The "official" Yamaha RX-V673 thread. 7.2-Channel Network AVR - Page 52 - AVS Forum | Home Theater Discussions And Reviews
 54Likes
post #1531 of 3875 Old 04-10-2013, 04:40 PM
kriktsemaj99's Avatar
Quoted: 636 Post(s)
Liked: 357
Originally Posted by BigBlkYJ View Post
A quick update to my firmware issue. The current firmware is 1.22 the upgrade says 1.64. Seems like a major jump haha! Also does anyone have any thoughts on my above audio problems? Maybe this update will solve them..?
If you mean the problem where STRAIGHT mode only gives you stereo, then no. That usually means that you are only sending a 2 channel signal to the receiver. What's your source and how is it connected?
kriktsemaj99 is offline
post #1532 of 3875 Old 04-10-2013, 05:17 PM
Iwanthd's Avatar
Quoted: 27 Post(s)
I am trying to install the receiver app on my kindle fire (NON-HD model) I have downloaded the android app but am having trouble with finding my 673 on the network. Network standby is onany suggestions?
After downloading from amazon and auto install, the Select Device screen comes up and i can only choose Blu-Ray Demo or AV Receiver Demo.
Iwanthd is online now
post #1533 of 3875 Old 04-10-2013, 05:52 PM
zapper's Avatar
Quoted: 52 Post(s)
Hi, tomorrow will set up my 673 and see if it works with my BenQ PJ , if that happens then have to think about a WI-fi adapter and asking this thread what adapter are you using with your receiver?
Ralph
zapper is offline
post #1534 of 3875 Old 04-10-2013, 09:32 PM
zapper's Avatar
Quoted: 52 Post(s)
Guy's will this wireless adapter work with the 673???? or should I get the real McCoy??
http://www.amazon.com/TP-LINK-TL-WN722N-Wireless-Adapter-Detachable/dp/B002WBX9C6/ref=cm_cr_pr_product_top
Ralph
zapper is offline
post #1535 of 3875 Old 04-10-2013, 09:39 PM
wader2k's Avatar
You need a wireless bridge. I ordered this one but haven't received it yet:
http://www.amazon.com/NETGEAR-WNCE2001-Universal-Internet-Adapter/dp/B007CO5DZ4/ref=sr_1_1?s=electronics&ie=UTF8&qid=1365651530&sr=1-1&keywords=NETGEAR+WNCE2001+Universal+WiFi+Internet+Adapter+refurb
wader2k is offline
post #1536 of 3875 Old 04-10-2013, 09:48 PM
zapper's Avatar
Quoted: 52 Post(s)
So assuming that it will work, if so will order one myself better then the $80 that asking for the Yamaha one.
Ralph
zapper is offline
post #1537 of 3875 Old 04-10-2013, 10:13 PM
twicebishop's Avatar
Did you enter the IP address of the receiver into the App under settings?
twicebishop is offline
post #1538 of 3875 Old 04-11-2013, 12:13 AM
ronnymills's Avatar
Currently running HDMI (ARC) from the 673 to TV. How do I run a mirrored composite A/V signal to a regular old SD TV in the kitchen? (Kitchen is wired for composite A/V and not willing to change it yet).
ronnymills is offline
post #1539 of 3875 Old 04-11-2013, 07:19 AM
Iwanthd's Avatar
Quoted: 27 Post(s)
Yes I did. It appears that my receiver has lost its connection to the network somehow. Weird because on the network status page it says connected but none of the internet radio or pandora will work due to no connection. I'm using the Yamaha wireless dongle which I will attempt to reinstall to get network connection back. Any other suggestions welcome. Thanks.
post #1540 of 3875 Old 04-11-2013, 08:20 AM
dont24's Avatar
Just received my 673 last night. Still going through the setup. Have a question about setting up my PS3, slim model. Originally set to pcm, since I was using optical to my previous receiver. Now using HDMI from my PS3 to the 673. Info screen ( lower left ) shows PCM. When I switched the PS3 to bitsream, info shows DTS-HD MA. I'm assuming bitstream is the correct setting I should be using?
dont24 is offline
post #1541 of 3875 Old 04-11-2013, 08:53 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Older PS3s needed to be set to PCM over HDMI. Slims can use bitstream. You are getting lossless that way. Also, with optical, bitstream is always the correct setting as PCM is limited to stereo over optical connections.
