (actually started to go dead after just a year and a half). Was very disappointed by Denon's customer service when I brought it up, so I don't want another Denon.
What I'm looking for:
  • Number one priority: Top sound quality (yeah, I know speakers are much more important for top sound quality than the receiver - but still want to have the receiver help as much as possible)
  • Secondary priority: Great industrial design (prefer a minimalist aesthetic - don't need a hundred buttons visible)
  • At least 5 HDMI inputs
  • Pretty standard living room size / speaker setup (5 speaker surround setup, not especially power-hungry speakers)
  • Budget of roughly $600, give or take a few hundred
  • No Denons
  • That's about it - stuff like AirPlay support, Audyssey, microphone setup, etc are all cool features, and I'd probably use some of them, but none are nearly as important as the factors above.
Also willing to wait up to 2 months if something much better and newer will be out by then. (Seems like most new models come out in the summer?)
So far, the model I've been looking at the closest is the Yamaha V671, though I feel like the industrial design of the front is a little uninspiring.
Thank you very much for any help!
-Brian
Brian G is offline
post #2 of 17 Old 04-06-2012, 11:54 PM
Venomous's Avatar
  • No Denons
-Brian
The new Yamaha rx series will bring all of that for the price. The Aventage line wont be updated until around October, but the 7xx and 8xx line will have AirPlay most likely when they do come out in the fall.
Onkyos will get you what you want right now but they don't have the best build quality.mdenon and Yamaha are tanks.
Venomous is offline
post #3 of 17 Old 04-07-2012, 01:13 AM - Thread Starter
Brian G's Avatar
So you're recommending to wait for the RX-V673? (Seems like the RX-V473 and RX-V573 just came out - but they each only have 4 HDMI inputs.)
Brian G is offline
post #4 of 17 Old 04-07-2012, 10:07 AM
pronghorn/az's Avatar
Quoted: 20 Post(s)
Liked: 31
The build quality of Yamaha better than Onkyo? Hmmm, that's a first! You can get a great deal on the 9 series of Onkyo, and the 709 and up ARE tanks! The new Onkyo receivers should be coming out in the next couple of months.
Jeff
pronghorn/az is offline
post #5 of 17 Old 04-07-2012, 11:08 AM
JDEaston's Avatar
Jeff
Are you joking? Yamaha is known for their legendary build quality and reliability. Onkyo, in recent years, has been known for the exact opposite.
JDEaston is offline
post #6 of 17 Old 04-07-2012, 02:10 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
I have had good luck with Yamaha.
"But this one goes up to 11"
MichaelJHuman is offline
post #7 of 17 Old 04-07-2012, 02:31 PM
Venomous's Avatar
Jeff
Shows how much experience you have with audio gear. Onkyos are the pintos of avr's.
Venomous is offline
post #8 of 17 Old 04-07-2012, 04:39 PM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
You might consider the Pioneer VSX-1121K. I bought one last fall (due to my Onkyo's HDMI subsystem being a pile of crap), and have been quite satisfied with it. I have it connected to (now) a TiVo Series3, a Panasonic DMP-BD35K, a PlayStation 3 and an Xbox 360 (not the new slim 360, the white Pro unit), and of course my Sony KDL-46XBR8.
I've been happy with my Pioneer on this front - in fact, its auto-calibration system actually picked up on one of my surround channels being phase flipped (the Onkyo's never did catch that). It's rated for 110 watts per channel, so should give you good punch for a "normal" room size.
This Pioneer model has a flip-down front panel for access to USB and composite for iPod/iPhone/iPad connectivity and HDMI front-panel input, but I keep it up most of the time, so the only things you can see are the input select knob, the volume knob and the power button. I think it looks nice.
Has 6 HDMI inputs on the back, and 1 on the front.
It's a 7.1 receiver (I have a 6.1 setup), but obviously 5.1 will work just fine.
I bought mine when it was about $600, but you can get the same unit now on Amazon for $499.
  • No Denons
Done!
It has DLNA sink functionality, AirPlay support, Pioneer MCACC (their equivalent of Audyssey autocalibration, complete with setup mic).
It looks like the VSX-1122K (the new upcoming model) is going to cut down on analog inputs and such. I don't think you'd gain anything by holding off, plus you get the cost savings.
demonfoo is offline
post #9 of 17 Old 04-08-2012, 10:31 AM - Thread Starter
Brian G's Avatar
Thanks, demonfoo - hadn't looked at the Pioneer VSX-1121K before. Will take a look.
If my Denon was a tank, it must have been from WWI.
Brian G is offline
post #10 of 17 Old 04-09-2012, 08:19 AM
oldmp3's Avatar
...Top sound quality
...Great industrial design
...At least 5 HDMI inputs
...Budget of roughly $600, give or take a few hundred
...AirPlay support, Audyssey, microphone setup, etc are all cool features
Consider the Harman Kardon AVR 3600 [only 4 HDMI ports] or the AVR 3650 [6 HDMI ports]. The 3600 is under your budget and hits everything except 5 ports, includes an ipod/iphone cradle.
The 3650 is at the top of your budget, hits everything, and has DLNA network connectivity.
Both have Dolby Volume, a feature I really like.
oldmp3 is offline
post #11 of 17 Old 04-09-2012, 09:34 AM - Thread Starter
Brian G's Avatar
Thanks, oldmp3! Will take a look at those HKs.
Brian G is offline
post #12 of 17 Old 04-09-2012, 09:43 AM
JDEaston's Avatar
Since your original choice was the yamaha 671 check out electronics expo. They have a great deal on those right now, I'm thinking about grabbing one myself, even though I already have a 71 series.
JDEaston is offline
post #13 of 17 Old 04-12-2012, 12:08 AM - Thread Starter
Brian G's Avatar
Wow, awesome deal - $200 off. Hard to turn that down. Thanks for sharing.
Brian G is offline
post #14 of 17 Old 04-12-2012, 02:05 AM
80sGuy's Avatar
Quoted: 179 Post(s)
Liked: 34
^^If you want clean 'industrial design', then harman/kardons are the way to go. I've had two in the past, and one boxed up in the closet and they lasts forever. The only thing I dislike about them was the heat, especially during the summer days, not sure how they are now. When I bought my new receiver last year (needed HDMI) I went with the Denon AVR-2310ci because it was the ONLY one I can find with a Phono Input and an array of analog audio Inputs, otherwise I'd buy another h/k if it wasn't for their lack of inputs.
http://www.amazon.com/gp/product/ima...&s=electronics
80sGuy is offline
post #15 of 17 Old 04-12-2012, 05:53 AM
C0rk's Avatar
Quoted: 34 Post(s)
Liked: 25
I have a 671 and can recommend it based on your specifications. It has much better sound quality than my previous Onkyo and Marantz (the Marantz had DLNA problems so I only had it for a month). For what it's worth, I also think the Yamaha has better build quility than the Onkyo, and I'm including internals in my definition on build quality.
All that said, given your specs I would look hard at the H/Ks. From the reviews I've seen and their general rep they have the best sound and amplifier section and strong build quality. They are lacking on the extras side of things, network support and so on.
C0rk is offline
post #17 of 17 Old 01-02-2013, 09:44 AM
minorc's Avatar
minorc is offline
Receivers Amplifiers , Denon Avr 1909 7 1 Channel Multizone Home Theater Receiver , Yamaha Rx V671 Receiver , Yamaha Rx V473 Receiver , Yamaha Rx V573 Receiver , Onkyo , Pioneer Vsx 1121 K 7 1 Home Theater Receiver Glossy Black , Xbox 360 250gb Console With Kinect
