The "official" Yamaha RX-V673 thread. 7.2-Channel Network AVR - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 274Likes
post #541 of 3906 Old 10-10-2012, 09:40 AM
yozh's Avatar
Hello All,
I started reading this thread and kind of stopped when I saw 18 pages smile.gif
I`m looking to purchase a receiver now for my new house that is being renovated. I dont want to spend a lot of money, but I do want a decent setup. I know I need 2 zones, 1 for porch and 1 for living room and need AirPlay (bluethooth would be nice too), Pandora etc..
I started looking at this Yamaha and the Denon 2113 or 2313. I`m very undecided if I should get this 673BL Yamaha or the Denons.
Which is the better quality, sound, functionality and reliability ? Which provides more functions and I guess more bang for the buck ?
Thanks in advance !
yozh is offline
post #542 of 3906 Old 10-10-2012, 10:08 AM
GoBroncos's Avatar
Originally Posted by yozh View Post
Hello All,
Thanks in advance !
Denon may have a small edge over Yamaha in sound quality, but I like the Yamaha sound better. If you will use the network App to control it, I think it's a no-brainier to go with the yamaha. Yamaha has a great user friendly App that works on most phone and tablets. My 6 year old son knows how to use it.
As far as price goes I checked the discount code of GRANDSLAM at Electronics Expo this morning and it gets you the receiver by itself for $404. That's hard to beat. There were some earlier upgrades but I think they are gone now.
GoBroncos is offline
post #543 of 3906 Old 10-10-2012, 10:11 AM
yozh's Avatar
Yeah I saw this price. It is hard to beat... My house wont be finished till New Years.... So I dont really want to jump on it now, unless I find a kill BF type of deal... So I`m still doing my research on what to get....
yozh is offline
post #544 of 3906 Old 10-10-2012, 11:14 AM
Flyinn_High's Avatar
Hello, after reading all this great info i went and bought this receiver. But now have a few questions if any one could help.
1: is the audio type under info suppose to be PCM all the time? Even when watching dts movies?
2: how do i get the radio to work when watching tv or game. I thought i read this earlier but cant seem to find that info.
3: how do i access the web address for on screen. I thought it said 192.168.1.21. But just hangs on that, since i have a 64b system do i need to run it in 32b?
Other then that, i think i have it set up good.
Flyinn_High is offline
post #545 of 3906 Old 10-10-2012, 03:19 PM
kriktsemaj99's Avatar
Quoted: 665 Post(s)
Liked: 383
1. If it shows PCM then that's what the player is sending, so change the player settings to send bitstream (and disable anything such as Secondary Audio that might prevent the player from sending a bitstream).
2. In the Input menu under Video Out, you can specify which video source you want to see when TUNER is selected.
3. Are you trying to control the 673 from a web browser? 64- vs 32-bit is not important. Double check the IP address of the 673 and you should be able to enter this in your browser address bar. But it needs to be on first unless you enable Network Standby.
kriktsemaj99 is offline
post #546 of 3906 Old 10-10-2012, 04:26 PM
Thanks. Tuner and game working great. But still cant seem to find where to change from pcm. The hdmi is coming from my pc, gtx 680. All i can seem to find is which output to use not any output. In the windows set up i have it to 7.1 and testing has all working but still in pcm and movies still don't play all speakers. Any ideas?
post #547 of 3906 Old 10-10-2012, 05:45 PM
Quoted: 665 Post(s)
Liked: 383
Can't really help with the PC, sorry.
post #548 of 3906 Old 10-10-2012, 06:35 PM
galileo2000's Avatar
Hello All,
Thanks in advance !
You do expect someone to do your homework for you.
Good luck!
Good time to buy computers and computer parts: NEVER
galileo2000 is offline
post #549 of 3906 Old 10-10-2012, 07:33 PM
Feddie's Avatar
Quoted: 28 Post(s)
I got the A720 upgrade, so I guess I'm off to find that thread. Thanks for those that provided the information!
Feddie is offline
post #550 of 3906 Old 10-10-2012, 08:05 PM
Congrats kamrad!
