The "official" Yamaha RX-V673 thread. 7.2-Channel Network AVR - Page 117 - AVS Forum | Home Theater Discussions And Reviews
 42Likes
Old 07-21-2014, 01:00 PM
JeffAV's Avatar
I've done a rudimentary search but could not find an answer: What are the watts per channel with all (5) channels driven, e.g., not just 2 channels?
JeffAV is offline
Old 07-21-2014, 05:43 PM
Liked: 0
Audio Out Level Too High?
I've attached a bluetooth transmitter so that I can send output to another speaker in the house however the audio was terrible, very high level causing distortion. I assumed it was the bluetooth transmitter. However, when I plugged the RCA cable (via 1/8" adapter) directly into my headphones to verify audio was clear - i had the same result. The audio level coming straight from the "AUDIO OUT" RCA line jacks in the rear are WAY too high.
Any ideas?
Thanks in advance!
ruster34 is offline
Old 08-07-2014, 11:39 AM
clexell1's Avatar
Overdriven RCA pre-outs
Any ideas?
Thanks in advance!
I have the same issue. My RCA outputs are connected to a 6 channel whole-home audio amp-switcher. When unit is playing any media via zone 2 RCA outputs it is overdriven and distorted as if they are putting too much power through the line-outs.
When I play any media source from both main AND zone 2 (party mode) it sounds great. Problem gone.
I think it is a glitch that Yamaha is ignoring on this model.
For me, this is only an issue when the In-laws visit. Within seconds of their arrival, my father-n-law grabs the remote and switches the input from music to the golf channel. I, then (through the web server) turn on amp 2 and play my distorted, over-driven whole home music while he watches golf ALL WEEKEND.
clexell1 is offline
Old 08-07-2014, 11:49 AM
ThinkRationally's Avatar
Quoted: 44 Post(s)
Liked: 79
You could do both. For some audio inputs (Airplay, Server, Internet radio, and maybe the tuner) you can set the Video out to whatever your TV input is (like an HDMI input). You don't hear the golf announcers, you hear the music. I guess your father-in-law would have to be open to this compromise. As a fan of golf, I often do this myself--watch TV and listen to music instead of the TV audio.
Sorry, I don't have a solution for the audio quality problem.
ThinkRationally is offline
Old 08-07-2014, 01:24 PM
clexell1's Avatar
Thanks, I didn't realize i could do this.
clexell1 is offline
Old 08-20-2014, 10:16 AM
Liked: 0
Has anyone ever had the issue where sound intermittently cuts out? It will happen after about ten minutes of playing the radio. Sound turns off and on a few times then it will run fine for another 10 minutes or so before it happens again. Bought it 6 months ago and I'm just running FM radio through it at the moment as I finish my theater room. I did a small test when I first purchased it but didn't think to run it for very long. It has been in the box since then until now.
bigd2x0 is offline
Old 09-13-2014, 06:19 PM
missyman's Avatar
Quoted: 26 Post(s)
Liked: 29
I have a question. Does anyone here change their dsp program to fit the type of movie their watching? For example gravity would be sci/fi.
missyman is online now
Old 09-13-2014, 08:11 PM
Bond 007's Avatar
Quoted: 1922 Post(s)
Liked: 1672
I generally use Standard but use whatever sounds best to you.
Bond 007 is online now
Old 09-14-2014, 06:14 AM
kriktsemaj99's Avatar
Quoted: 628 Post(s)
Liked: 344
A lot of people just use Straight mode (with Extended Surround set to Dolby PLIIx Movie if you have a 7.1 setup). Otherwise it's whatever you happen to like best.
kriktsemaj99 is offline
Old 09-17-2014, 07:24 AM
Cla55clown's Avatar
Quoted: 121 Post(s)
Liked: 62
Yes I do. Maybe it's placebo effect but I feel it gets the most out of the movie soundtrack. Some people like their sound unmolested though so just do what sounds best to you.
Quick question: I connected a USB 3.0 external hard drive to the front USB port hoping to stream some .mkv movie files. Power light indicator came on on the hard drive but the AVR read 'access error'. What's the problem: the USB 3.0 or the .mkv files?
Cla55clown is offline
Old 09-17-2014, 10:00 AM
Quoted: 628 Post(s)
Liked: 344
^ The receiver only streams audio, no video files of any kind. You need a separate media streamer for video.
Old 09-17-2014, 02:16 PM
Liked: 1
Just thought i'd say that i've been running the RX-V673 on a 5.1 main and 2.0 zone 2 setup now for almost 3 years and the beast is still running strong! if wasn't forced to i would never have picked up the Denon AVR-X3000 for which i'm still on the fence.
Cla55clown likes this.
thekash is offline
Old 09-27-2014, 10:32 AM
apkesh's Avatar
Unhappy Receiver buttons do not work
Hi, I am no longer able to turn on the receiver manually. The only thing that seems to work is the volume, for everything else, I have to rely on the remote. Can someone tell me if this is a setup issue or something terribly wrong with the component it self?
