The "official" Yamaha RX-V673 thread. 7.2-Channel Network AVR - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 54Likes
Old 08-26-2012, 04:44 PM
JD NC's Avatar
Liked: 40
Originally Posted by runningman28 View Post
I have a htr 5660 which works fine but doesn't have hdmi. I use the opitical out with my blu ray. Im wondering is there a significant change in audio quality in this new model in playing music?
I can't compare the V673 to previous Yamaha AVRs re: music, but the 673 is certainly a good music performer. The upgrade to HDMI will also give you full HD audio output from your bluray. The optical cable doesn't output the full DTS HD-MA or Dobly TrueHD bitstream to the receiver, only HDMI is able to pass through the audio at the full resolution.
JD NC is offline
Old 08-26-2012, 08:24 PM
Flavius's Avatar
Liked: 46
How does the V673 decide to use Dolby EX vs DTS ES for the surround back channel(s) for 5.1 sources? I know you set ES/EX in the Options, but how does it decide? It gave me Dolby EX for a DTS HD MA 5.1 track.. Should it not give me DTS ES? Help!
Flavius is offline
Old 08-27-2012, 03:23 AM
Gmash's Avatar
Quoted: 144 Post(s)
Liked: 142
Originally Posted by Neil-007 View Post
Hi,
I am just a real newbie with regards to these modern A/V Receivers. Mine is a 22 year old Sony that I want to dump and go with a Yamaha 671 but the 673 sounds a bit appealing. Here are my questions (any help would be greatly appreciated):
1. PANDORA: I DO NOT plan on hooking up my receiver and speakers to a TV. I am leaning towards the 671 since it has built-in Pandora. But how the heck can I play, say, "Born in the USA" by the Boss via the receiver if I cannot see a screen? I know on my laptop I can just go to Pandora.com, log in and type in "Bruce Springsteen" and I can play it on my laptop that way. But the receiver does not have a screen and how the heck do I type? By the way, I am too old for DLNA, AirPlay, etc., so I am not going to use (nor have) an iPhone/iPad, etc., nor do I want to sync my laptop to the network and connect to the receiver.
But I DO want to play internet radio, especially Pandora (which is why most likely I would not go with a 673 but buy a 671).
2. I noticed the 673 is only 90 watts whereas the 671 is 105 watts......so why the heck is an "improved" 673 down on power? Is this another reason I should NOT go with the 673?
Pretty much all of the set up options are done via on screen menus. I wouldn't recommend this receiver if you're not planning on hooking it up to a TV.
Gmash is offline
Old 08-27-2012, 09:42 PM
DeadEd's Avatar
Quoted: 85 Post(s)
Liked: 167
Two questions about this:
1) How do you update? I read the manual. It says that if an update is available it will be offered automatically. But is there no place to manually update it?
2) What if you are not on the internet? You should still be able to update the firmware. The manual says to download the update from their website, put it on an USB drive, and update that way. But I can't find ANY firmware to download on their site. Has anyone found where they keep their firmware files?
UPDATE........UPDATE....UPDATE!!!!
The local Video Only store here says they received a fax memo (to dealers) from Yamaha that PANDORA will be added with a firmware update sometime in 3rd week of August 2012..............
Dyslexics are teople poo.
DeadEd is online now
Old 08-28-2012, 01:50 AM
Bond 007's Avatar
Quoted: 2375 Post(s)
Liked: 1911
Does anyone have Pandora on their 673 yet?
Licence to Kill
Bond 007 is offline
Old 08-28-2012, 06:36 AM
JD NC's Avatar
Liked: 40
I was wondering the same thing. I looked for manual update settings and found none. I imagine it just polls the Yamaha server daily or weekly for updates if it's connected to the network. I expect once the auto-updates start, the update will also be posted to the website for USB installs.
JD NC is offline
Old 08-28-2012, 08:30 AM
kkiran's Avatar
I am not much of an audiophile, never installed a 5.1 or 7.1 system for that matter. Waited so long for a future-proof receiver and finally bought it.
I would like zone 2 for bedroom. Do you think Polk Audio OWM3 has the necessary ratings for this receiver? I understand that there are several limitations on Zone 2 - no airplay, makes the system 5.1 when turned on.
Please suggest if Polk Audio OWM3 works with this receiver. My interests are 5.1 in the living room and zone 2 in the bedroom.
kkiran is offline
Old 08-29-2012, 06:41 AM
jdsmoothie's Avatar
Quoted: 12168 Post(s)
Liked: 5545
Those speakers should work fine as Zone 2 speakers. Airplay can pass to Zone 2 speakers on Denon AVRs so can likely do the same with the Yamaha as well.
jdsmoothie is offline
Old 08-29-2012, 07:10 AM
yamahobbes's Avatar
According to the Yamaha press release...
http://usa.yamaha.com/news_events/audio_visual/yamaha_av_receiver_firmware_updates_provide_pandora_and_napster_music_services/
The downloads will be kept under the "Support" tab on the product page...