BIslander is offline
post #1542 of 3875 Old 04-11-2013, 09:10 AM
dont24's Avatar
Thanks. I Googled after my post and found this. http://www.engadget.com/2009/04/21/hd-101-how-to-use-dolby-truehd-and-dts-hd-with-your-ps3/ I do see it was written in 2009, so maybe something has changed since then?
That article seems to indicate better audio using PCM. Either way, I'll let my ears decide if either setting basically produces the same audio output. Looks like other searches are turning up bitstream as well. That'll be what I use.
dont24 is offline
post #1543 of 3875 Old 04-11-2013, 09:21 AM
BigBlkYJ's Avatar
Figured it out last night while in the Info section. Im using a PS3 for bluray and found that the settings of the PS3 were o ly PCM 2.0. Set all of them to on and now I get full DTS Master 7.1 without Cinema DSP faking it from a 2.1 signal! So you were right on point with that!
My Firearms/Outdoors forum: http://thegungroup.com
BigBlkYJ is offline
post #1544 of 3875 Old 04-11-2013, 10:21 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
TrueHD and dts-MA are simply zipped up versions of the original PCM. They are used to save space on the disc just the way a zip file is used to compress regular data files. TrueHD and dts-MA must be decoded back into PCM before they can be processed to produce sound. It does not matter whether the player or the receiver does the decoding. The exact same PCM is produced either way. There may be other factors involving secondary audio or related to specific limitations of your equipment that favor one approach over the other. But, there is zero difference in the PCM produced by player and receiver decoding.
And, yes something changed after 2009. The "fat" PS3s could not bitstream lossless codecs. The newer "slim" models can.
post #1545 of 3875 Old 04-11-2013, 12:44 PM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
I called Yamaha today and had a rather lengthy chat with the level 2 tec. All in all he said only way to get same sound at the same time out of the 673 is to put it in 7 channel stereo and use a switch for rear surrounds. Turn them on when you want music, or switch them to your main room when you want it to be 6/7 speakers. Not a huge problem and could even put an inline volume control in if needed.
The 773 he said gives me several more options I don't really need besides, party mode . ALSO it says PARTY on the remote, that's kinda cool. He said all things being equal there is not much of a bump in performance at the 673 until I move up to the A1020. Unfortunately that's out of my price range.
He told me that Costco has their own special version of the 773 called the HRT-7065. its the exact same receiver, it just doesn't come with the wireless adapter. Curious I called around to a few local Costco ( you wont find it listed on their online store, they have different products at the store location) and they quoted me 479.99 So, compared to the current amazon price of that 773($799) its a bargain.
But Newegg is having a sale on the 773 and its .....479.00 w free shipping. I paid $357.00 for my 673, cant decided if its worth the extra money to get the 773 if all I really care about is PartyMode. The five additional watts is negligible He even said, "its all marketing, no real reason besides that we don't include it on the other models". Really happy with their customer support BTW. Called this morning with my question and they gave me a ticket number telling me a lvl 2 tec would be following up and they called a few hours later. +1 for Yamaha.
"we need more power" - My Wife.
Theater Build Thread - Wartooth
lemonslush is offline
post #1546 of 3875 Old 04-11-2013, 12:46 PM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
Turn up the sub. There's no reason to leave it at 25% if you want more bass. If the Yamaha sub output uses a lower voltage than the Onkyo, you'll need to turn up the sub gain to compensate, but it doesn't mean the sub has to work any harder to produce the same volume of sound.
Yea logically you make total sense. I would still be getting the same DB out of the sub. I didn't know if it would be more taxing on my amp.
post #1547 of 3875 Old 04-11-2013, 01:50 PM
dont24's Avatar
I was going back and forth deciding the same exact thing. For me , it was the 773 has the ability to send a digital signal to zone 2, via party mode. I ended up going with the 673 for $358 as well from Amazon. I ran analog cables from my Dish 722 ( TV 2 ) to Audio1. I can now get the Dish Sirius XM channels to zone 2. One thing I noticed, when playing around with Airplay. Using the iPad app, I selected Zone 2 and Airplay. When I started playing music, Main zone also switched to Airplay music. Not sure why, since the 673 doesn't have party mode. Both zones were playing music from my iTunes at the same time.
dont24 is offline
post #1548 of 3875 Old 04-11-2013, 05:16 PM
steve>jf's Avatar
Has anyone had any experience with slight degradation in video when connected thru the 673 with a BD player using HDMI and the 673 in STRAIGHT video mode? When directly connected to the TV, the colors seem more vibrant. The only adjustments available in the 673 when in PROCESSSING mode are RESOLUTION and ASPECT. I thought that new HDMI receivers were supposed to improve or at a minimum not degrade picture quality?
