The "official" Yamaha RX-V673 thread. 7.2-Channel Network AVR - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 57Likes
post #811 of 3880 Old 12-17-2012, 10:12 AM
Wildmanzero's Avatar
Originally Posted by RX-V673 View Post
The winamp plugin I found isn't free....winamps jump feature is so handy, looks like I'll need to find an alternative way to send music from my pc.
DO you realize that WIndows Media Player can function as a music server? See page 65 in the RX-673 manual.
Wildmanzero is offline
post #812 of 3880 Old 12-17-2012, 11:13 AM
Bond 007's Avatar
Quoted: 2561 Post(s)
Liked: 2023
I tried updating the firmware via a USB stick and got the Device Error after some verifying...tried FAT & FAT32 and no go...guess I'll leave it alone until I find another usb stick..dont want to do it over wifi...
Also I isolated the lagged audio issue when using the xtreamers, its definitely the xtreamer, when I hook it up to a laptop via usb and hdmi the laptop to receiver all is good when playing the same file.
Repositioned my subby to the corner of the room and YPAO gave the W-3 Error..I'll need to look at this after work, I didnt save the setting.
Airplay isnt as good on my android SE xperia mini, much easier on the iphone...(theres also two yamaha apps on the iphone), there isnt an airplay button in the native music player.
W-3 Error is a common "out of phase" error. Check to mae sure your wires are properly hooked up and if they are then ignore it.
Licence to Kill
Bond 007 is offline
post #813 of 3880 Old 12-17-2012, 12:45 PM
chrisg75's Avatar
OK, So I have my new Sony 55" HX850 tv connected to Yamaha HTR6065 AV Receiver via the ARC HDMI, and then all other items (DVD player, PS3 and Foxtel IQ2 HD) connected through the HDMI inputs to the receiever
Was watching I think Animal Planet last night on foxtel and to be honest, it looked kinda bad quality. From memory it looked better on my old receiver and TV.
Anyone suggest settings to check to make sure im getting the best out of my set up ?
cheers
chrisg75 is offline
post #814 of 3880 Old 12-17-2012, 02:01 PM
Bond 007's Avatar
Liked: 2023
cheers
Make sure the receivers video processing is off.
Licence to Kill
Bond 007 is offline
post #815 of 3880 Old 12-17-2012, 04:05 PM
chrisg75's Avatar
Oh Ok....Is it not good ?
Will check it tonight
Cheers
chrisg75 is offline
post #816 of 3880 Old 12-17-2012, 04:37 PM
Bond 007's Avatar
Liked: 2023
Cheers
Sometimes it can be helpful. Sometimes not. But it can affect PQ so its worth looking into.
Licence to Kill
Bond 007 is offline
post #817 of 3880 Old 12-17-2012, 05:56 PM
RX-V673's Avatar
I've got a server, I more wanted to push music to the system e.g. when im on the pc. I havent found anything to replace winamps Jump function.
I moved the config mic and all is well.
RX-V673 is offline
post #818 of 3880 Old 12-18-2012, 04:58 AM
probman's Avatar
Pc is a server and music plays but from where? Pc is turned off and still music playing when server selected as input. Unable to change playist on Media player am only able to browse on TV display. Do not think I am in the cloud, did not set up as such. As side not, Asus 300tf tablet plays fine through 673. Total control.
probman is offline
post #819 of 3880 Old 12-18-2012, 08:15 AM
raudraido's Avatar
Where I can disable AIRPLAY so that everyone on my home network cant access to my receiver?
At the moment every computer on my home network has the airplay icon and they can send music to my receiver. Same with ios/android devices.
Is there any solution?
raudraido is offline
post #820 of 3880 Old 12-18-2012, 10:40 AM
defdog99's Avatar
Quoted: 81 Post(s)
Liked: 53
It seems to discover off your router subnet. Maybe you can do router tricks and make a dmz to put your wanted airplay devices in.
and everyone else gets the default subnet.
Just guessing.
defdog99 is offline
post #821 of 3880 Old 12-19-2012, 01:53 AM
Xmodtv's Avatar
Hi all, Has anyone come across the problem of having two 673s in one house and wanting to control both from the Android/apple app. I set these up for a customer this afternoon after he jumped on the JB hifi deal and bought two. One upstairs, one downstairs, the wifi is srrong enough to run both but I want to seperate them
Any ideas?
Xmodtv is offline
post #822 of 3880 Old 12-19-2012, 03:13 PM
El Burrito's Avatar
Just a guess, since I cant try it only having one; you can rename the receiver. So if u give them two different names the different names should show up when starting up the app. Hope this works, curious!
El Burrito is offline
post #823 of 3880 Old 12-19-2012, 03:59 PM
Bond 007's Avatar
Liked: 2023
I am not certain either but I am pretty sure they would need separate ip addresses.
Licence to Kill
Bond 007 is offline
post #824 of 3880 Old 12-20-2012, 09:41 AM
joycetopher's Avatar
Hooked up my new 673 yesterday. The network connection is fine and i can stream from my home computer using windows media player. The app works on my iphone5 and I can stream music from my phone using the app and access my home media server, this is all on the "server" input. The problem is when i switch to airplay i cannot seem to see anything. My itunes on my computer and music library on my iphone do not have the airplay icon, that I am supposed to see. Any suggestions?
