External Sound Card for iMac... - AVS Forum | Home Theater Discussions And Reviews
Old 04-23-2012, 11:14 AM - Thread Starter
Krazy Train's Avatar
First allow me to apologize if this has already been covered in another thread but I searched for about an hour and could not find anything recent on this topic. I'm also not sure if this is even the right sub-tab for this kind of question...but here it goes.
I just recently purchased an iMac computer and would like to use my existing Altec Lansing ADA995 200 Watt THX sound system. Here is the link for the specs of the system
http://www.overstock.com/Electronics...8/product.html
Now the system has one of those "Yellow, Green and Black 3.5mm jacks to connect it to the computer. I can hook it up to the Mic out jack on the back of the Mac to get base but cannot get any other sound from the speakers. I'm assuming it's because the Mac outputs a Digital Signal and the sub and speakers are analog. My question is would it be possible to purchase an external sound card that would solve this problem. Im not even concerned about the surround sound at this point...just the two front speakers and the sub up and running would be more than enough...
Thanks in advance for any and all help on this fellas...and once again, my apologies if this has already been recently covered and or it does not belong in this section.
Krazy Train is offline
Old 04-23-2012, 12:02 PM
Ross Ridge's Avatar
Liked: 81
Connect the green 3.5mm jack from your speakers to line out at the back of your iMac. It should be the first jack closest to the edge.
The audio line out jack at the back of your iMac can either be used as a analogue or a digital optical output. You may need to configure your iMac to use this anlogue output instead of your speakers or the digital optical output.
Ross Ridge is offline
Old 04-23-2012, 12:49 PM - Thread Starter
Well, you solved my problem Ross and I can't thank you enough. I don't know why I was under the impression that the output on the Mac was limited to digital only but I am THRILLED to be wrong in this instance...
Again, thanks for taking the time to help me out here...it's very much appreciated.
