Which is better at matrixing: DSX or PLIIz Height? - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Which is better at matrixing: DSX or PLIIz Height?
PLIIz Height 0 0%
DSX Height 2 100.00%
Voters: 2. You may not vote on this poll
Old 04-26-2012, 07:06 PM - Thread Starter
porschedrifter's Avatar
So i'm curious at which format is better matrixing the height ambiance channel from a standard 7.1 or below source?
Audyssey DSX Height or Dolby's PLIIz Height?
//Onkyo 608 - B&W LCR 60 S3 Center - B&W DM 602 S3 Fronts - TSC TSS & Phase Tech DST Surrounds - B&W ASW600 S3 Subwoofer//
120''+ Screen size club.
"At 20 bits, you are on the verge of dynamic range covering fly-farts-at-20-feet to intolerable pain. Really, what more could we need?"
AudioCheck -...
porschedrifter is offline
Old 04-26-2012, 07:24 PM
sdurani's Avatar
Quoted: 4506 Post(s)
Liked: 2911
DSX doesn't matrix ambience, it uses the contents exclusivelyfrom the front L&R channels to generate proscenium reflections based on concert hall acoustics. By comparison, PLIIz extracts decorrelated (out of phase) ambient information from the surround channels to feed the height speakers.
Sanjay
sdurani is online now
Old 04-26-2012, 07:29 PM - Thread Starter
I see, I wasn't aware but I get the idea of what you are saying.
So in your opinion which would be the more accurate and better method?
AudioCheck -...
Old 04-26-2012, 07:35 PM
M Code's Avatar
Quoted: 718 Post(s)
Liked: 423
The list is incomplete...
You should add DTS Neo X...
Just my $0.02...
M Code is offline
Old 04-26-2012, 07:47 PM - Thread Starter
My 608 doesn't have that
AudioCheck -...
Old 04-26-2012, 08:11 PM
OldSchoolMETAL's Avatar
You should have included Yamaha's Height channels as they have much more experience with this than either of the 2 you mentioned. They have been doing height channels for over 12 years. My old RX-V2095 had these speaker outputs although I never used them. The new models also have them and why they don't offer DSX or DPL IIz (just DPL IIx).
Once again I don't use them but for years Yamaha has always got the thumbs up for great height imaging with their height channels.
OldSchoolMETAL is offline
Old 04-26-2012, 09:07 PM
sdurani's Avatar
Liked: 2911
More accurate to what? If I want to feel like I'm listening in a larger room, then I would use DSX. If I want surround ambience to come from above the front soundstage, then I would use PLIIz. I doubt that film makers and their sound mixers intended for either of those effects, so I'm not sure whether I'd consider either one "accurate".
Sanjay