Cheers
joycetopher is offline
post #825 of 3880 Old 12-20-2012, 03:47 PM
RX-V673's Avatar
Cheers
Set the receiver to Airplay, on your iphone (connected via wifi to your home network) you should see an icon on the bottom right of itunes. Press it and it should send whatever is playing on your phone to your receiver.
RX-V673 is offline
post #826 of 3880 Old 12-20-2012, 04:02 PM
Yea i tried that, no icon anywhere. i can stream the music from my phone no problem using the Yamaha app, but airplay i cant see anything. I see on the internet what it is supposed to look like i just have the back ,forward, and play icon.
post #827 of 3880 Old 12-20-2012, 04:08 PM
RX-V673's Avatar
Are you saying you can't push music to the receiver (when its set to Airplay) via your itunes on the computer?
RX-V673 is offline
post #828 of 3880 Old 12-20-2012, 06:00 PM
yes that is correct, when set to airplay i cannot push any music to it. i do not see the airplay icon anywhere, computer or iphone. no problem pushing music when i use the yamaha app but set server. i can use that to play the music that is stored on my i phone or use it to see music that is located in media player.
post #829 of 3880 Old 12-20-2012, 06:33 PM
DeadEd's Avatar
Quoted: 86 Post(s)
Liked: 176
And AirPlay has been turned on in the receiver menu?
Dyslexics are teople poo.
DeadEd is offline
post #830 of 3880 Old 12-20-2012, 08:14 PM
Yes it's on
post #831 of 3880 Old 12-21-2012, 09:46 AM
probman's Avatar
have you updated itunes on computer? Airplay upper left corner while viewing libary on pc, it should stream itunes on computer as well as cloud content.
probman is offline
post #832 of 3880 Old 12-21-2012, 01:00 PM
im running itunes 11 on my computer. still no icon appearing. version 6.0.1 on my iPhone. shot an email into yamaha to see what they say as well.
post #833 of 3880 Old 12-21-2012, 06:36 PM
2K6TSX's Avatar
Does anyone know if there's a way to reduce the number of presets? I have 40 and only use about 6. I find it annoying how the rest of them are the same as #1. It keeps cycling through 7-40 and they're the same station. I'd rather have it loop back to #1, 2, 3 etc.
Also wondering if there's a way for this receiver to connect via wifi to do a software update. I don't have any cables connected to provide internet. Running on strictly wifi at the moment.
Thanks in advance!
2K6TSX is offline
post #834 of 3880 Old 12-21-2012, 06:58 PM
Bond 007's Avatar
Liked: 2023
Thanks in advance!
2 very good questions. I think the answer is no to both but I hope someone will prove me wrong.
Licence to Kill
Bond 007 is offline
post #835 of 3880 Old 12-21-2012, 09:24 PM
vespadaddy's Avatar
I've not even plugged my 673 in yet, but I can tell you that it isn't wireless. You'll need to either plug a network cable into the AVR, or buy the wireless adapter device to add wireless capability.
From what I have read, you can download the firmware update to a thumb drive, and use that to update the firmware...
vespadaddy is offline
post #836 of 3880 Old 12-22-2012, 06:46 AM
Leiterch's Avatar
Is anyone having issues with such woofer signal from their directv through their yamaha? I have been having intermittent subwoofer signals throughout different programs. It is very odd. I don't know if it is the yamaha having difficulty with the signal from the directv or if it is the yamaha. Wondering if anyone has experienced this issue.
Sent from my DROID RAZR using Tapatalk 2
Leiterch is offline
post #837 of 3880 Old 12-22-2012, 07:47 AM
Bond 007's Avatar
Liked: 2023
Depending on your 673 settings that may be because it is not always a 5.1 signal. Are you using "straight" or "direct" sound programs?
Licence to Kill
Bond 007 is offline
post #838 of 3880 Old 12-22-2012, 10:00 AM
sabes35's Avatar
Is there a way I can watch tv through HDMI 1 while listening to Airplay?
sabes35 is offline
post #839 of 3880 Old 12-22-2012, 03:06 PM
kriktsemaj99's Avatar
Quoted: 648 Post(s)
Liked: 368
Go to Input Menu / Video Out (page 83 of the manual). It lets you specify a video source to play while listening to various audio sources. It doesn't say explicitly, but I assume it works for Airplay.
kriktsemaj99 is offline
post #840 of 3880 Old 12-22-2012, 03:48 PM
ousooner2's Avatar
Quoted: 289 Post(s)
Liked: 179
Has anyone had issues with one channel not coming on upon power up? This has to do with my rx-v663, but that thread is SO old that I figured I might get a little more help here. I know for a fact it's the AVR and to get it to come on you have to turn it off and back on until that specific channel (FRONT RIGHT) comes on. Sometimes you can get away with turning up the volume and it finally gets power to the FR speaker. Weird I know...
Currently Auditioning: Klipsch RP-150M
SOLD: EMP e55ti / EMP e56ci / EMP e5bi / (2) e1010i
FOR SALE --- 1 EMP Tek/RBH Sound e1010i sub: http://www.avsforum.com/forum/209-au...al-10-sub.html
ousooner2 is offline
firmware update , pandora , Yamaha Rx V673 Receiver