See you on A720 thread!
post #551 of 3906 Old 10-11-2012, 05:24 AM
WaldoMan's Avatar
Intermittent Standby Problem
I am experiencing a very annoying intermittent problem. My receiver is set to Standby mode so that I can watch TV normally on HDMI1 when the receiver is "powered off".
Occasionally, about 10 seconds after I press the "Power Off" button, I get horrible noises out of the speakers. Sometimes it is a loud white noise, sometimes it is a high pitched tone, sometimes there are voices in it. Last night it happened and repeated every time the unit was powered off. I recycled the power by unplugging the receiver and it quit happening, for the moment. But it will happen again because it always does.
I can't be the only one experiencing this symptom. How can it be corrected?
WaldoMan is offline
post #552 of 3906 Old 10-11-2012, 07:36 AM
JBWIII's Avatar
Liked: 44
Because of the voices in the noise I was going to say either psychotic episode or haunting, but since uplugging it helped, it doesn't sound like either of those. I would recommend re-checking all of your connections and doing a full reset on the receiver (see the manual). If it doesn't help, then it might need repair. How old is it?
JBWIII is offline
post #553 of 3906 Old 10-11-2012, 11:58 AM
tornadog's Avatar
Quoted: 65 Post(s)
I am looking to replace a Pioneer VSX 920K
Is this a good upgrade?
tornadog is offline
post #554 of 3906 Old 10-11-2012, 12:32 PM
WaldoMan's Avatar
At this point I am thinking that the psychotic episode is the most likely cause.
The receiver is brand new - a couple of weeks old. The manual says (p. 115) "Hold down MAIN ZONE power button on the front panel for more than 10 seconds to initialize and reboot the unit." I have done that but the problem persists.
I believe that I have isolated the problem to a particular sequence of events. The following seems to consistently cause the problem:
  1. Watching TV, with the receiver on and supplying the audio.
  2. Power off the TV.
  3. Power off (standby) the receiver.
  4. Now the receiver is hosed & making funny sounds. Turning the receiver on and off again results in different horrible sounds (sometimes those little voices).
Reversing steps 2 and 3 seems to consistently circumvent the problem. That is, powering off the receiver first and the TV second prevents the problem.
Is anyone else here seeing anything similar? Maybe it has to do with the model of my TV (Hitachi). Regardless, it seems to me to be a flaw in the RX-V673 software.
WaldoMan is offline
post #555 of 3906 Old 10-11-2012, 04:44 PM
Manfred Man's Avatar
Originally Posted by JD NC View Post
Depends who you ask - interconnects and wires can be particularly touchy subjects around here. AFAIK, the metal contacts inside the clips are electrically the same as the contacts inside the binding posts, so if you're using a higher gauge wire and make sure it makes a secure contact over a large area within the clip, there's no reason for performance to be any different than with a banana plug. The main drawback of clips is that they're flimsier and will come loose much easier if there's any tension on the wire, whereas banana clips will just pop out with no damage. As long as the wire makes a nice fat contact inside the clip and you don't yank on the wires though, the juice should flow just fine.
Thanks for the confidence booster. I think installing in-wall speakers might be a weekend project coming down the pipe...
Manfred Man is offline
post #556 of 3906 Old 10-12-2012, 04:29 AM
Gmash's Avatar
Quoted: 144 Post(s)
Liked: 143
I would hook the soundbar up to the zone 2 and your good speakers to the main channels. Just saying.wink.gif
Gmash is offline
post #557 of 3906 Old 10-12-2012, 05:32 PM
tbm4's Avatar
I was about just about the pull the trigger on the 671 and hope for the upgrade, but EE now has it listed as sold out...
I may buy an open box 673 (listed at $439). I don't know much about this, can anyone give me a quick differences between the 673 and the A720?
tbm4 is offline
post #558 of 3906 Old 10-13-2012, 02:19 AM
Bond 007's Avatar
Quoted: 2650 Post(s)
Liked: 2103
Have you looked at the Yamaha website?
Licence to Kill
Bond 007 is offline
post #559 of 3906 Old 10-13-2012, 12:06 PM
tbm4's Avatar
Yes, it seems the Aventage is the higher end...but it's a bunch of specs that I am not very familiar with...
tbm4 is offline
post #560 of 3906 Old 10-13-2012, 01:06 PM
LSG_Da_Bears's Avatar
I pretty much had the same question on these two. I had saw the A720 upconverted component and was 6 lbs heavier.