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v673_black_u/?mode=model
I'm not seeing any update... so perhaps it hasn't been released yet.
As possible confirmation, my recently shipped unit (connected to the net) says that it's current firmware is up to date; suggesting that there isn't an update yet available.
yamahobbes is offline
Old 08-29-2012, 07:21 AM
yamahobbes's Avatar
Also regarding the firmware update...
According to the press release: "Yamaha Electronics Corporation today announced the latest firmware updates for selected AV receivers within their popular RX-V series..."
The key word there is "SELECTED." Currently, within the RX-V series, it appears to only be offered for the RX-V867. Perhaps it will be offered for the 673 - perhaps not.
Old 08-29-2012, 10:57 PM
Flavius's Avatar
Liked: 46
Need help again: I want to use the SOURCE OFF button on the left of the remote to turn off my TV. Not the tiny TV power button on the lower right. I got that tiny button to work, but any idea how to get the Source power button to work for a Samsung TV with code 0076?
Or even better, how can I turn off my TV and receiver at the same time using the receiver's power off button? I think I got it to work the other way around with HDMI-CEC settings (very confusing).
Flavius is offline
Old 08-29-2012, 11:40 PM
DeadEd's Avatar
Quoted: 85 Post(s)
Liked: 167
Old 08-30-2012, 06:15 AM
yamahobbes's Avatar
Originally Posted by Flavius View Post
... how can I turn off my TV and receiver at the same time using the receiver's power off button? I think I got it to work the other way around with HDMI-CEC settings (very confusing).
I bit the bullet and purchased a new universal remote.
http://www.amazon.com/Logitech-Harmony-Universal-Remote-Touchscreen/dp/B002RL875A/ref=sr_1_1?ie=UTF8&qid=1346328061&sr=8-1&keywords=harmony+one
Setting it up was a breeze!... very intuitive.
You establish "activities"... such as - Watch TV. Then one button turns on/off the appropriate equipment; making the correct settings on the TV/AVR/Cable box.
Changing "activities" is as easy as pressing another button "Radio", for example. (TV/Cable turns off, ARV switched to tuner, Sound field changed, etc)
Turning off all of the equipment is, again, just one button.
So far, I'm pretty impressed.
Old 08-30-2012, 07:06 AM
kriktsemaj99's Avatar
Quoted: 636 Post(s)
Liked: 358
That press release is over a year old and has nothing to do with the rumoured update for the 673. But so far I think it's just a rumour, so don't count on it.
kriktsemaj99 is offline
Old 08-30-2012, 11:54 AM
Flavius's Avatar
Liked: 46
Not an option for me. Logitech is too cheap to include a simple Bluetooth transmitter so it will work with the PS3 without an adapter.
Just want to be able to turn the TV and receiver on at the same time from the receiver remote using either 1 button, or the Source power button, not the TV power button.
Flavius is offline
Old 08-31-2012, 12:24 AM
Nick Burns's Avatar
Just ordered the v673 with delivery on 9/9. This is my very first foray into HT receivers. Does anyone have recommendations on a set of speakers? - 7.1 since I will not be using the Zone 2 feature.
I was wondering if there were any "wireless" options, or if that's even recommended.
Thanks for a wonderful thread. I purchased this unit before I even found this thread. Now I'm very happy with the choice!
Not as lean
Not as mean
Still a Marine.
Nick Burns is offline
Old 08-31-2012, 05:08 AM
Bond 007's Avatar
Liked: 1911
The obvious question would be how much are you willing to spend?
Licence to Kill
Bond 007 is offline
Old 08-31-2012, 07:26 AM
two40's Avatar
Can someone confirm this? Does Airplay pass to Zone 2?
One of the big selling points for me of it does.
two40 is offline
Old 08-31-2012, 08:00 AM
JD NC's Avatar
Liked: 40
Yes, you can pass Airplay to zone 2. Page 74 of the manual has instructions for sending different audio sources to zone 2, and airplay is included.
You can't have the same source playing on zone 1 and zone 2 simultaneously, though. This is "party mode" and you need the V773 for this feature.
JD NC is offline
Old 08-31-2012, 08:01 AM
Nick Burns's Avatar
lol, biggrin.gif I actually anticipated this question and I did forget to mention my budget... since I was able to get the v673 for $325 (that includes Tax,S&H), I can budget ~$500 towards the speakers.
Not as lean
Not as mean
Still a Marine.
Old 08-31-2012, 08:32 AM
JD NC's Avatar
Liked: 40
Eep, that's a tight budget for a complete 7.1 system (including subwoofer, I assume)? I'd suggest getting a 5.1 system with an eye toward easy upgrades down the road. Check out the Definitive Technology ProCinema 400 ($600). You may find the sub to be underpowered for your larger room, but you can upgrade with a second sub or replace with a larger sub at any time. Also, you can easily get upgraded L/R/C satellites and convert the old L/R procinema satellites into your rear channels. When in doubt, spend extra on the sub and center channel.