Steve
steve>jf is offline
post #1549 of 3875 Old 04-12-2013, 06:52 AM
craigrendle's Avatar
Hi can some one please help me,I'm a newbie to the whole surround av game,iv recently purchased the yamaha 673/mass package from richer sounds..the problem I'm having is that I don't think I'm getting 'true HD' sound,do I need to set this up within the amp or bluray player for the amp to play it?..it's just when I'm playing a bluray that is trueHD comparable I can only switch the sound source between the settings of dolbypro music/dolbypro movie/straight etc etc and it does not display as true HD?? Help please smile.gif
craigrendle is offline
post #1550 of 3875 Old 04-12-2013, 08:15 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Do you have a 5.1 system? If so, the fact that you can select ProLogic means your player is sending stereo, not encoded multichannel sound. So, I would start by checking the audio output settings of the Blu-ray player. What player do you have and what the the audio settings?
post #1551 of 3875 Old 04-12-2013, 10:23 AM
yes i have a 5.1 system i have the panasonic DMP BDT220 i have been in the settings and in digital out put it has
dolby d/dolby d+/dolby true HD = bitstream
DTS/DTSHD = bitstream
MPEG audio = PCM
BD- video secondary audio = off
hdmi audio output = on
im not actually sure if i have dolby pro on the actually amp display it is saying av1 and it also has lit up cinema DSP and sound is coming out of all the speakers, totally lost with this, spoke to richer sounds and they said that it should say true HD or DTS HD on the display if it is outputing it..and also said they would come set it up for 50quid! which i found quite cheeky as id just spent 2k with them on the speaker/amp TV package
post #1552 of 3875 Old 04-12-2013, 10:24 AM
is there something in the amp settings i need to change maybe?
post #1553 of 3875 Old 04-12-2013, 10:24 AM
MPEG audio = PCM
post #1554 of 3875 Old 04-12-2013, 11:02 AM
now im getting a 'decoder off' on the display?? aghhhh nothing is working now lol
post #1555 of 3875 Old 04-12-2013, 11:03 AM
LeSaux's Avatar
Hello,
I have RX-V 673 and use the app on my iPad mini to control it. Is there any option how to "move" in a song (a time bar)? For example: to skip first 30 minutes in a long dj set... And moreover I haven't found an info about a length of song...
Thank u!
LeSaux is offline
post #1556 of 3875 Old 04-12-2013, 11:27 AM
ok got sound back but still no true HD :/
post #1557 of 3875 Old 04-12-2013, 11:55 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
MPEG audio = PCM
Those settings are correct. When you select a track using one of the listed formats, the player will simply send it to the receiver for decoding. Your AVR display should report whatever format was encoded on the disc you are playing (TrueHD. DTS-HD Master Audio, etc).
There is nothing you need to change on the receiver. Frankly, you may have everything running as it should and simply don't understand what the receiver display means. AV1 is the name of an input - rthe AVR is telling you what input you are using at the time. Cinema DSP refers to a group of Yamaha Digital Signal Processing modes that alter the sound. You may or may not have applied any one of a number of DSP choices. I think you need to spend some time with the manual and the receiver to learn more about how it operates. One thing I would do is turn off any Cinema DSPs, which will make it easier to see what the receiver is actually doing.
post #1558 of 3875 Old 04-12-2013, 12:04 PM
thanks,but shouldnt the display state that it is playing trueHD or DTS HD? in red? at the moment there is nothing?
post #1559 of 3875 Old 04-12-2013, 12:50 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
^^ There can't be nothing.
post #1560 of 3875 Old 04-12-2013, 01:05 PM
This is the display I get,with the blu ray settings as I said earlier and with a true HD bluray playing :/
firmware update , pandora , Yamaha Rx V673 Receiver