JBWIII and Galileo chimed in with the A720 being the low end of their upper models and it also has a fifth foot, a second front control dial for selecting sources, a removable power cord, and an extra year of warranty.
LSG_Da_Bears is offline
post #561 of 3906 Old 10-13-2012, 02:39 PM
Quoted: 665 Post(s)
Liked: 383
The 720 doesn't convert component to HDMI (except for 480i input), so it's the same as the 673 in this respect. With this year's models you need the 1020 to convert HD component to HDMI.
post #562 of 3906 Old 10-13-2012, 10:14 PM
MSUSparty1's Avatar
I am trying to decide whether to buy this Yamaha 673 or a Pioneer 1122. I can get the Pioneer about $25 cheaper, but would rather pay the extra to get the better receiver. However, I own pioneer fl51 floor-standing speakers which are 6 ohms. Can I switch the Yamaha settings from 8 ohms to 6?
Amplifier Section Channel 7.2
Rated Output Power (1kHz, 2ch driven) 105W (8ohms, 0.9% THD)
Rated Output Power (20Hz-20kHz, 2ch driven) 90W (8ohms, 0.09% THD)
Dynamic Power per Channel (8/6/4/2 ohms) 130/170/200/240W
That is on the manual, but I am ignorant to audio specs.... any help?
MSUSparty1 is offline
post #563 of 3906 Old 10-14-2012, 04:37 AM
Bond 007's Avatar
Liked: 2103
Yes you can switch the Yamaha to 6ohm and it is very easy to do. Look at Advanced menu in the manual.
Licence to Kill
Bond 007 is offline
post #564 of 3906 Old 10-14-2012, 07:30 AM
JD NC's Avatar
Liked: 40
The soundbar is 7 channel, but Zone 2 is 2.0/2.1, so the soundboard has to be on zone 1 to work properly.
JD NC is offline
post #565 of 3906 Old 10-14-2012, 09:35 AM
Bond 007's Avatar
Liked: 2103
What kind of soundbar is it?
Licence to Kill
Bond 007 is offline
post #566 of 3906 Old 10-14-2012, 10:28 AM
gleapman's Avatar
Originally Posted by gleapman View Post
(Post from June 2012) I'm with 3gjgr. Had hoped to replace my v663 with the v673. I'll be watching to see if Yamaha adds back Pandora before spending the $600. But, if Denon wises up before then and adds Zone 2 to its mid-priced receivers WITHOUT having to give up the rear surround-sound speakers, Denon gets my $600 (I'd even go to $700 for the extra channels).
No Pandora is still a deal killer. I'll keep checking back each month to see if Yamaha has grown a brain. Once the v673 has Pandora, I'll own a v673.
gleapman is offline
post #567 of 3906 Old 10-14-2012, 04:54 PM
Are you sure that Zone 2 can be 2.1? I was under the impression that Zone 2 could only be 2.0. That's why I'm still struggling with the decision about how I might hook this up. The speakers I'm looking at should be pretty darn good without a sub-woofer but from what I've read unless you've got some really high end/expensive speakers (i.e. 5k/pair) a sub-woofer is going to help your sound.
post #568 of 3906 Old 10-14-2012, 04:55 PM
It's a Polk SoundBar 400.
post #569 of 3906 Old 10-14-2012, 05:57 PM
Bond 007's Avatar
Liked: 2103
:Dont hold your breath. I think Yamaha is telling people they will add Pandora to pacify them. They probably signed an agreement with Apple to not provide it so that people would be encouraged to buy an Airplay product. Apple is well known for this kind of thing. Why else would they go through the trouble to remove it in the first place? And dont forget they also removed Sirius XM, Netradio and Napster.
Licence to Kill
Bond 007 is offline
post #570 of 3906 Old 10-14-2012, 06:09 PM
Bond 007's Avatar
Liked: 2103
Holy sh#@! You spent $600 for a soundbar!? Please tell me someone gave that to you.
Licence to Kill
Bond 007 is offline
firmware update , pandora , sound dropping out , Yamaha Rx V673 Receiver
