New Denon AVR-1712 No Audio From TV - AVS Forum | Home Theater Discussions And Reviews
Old 04-29-2012, 06:01 PM - Thread Starter
chrismgan's Avatar
I was hoping someone might help as it's Sunday night and Denon support is closed. I've just hooked up my new receiver and can't seem to get audio from the TV. I've got the HDMI cable running from the TV to the Monitor ARC input on the receiver. No audio from the TV- great picture but no audio. The DVD unit works fine- video and audio. The TV is an LG. If anyone has any suggestions, I'd really appreciate them.
Chris
chrismgan is offline
Old 04-29-2012, 06:09 PM
jdsmoothie's Avatar
Quoted: 12103 Post(s)
Liked: 5508
To enable the ARC feature you must enable HDMI-CEC (SimpLink) on the LG as well as on the AVR (HDMI Control).
For more information on your new 1712, join us in the Denon XX12 Owner's thread linked in my sig, especially reviewing post #3 in that thread.
jdsmoothie is offline
Old 04-29-2012, 06:16 PM - Thread Starter
chrismgan's Avatar
Thanks- The SimpLink is enabled on the LG, however I'm not sure how to enable the AVR?
Old 04-29-2012, 06:20 PM
jdsmoothie's Avatar
Liked: 5508
See HDMI Control (p. 63) in your Owner's manual.
Old 04-29-2012, 06:28 PM - Thread Starter
chrismgan's Avatar
Call me a dummy, but I'm reading pg 63 and can't figure out how to get to "select HDMI audio output device". Do I press something on the remote?
Old 04-29-2012, 07:38 PM
jdsmoothie's Avatar
Liked: 5508
System Setup ---> HDMI Setup ---> HDMI Control (defaults to OFF, set to ON)
Old 04-29-2012, 08:02 PM - Thread Starter
chrismgan's Avatar
Ok Thanks I've set the HDMI Control to ON and I still don't have any audio from my speakers. Any other suggestions? Thanks for all your help. I'm not using cable or Sat by the way, I'm receiving my signal over the air by antenna. Not sure if that makes any difference, it didn't with my old amp.
Old 04-29-2012, 08:11 PM
jdsmoothie's Avatar
Liked: 5508
Ensure the TV is to "external speakers". Once set, power off the TV and AVR and then power ON again. If still no joy, connect an optical cable from the TV to the AVR for the short term until you can resolve the issue.
Old 04-29-2012, 09:41 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
optical cable from TV to receiver will solve all your problems.
Afro GT
afrogt is online now
Old 04-30-2012, 02:03 AM - Thread Starter
chrismgan's Avatar
Ok, I'll try an optical cable. Thanks for all the help.
Old 04-30-2012, 11:43 AM
tarzan1234's Avatar
I'm having the exact same problem as the OP. I just replaced my Yahama receiver with a Denon 1712 for Audyssey MultiEQ XT. ARC worked on my Yamaha just fine but when I hooked up my Denon, turned ARC function on and no sounds came out. Everything else worked just fine, including stand-by pass through. I'm not sure if I just had bad luck with a defective unit or there's some compatibility between my Panasonic Plasma with Denon receiver. Anybody else has ARC problems with Denon receiver and Panasonic TV? If it's actually compatibility issue, I shouldn't waste my time to exchange it and just get an optical cable. I can live with that. But if my unit is defective, I should ask for an exchange.
tarzan1234 is offline
Old 04-30-2012, 12:34 PM
Possumgirl's Avatar
Liked: 58
Perhaps not what you wanted to hear, but no ARC problems between my Panny ST30 and Denon 1612. I watch OTA TV and sometimes use the Panny internet apps. As soon as I enabled Denon's HDMI-CTL, it all worked.
Possumgirl is offline
Old 04-30-2012, 01:33 PM
tarzan1234's Avatar
Thanks Possumgirl. In fact, this is exactly the confirmation I wanted to hear. This is a good time to appreciate Amazon's superb services...
Old 04-30-2012, 01:36 PM - Thread Starter
chrismgan's Avatar
I on the other hand am still without audio from the TV even after hooking up an optical cable. Any thoughts ?
Old 04-30-2012, 01:52 PM
tarzan1234's Avatar
Have you tried to re-run the setup wizard? No need to repeat the the entire process, just jump to Input setup section and select a connection for TV.
Old 04-30-2012, 01:58 PM - Thread Starter
chrismgan's Avatar
I'll give it a shot now. Thanks
Old 04-30-2012, 02:01 PM - Thread Starter
chrismgan's Avatar
That did it! Thanks so much !
Whoops- Only getting sound from two speakers on a 5.1 system.
Denon Avr 1712 Receiver