That's a great price you got for the V673. You're likely to go through multiple speaker upgrades before you need to worry about getting a new AVR. Enjoy!
JD NC is offline
Old 08-31-2012, 10:55 AM
Bond 007's Avatar
Liked: 1911
http://www.amazon.com/Klipsch-QUINTET-Speaker-System-Black/dp/B002HWRKA2/ref=sr_ob_5?s=electronics&ie=UTF8&qid=1346431652&sr=1-5. This is a great deal and are excellet speakers for the money. Get a BIC F12 475 watt sub for around $200 that will kill the Definitive sub and you are right at your $500 mark.http://www.amazon.com/BIC-AMERICA-DV-32B-Shielded-Speakers/dp/B00006JPDF/ref=sr_1_7?s=electronics&ie=UTF8&qid=1346433676&sr=1-7&keywords=bic+speakers+pair. Just ran across these. These are well matched to the Klipsch and would do very well for back or prescence speakers. 7.1 for $550.
Licence to Kill
Bond 007 is offline
Old 08-31-2012, 07:44 PM
rothlike's Avatar
I've been using Harmony remotes for years, convenience can't be beat...
Here's a great deal....
Logitech has the refurbished Logitech Harmony One Advanced Universal Remote Control for $130 - $40 off with coupon code logi_h1_83112 [Exp 9/3] = $90 with free shipping. Features color touchscreen, backlit buttons and rechargeable battery.
http://www.logitech.com/en-us/promotional-items/7193?WT.mc_id=amr_affiliate_cj_us&ci=0
Cheers! Big Rich
rothlike is offline
Old 08-31-2012, 09:13 PM
Bond 007's Avatar
Liked: 1911
For $10 more you can get it brand new at Amazon or depending on how many devices you have you can save $60 and get the 700. The 650 is fine with me. Logitech is basically charging $40 for the rechargable battery. For $40 and can get enough batteries to last longer than the remote will.
Licence to Kill
Bond 007 is offline
Old 08-31-2012, 11:15 PM
Flavius's Avatar
Liked: 46
The BIC F12 is terrible advice, esepcially for those small speakers. Much better is the Energy ESW-M8. I actually auditioned both these subs in my house with a small matched mains and satellite 6.1 system on this receiver. The F12 is a muddy mess, and all it has going for it is volume. The ESW-M8 can be plenty loud for a living room, but the sound quality is leagues better and better matched to small speakers. The BIC F12 is a boomy and bloated sounding. The Energy is super tight and nuanced. Way better for music, and even for movies unless you like to play your movies at volumes that rattle every wall in your house. Btw, Energy is owned by Klipsch. The ESW-M8 is only $100 more than the BIC F12. But it sounds like $500 more.
Flavius is offline
Old 09-01-2012, 03:42 AM
Bond 007's Avatar
Liked: 1911
I dont know about terrible advice. What you say about the ESW-M8 may be true. I never said the F12 was an awesome sub but I own it and it suits me just fine along with about 200 other people who have bought it from Amazon. Definitely cant beat it for $200. I was trying to keep him at his stated ~$500 budget and that would put him at $650. If he wants to spend $650-$700 then there are plenty of other options. Personally I would still get the F12 and get some front towers instead of satellites. I prefer to spend my money above 100hz. Whatever the case may be, you are not going to get some kind of outstanding 7.1 setup for around $500. BTW, did you ever get that button on your remote control to work?
Licence to Kill
Bond 007 is offline
Old 09-01-2012, 01:00 PM
Flavius's Avatar
Liked: 46
No... I'm still confused about the Source power button and what exactly it is supposed to turn off. I was only able to get the TV to turn off using the tiny and badly placed TV power button the receiver remote (lower right).
Flavius is offline
Old 09-01-2012, 03:56 PM
Nick Burns's Avatar
Thanks for the suggestions.
What are people's thoughts on these:
Onkyo SKS-HT870 Home Theater Speaker System
Onkyo SKS-HT540 7.1 Channel Home Theater Speaker System
Not as lean
Not as mean
Still a Marine.
Old 09-01-2012, 04:03 PM
rothlike's Avatar
My last Harmony remote had no rechargeable battery and it was a pain to have to change batteries so often. Of course that was before I knew about the Samsung Interloop rechargeable AA batteries. I have a Harmony 880 currently and love it, will not be using a Harmony that is non-rechargeable going forward. Too convenient to just place the remote in its cradle.
Rich
Cheers! Big Rich
rothlike is offline
Old 09-01-2012, 07:00 PM
Bond 007's Avatar
Liked: 1911
Cant beat the price. Ive never known anyone to get Onkyo speakers but they have good reviews.
Licence to Kill
Bond 007 is offline
firmware update , pandora , Yamaha Rx V673 Receiver
