Denon 4311 or 3312? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 69 Old 05-31-2012, 11:34 AM - Thread Starter
swizzchard's Avatar
Originally Posted by splicer010 View Post
never say never...
she'll never know if you just slip it in there...you know...like you do with sex! J/k of course, well, about the latter, not the former.
:d
swizzchard is offline
post #62 of 69 Old 05-31-2012, 11:52 AM - Thread Starter
swizzchard's Avatar
Even if adding a second sub would actually make the bass sound better/smoother?
http://www.audioholics.com/tweaks/ge...-bass/two-subs
but this isn't a luxurious home theater room. This is a family room, so the decorating aspect of it probably wont pass the wife...
post #63 of 69 Old 05-31-2012, 11:53 AM
KidHorn's Avatar
Quoted: 1377 Post(s)
Liked: 886
Originally Posted by Osamede View Post
Happy to take bets anytime - we all know the biggest "innovation" 4520 will have is 4k upscaling that nobody needs, since any 4k display will do better. You could pretend otherwise, but the product will be what it is in the end: fairly predictable.
It could also support 11 channel neoX and have 11 internal amps. Plus have 4 subwoofer outputs. None of which are huge IMO. I'm generally in agreement with you.
KidHorn is offline
post #64 of 69 Old 05-31-2012, 11:57 AM
jdsmoothie's Avatar
Quoted: 12160 Post(s)
Liked: 5540
If you read the article, you'll note the test was done in a "family room" setup and not a "luxurious home theater room". The point being that most wives would think that adding another sub would result in more boomy bass rather than smoother bass.
jdsmoothie is online now
post #65 of 69 Old 05-31-2012, 12:41 PM
ObiChad's Avatar
For some the issues is likely more "there's no way you are putting another large box in this room" and relatedly "I don't care if it'll sound better / less boomy / 'other sound word' I don't care about".
And by some, I mean me.
ObiChad is offline
post #66 of 69 Old 07-24-2012, 03:18 PM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
I am in need of a AVR..
I have 2 Martin Logan Motion 12s and 4 Martin Logan Motion 10s and 2 Dynamo 500 subwoofers..
Do you think I would be better off going with a 4311 or a 3311 or 3312 and justting a emotiva 3 channel for my lrc?
Holiday121 is offline
post #67 of 69 Old 07-24-2012, 03:33 PM
jdsmoothie's Avatar
Liked: 5540
Not only is the 4311CI a level above the 33XX series, but it can power 4-ohm speakers without issue as well.
post #68 of 69 Old 07-30-2012, 01:34 PM
DIYHomeTheater's Avatar
Upon reading the 4311 owners manual, it seems that if you want to use a combination of the in-built amp and the preouts, you MUST use the built in power amp for 9 channels and an external
amplifier for the two fronts. I already have a 7-channel external power amp, would like to use only 4 of the Denon's channels. It seems that this is not possible. Am I correct?
Thank you
DIYHomeTheater is offline
post #69 of 69 Old 07-30-2012, 02:15 PM
jdsmoothie's Avatar
Liked: 5540
You can use any combination of powered vs. pre-outs, rather you are required to at a minimum externally power the FL/FR or FHL/FHR to expand to 11.2.