Thanks in advance.
apkesh is offline
Old 09-27-2014, 10:55 AM
Cla55clown's Avatar
Quoted: 121 Post(s)
Liked: 62
Thanks in advance.
That surely doesn't sound right. Must be something wrong with the switch. Also check your setting associated with Eco mode.
Old 09-27-2014, 11:02 AM
apkesh's Avatar
Cla55clown, I think you may be on to something. I do see "ECO" displayed on the dashboard when power is on. Is there a way to turn this off with the remote?
apkesh is offline
Old 09-27-2014, 11:06 AM
Cla55clown's Avatar
Quoted: 121 Post(s)
Liked: 62
Press the 'on screen' button on the remote. Navigate to 'Setup' I think and the option for Eco mode is in there. Make sure you have an HDMI cable attached to your monitor so you can actually see the on screen menus.
Old 09-27-2014, 12:08 PM
apkesh's Avatar
Thank you. I disabled that feature and it still is an issue. I'll play around with it a bit more. Last resort, I'll reset it to factory settings.
apkesh is offline
Old 09-27-2014, 12:39 PM
Bond 007's Avatar
Liked: 1672
Thanks in advance.
The entire board would have to fail. Has it gotten wet or been dropped? Possibly a power surge. Take the cover off and see if anything looks funny. Otherwise have it serviced.
Old 09-27-2014, 02:48 PM
Quoted: 628 Post(s)
Liked: 344
Have you tried unplugging it from the wall yet? It solves a surprising number of problems (the power button doesn't really turn it off, so you have to unplug it).
Old 09-27-2014, 03:17 PM
apkesh's Avatar
yup, tried that too, no luck
so symptoms are this: None of the buttons work if the power is down. I do see the little red light next to power button, so that means the power source is there. I can also turn on the receiver using my remote so the problem seems to be concentrated to the buttons on the receiver. I can also turn up the volume using the volume knob. My receiver is not even 2 years old, and it's been plugged to a surge protector, so really hoping it's not damaged.
apkesh is offline
Old 09-27-2014, 03:56 PM
Bond 007's Avatar
Liked: 1672
Do all the buttons work once you turn it on with the remote? Can you turn it off with the power button?
Old 09-27-2014, 04:01 PM
apkesh's Avatar
No, only the volume works once I turn the power on using the remote. I have to use the remote to do anything else, including turning off the unit.
apkesh is offline
Old 09-27-2014, 07:29 PM
Bond 007's Avatar
Liked: 1672
Its damaged.
Old 09-27-2014, 09:03 PM
apkesh's Avatar
That was my fear. I just looked at my invoice, I had actually purchased the unit less than a year ago so hoping it's still covered under yamaha warranty. Has anyone dealt with this type of stuff with yamaha canada? Will they fix the issue for free?
apkesh is offline
Old 09-27-2014, 09:41 PM
Bond 007's Avatar
Liked: 1672
Dont know about Canada. Had a problem with my 671 in the US and after many hours over several days on the phone I sent it back to them and they replaced it with a 675 for free. I had to pay to ship it there.
Call them ASAP.
Old 10-02-2014, 02:42 PM
apkesh's Avatar
more bad news..just found out Yamaha Canada won't fix this unit as i had bought it in the US (Who knew Yamaha had different warranties for US vs Canada?!!)
I called the US Yamaha support and they told me to take it to one of the local shops. Do you happen to recall where you sent your receiver to? I'd rather mail it when I am in the US than deal with driving around looking for the repair shop.
Call them ASAP.
apkesh is offline
Old 10-02-2014, 05:10 PM
Bond 007's Avatar
Liked: 1672
I didnt send it to a repair shop. I sent it to Yamaha somewhere in the US. Dont remember where offhand.
Try the yamaha website for repair shops near where you want to take it or ask support.
Old 10-24-2014, 07:03 PM
Cla55clown's Avatar
Quoted: 121 Post(s)
Liked: 62
I added a centre speaker to my setup (so now 3.1) and ran YPAO. I adjusted my sub's gain knob to get close to 0db for the level after running YPAO. Now, my sub output seems too low (like not enough volume not low as in hz). My question is: what should I adjust to make my sub output more prominent to my ears? Looks like I can adjust the level in setup, the subwoofer trim in the options menu, or the acutal gain knob on the sub itself. Which one is best?
Old 10-24-2014, 07:09 PM
Bond 007's Avatar
Liked: 1672
Adjust it at the gain knob on the sub.
Old 10-25-2014, 10:52 AM
Cla55clown's Avatar
Quoted: 121 Post(s)
Liked: 62
Thanks I adjusted the gain knob up a bit and it does sound better/fuller. Still confused about what the 'Subwoofer Trim' option actually does. I have it set at +1.5dB. Also, what parametric EQ setting has everyone settled on? Options are flat, front, natural, and through. Should i be using front since i only have a 3.1 config?
Yamaha Rx V673 Receiver
